    Membro Avatar de ZaRgON
    Qual desses LCDs?
    E ai, qual desses eh melhor? E pq o da Philips eh mais caro?
    PHILIPS 190S5FB 19" LCD Monitor, 12ms -RETAIL $447.49
    - Specifications -
    Panel Type: 1280 x 1024 pixels, Anti-glare polarizer, RGB vertical stripe
    Recommended Resolution: 1280 x 1024 @ 75 Hz
    Pixel Pitch: 0.294 x 0.294 mm
    Brightness: 250 cd/m2
    Contrast Ratio: 500 : 1
    Response Time: 12 ms
    View Angle: 160° / 160° (H / V)
    Input Connectors: 15-Pin D-SUB
    Features: Embedded power supply eliminates power adapters
    Dimensions & Weight: 16.73" x 14.9" x 2.75" (WxHxD) / 15.62 Lbs
    Manufacturer's Warranty / Phone No.: 3-Year / 877-835-1838
    Dead pixels policy: return or refund for 8 or more dead pixels only!
    Model#: 190S5FB
    Item#: N82E16824133147
    Rating: Vote(s): 27 Review(s): 6
    BenQ FP931 Silver 19" LCD Monitor -RETAIL $389.99
    - Specifications -
    Panel Type: TFT Active Matrix LCD
    Native Resolution: SXGA 1280x1024
    Pixel Pitch: 0.294 mm
    Contrast Ratio: 450:1
    Response Time: 16 ms
    View Angle: 130° / 130° (H / V)
    Input Connectors: 15-pin D-sub, DVI-D
    Features: Built in Power Supply
    Dimensions & Weight: 16.8" x 16.3" x 7.1"(WxHxD), 16.3 lbs
    Dead Pixels Policy: Replacement or Refund for 8 or more DEAD PIXELS ONLY!
    Model#: FP931
    Item#: N82E16824014063
    Rating: Vote(s): 26 Review(s): 19
    ACER AL1912b 19" Black LCD Monitor - Retail $356.50
    - Specifications -
    Native Resolution: SXGA 1280 x 1024
    Contrast Ratio: 500:1
    View Angle: 140 (Vertical)
    Input Connectors: 15 pin D-SUB
    Dimensions & Weight: 16.6" x 17.1" x 6.9" (W x H x D), 12.1 lbs
    Manufacturer's Warranty: 3 years warranty
    Model#: ETL2302022
    Item#: N82E16824009022
    Rating: Vote(s): 25 Review(s): 12
    O da Phillips é mais caro pq é 12ms.
    E acredito q seja o melhor. hehe
    Mas fora os 12ms, o q q eh melhor? Vi so q o angulo de visao eh maior do Philips, pq tipo, tem um monte de 17 polegadas q tem 16ms de resposta, mas alguns sao BEM mais caros, tipo um custa 299 dolares o outro 599!
    Alguem sabe pq? Tem mais alguma especificacao importante pra se ver?
    Membro Avatar de corvoO
    ñ c esaute joven
    Oct 2004
    qto menos o response time... melhor.. e menos borrada fica a imagem em jogos de movimento rapido...
    nesse caso em 12ms. ja fica igual tela normal..
    vai fundo q eh uma boa pedida....
    PHILIPS
    monitor lcd de 19 passa dos 5 mil reais , certo?
    MHz
    MHz está offline
    Originalmente enviada por SK8_hUgO
    aqui no brasil, comprado em loja de nome sim.
    O Philips é melhor, mas eu tô de olho nesse Acer
