    Ajuda ai, Qual destas Mobo Escolher??
    DFI "LANPARTY UT nF3 250Gb" NVIDIA nForce3 250GB Chipset Motherboard For AMD Socket 754 CPU
    Specifications:
    Supported CPU: AMD Athlon 64 processor
    Chipset: NVIDIA nForce3 250Gb
    RAM: 3x DIMM Supports DDR266/333/400 Max 3GB
    Slots: 1x AGP 8X/4X, 5x PCI
    Ports: 2x PS/2, 1x COM, 1x LPT, 8x USB2.0(Rear 4), 1xRJ45, 2x S/PDIF In/Out, Audio Ports
    IDE: 2x ATA 133 up to 4 Devices
    SATA/RAID: 2x SATA RAID with NVIDIA RAID 0,1,0+1,JBOD, 2x SATA by Marvell SATA PHY
    Onboard Audio: Realtek ALC850(8-Ch)
    Onboard LAN: Marvell 88E1111 GbE PHY
    Form Factor: ATX
    EPoX "EP-8KDA3+" nForce3 250Gb Chipset Motherboard for AMD Socket 754 CPU
    Specifications:
    Supported CPU: AMD Athlon64 Processors
    Chipset: nVIDIA nForce3 250Gb
    FSB: 800MHz (Hyper-Transport)
    RAM: 3x DIMM for DDR400/333/266 Max 3GB
    Slots: 1x AGP 8X/4X(1.5V), 6x PCI
    Ports: 2xPS/2,1xLPT,1xCOM,SPDIF Out,1xLAN,8xUSB2.0(Rear 4),Audio Ports
    Onboard Audio: Realtek ALC850 8-Channel Codec
    Onboard LAN: Gigabit Ethernet
    Onboard SATA/RAID: 2 by nForce3 250Gb, 4 by Sil3114 w/ RAID 0/1/10
    Form Factor: ATX
    GIGABYTE "GA-K8NS PRO" nForce3 250 Chipset Motherboard for AMD Socket 754 CPU
    Specifications:
    Supported CPU: AMD Athlon64 Processors(1600MHz System Bus)
    IDE: 2x ATA 133 by chipset, 2x ATA 133 w/ RAID0/1/0+1 JBOD by GigaRAID IT8212 up to 8 Devices
    Ports: 2xPS/2,1xLPT,2xCOM,1xLAN,8xUSB2.0(Rear 4),Audio Ports
    Onboard LAN: Marvell 8001 Gigabit Ethernet
    Onboard SATA/RAID: 2x SATA by chipset, RAID 0/1 JBOD; 2x SATA by Sil3512, RAID 0/1
    Onboard 1394: T.I. controller, 3 Ports
    Form Factor: ATX
    SOLTEK "SL-K8AN2E-GR" NVIDIA nForce3 250Gb Chipset Motherboard For AMD Socket 754 CPU
    Specifications:
    Supported CPU: AMD Athlon 64 Processor
    FSB: 800MHz Hyper Transport
    RAM: 2x DIMM Supports DDR266/333/400 Max 2GB
    Ports: 2x PS/2, 2x COM, 1x LPT, 8x USB2.0(Rear 4), 1xRJ45, Audio Ports
    IDE: 2x ATA 133 up to 4 Devices, 1x ATA 133 up to 2 Devices by Promise PDC20579
    SATA/RAID: 2x SATA RAID with 0,1,0+1 by nFORCE 3 250Gb, 2x SATA RAID with 0,1,1+0 by by Promise PDC20579
    Onboard Audio: 6-Channel AC'97 Audio
    Onboard LAN: 1000 BASE-T Ethernet
    Form Factor: ATX
    Grato pela ajuda.
    e gostaria de saber se todas estas mobos tem o HYPER TRANSPORT de 800MHZ???
    giga ou DFI... agora 754? pq n parte logo pra 939?
