    Sapphire Radeon 9550 e boa
    blz pessoal...
    e o seguinte, essa placa Sapphire Radeon 9550 128 MB 128 bits e processo de fabricação de 0.13 micron, ta saindo a uns 300 contos, como to sem grana pra pegar uma placa que realmente vale a pena, compensa gasta 300 reals nessa...
    ao que o fornecedor fala da criança...
    Technology Features
    - 4 parallel pixel pipelines
    - 2 programmable vertex shader pipelines
    - 128-bit dual-channel DDR memory interface
    - AGP8x/4x
    - Core 250MHz
    - Memory 400MHz
    SMARTSHADER? 2.0
    - Support for Microsoft® DirectX® 9.0 programmable vertex and pixel shaders in hardware
    - DirectX® 9.0 Vertex Shaders
    Vertex programs up to 65,280 instructions with flow control
    - DirectX® 9.0 Pixel Shaders
    Up to 1,536 instructions and 16 textures per rendering pass
    32 temporary and constant registers
    128-bit, 64-bit & 32-bit per pixel floating point color formats
    Multiple Render Target (MRT) support
    - Complete feature set also supported in OpenGL® via extensions
    SMOOTHVISION? 2.1
    - 2x/4x/6x Anti-Aliasing modes
    Sparse multi-sample algorithm with gamma correction, programmable sample patterns, and centroid sampling
    Lossless Color Compression (up to6:1)at all resolutions
    Temporal Anti-Aliasing
    - 2x/4x/8x/16x Anisotropic Filtering modes
    Up to 128-tap texture filtering
    Adaptive algorithm with bilinear (performance) and trilinear (quality) options
    HYPER Z? III
    - Hierarchical Z-Buffer with Early Z Test
    - Lossless Z-Buffer Compression (up to 48:1)
    - Fast Z-Buffer Clear
    - Z Cache optimized for real-time shadow rendering
    VIDEOSHADER?
    - Seamless integration of pixel shaders with video in real time
    - FULLSTREAM? video de-blocking technology for Real, DivX, and WMV9 formats
    - VIDEOSOAP? noise removal filtering for captured video
    - MPEG1/2/4 decode and encode acceleration
    DXVA Support
    Hardware Motion Compensation, iDCT, DCT and color space conversion
    - All-format DTV/HDTV decoding
    - YPrPb component output for direct drive of HDTV displays?
    - Adaptive Per-Pixel De-Interlacing and Frame Rate Conversion (temporal filtering)
    Additional Features
    - Dual integrated display controllers
    - Dual integrated 10 bit per channel 400 MHz DACs
    - Integrated 165 MHz TMDS transmitter (DVI 1.0 / HDMI compliant and HDCP ready)
    - Integrated TV Output support up to 1024x768 resolution
    - Windows® Logo Program compliant
    - ATI CATALYST? Software Suite
    Obs.: Como podemos ver, a placa suporta as mesmas tecnologias que um modelo da linha Radeon 96xx ou 98xx.
    ________________________
    me da um help valeu galera..
    Membro Avatar de rocknaveia
    Eu to com umas GECube aqui, soh que eh 64bit , ateh que da pra quebrar um galho, agente vai usar na lan que o chefe ta montando, rodou NFSU , UT2k4 de boa
    ajuda ae pessoal, entre essa 9550 e uma saphire 8500 bba 250/250 por 260 reais, qual vale mais a pena?
    Membro Avatar de Son of Satan
    Não é boa, eu iria de 8500
    Originalmente enviada por «[email protected]»
    com certeza a 9550 caso seja 128bits, ela eh uma 9600 com clocks menores, com overclock ela eh melhor q a 8500 de qualquer forma.
    n3w
    n3w está offline
    tem 9600pro oem por R$400
    eu vi um monte de 9550 64bits
    de xorar
    tpo cara... os negos do classificados que trazem coisas dos eua, eu vi no topico do sapporo acho, ta trazendo r9600pro com clocks de 400/600mhz, que eh a melhorzinha, por 400 pau, vale a pena
    Olha cara.....e 8500 na cabeca, pois esta 9550 com certeza deve ser de 64bits, vc sabe mercado livre = paraguay = 64bits, a proposito vamu jogar bola amanha???
    GSJ
    GSJ está offline
    Jan 2001
    Não é bem assim... verifica o número de chips dela, se for 8 chips é 128bits...
    E outra, se for 128 bits é melhor que qualquer 8500, ainda mais com um bom overclock.
