    Email inválido
    Resolução rapida em radeons??
    O q q seria recusros de resolução grafica nas placas radeon??eh bom deixar habilitado ou desabilitado??
    Nunca vi isso na minha vida.
    Email inválido
    entaum, eh os eguinte], eu instalei o omegadriver 2.5.30 e qd vc abre as configuracoes avancadas, opcoes, tem uma caixa para vc marcar desabilitar recurso de resolucao rapida....q diabos eh issooo/???
    Membro Avatar de In a RUSH
    Tough ain't enough!
    Disable quick resolution feature: If you have the ATI Taskbar Application enabled, the 'quick resolution feature' provides a menu (when you left-click on the small ATI icon in your system tray) which provides options for changing the color quality (16 and 32 Bits Per Pixel) and your desktop resolution. Once again, this is a relatively useless function, since not many people constantly change their desktop resolution and color quality. Tick this box to disable this feature and free up some system resources, and should you need to, change your color quality and resolution in the ATI Control Panel as usual.
    ATI Catalyst Tweak Guide (o texto acima foi copiado da página 6): http://www.tweakguides.com/ATICAT_1.html
