Página 2 de 2 Primeira 1 2
    Membro Avatar de Mahoney
    Originalmente enviada por CloneSIGN
    kero nem saber.....
    so vo fazer EEK qdo ver 2x 6800Ultra com FX-57 Overclocked
    É, HD Sata raid, Dual DDRII e Dual processor. hahuahauahuaa
    Membro Avatar de NIex
    apl525 here
    Serve esse??
    Technical Specifications
    Area-51 ALX with NVIDIA SLI Technology:
    Processors
    2 X Intel® Xeon™ Processor with Hyper-Threading and EM64T Technology Up to 3.6GHz, 800MHz FSB, 1MB full-speed Level 2 Cache
    Chipset
    Intel® E7525 chipset
    Operating Systems
    Microsoft® Windows® XP Professional Edition
    Memory
    Dual Channel DDR2 at 400MHz
    Four DDR2 DIMM sockets
    Up to 4GB of system memory
    Graphics
    PCI-Express x16 high-performance graphics
    Combined 512MB DDR3 dedicated video memory
    Dual DVI and S-Video outputs with dual-display support
    Full DirectX® 9.0 and OpenGL® 2.0 graphics compatibility
    Drive Bays
    Externally accessible:
    Three 5.25" for DVD-ROM, CD-RW, DVD/CD-RW, or DVD±RW drives
    Two 3.5" for floppy drive, 8-in-1 digital media reader / writer, or front accessible 1394
    Internally accessible:
    Six 3.5" bays for hard drives with tool-less access
    I/O Ports
    One 9-pin serial port
    One 25-pin parallel port
    Four 24-pin DVI ports*
    One 6-pin mini-DIN port***
    One IEEE 1394 port - 1 back
    Two IEEE 1394 ports - 1 back / 1 front (optional)
    Eight USB 2.0 ports - 4 front / 4 back
    Three 1/8" analog jacks / one optical output / one coaxial output
    Supports 6-channel (5.1) 20-bit audio
    Three 1/8" analog jacks / one 1/8" digital jack (optional)**
    Supports 8-channel (7.1) 24-bit high-definition audio
    One Gigabit Ethernet
    Serial ATA:
    Primary IDE Channel:
    Secondary IDE Channel:
    Floppy:
    Six Serial ATA-150 ports
    RAID0 and RAID1 (optional)
    One 40-pin connector
    One 13-pin connector
    Slots
    2 PCIe x16 slot for graphics
    3 PCI slots
    Chassis
    Chassis features:
    AlienIce high-performance air intakes illuminated in choice of colors
    Locking front and side panels secure and conceal front I/O ports and drive bays
    650 watt power supply with Active PFC
    Alienware ALX silent liquid cooling technology
    Up to six USB 2.0 ports (4 front / 2 back)*
    Three 5.25" external bays
    Two 3.5" external bays
    Six 3.5" internal bays
    *Dependent upon system configuration
    Power
    Output Wattage: 650 Watts (Max)
    Input Voltage: 100 - 240V at 50 - 60Hz
    Heat Dissipation: 853.2 BTU per hour (monitor not included)
    Backup Battery: 3.0V coin cell
    Operating Environment: 60-80 degrees Fahrenheit
    Eu esperava 2x 6600GT serem 20% mais rápido que uma 6800GT
