    Sli pode ser ligados em placa-mãe normal com tinta condutiva!
    http://www.anandtech.com/cpuchipsets...oc.aspx?i=2322
    olhem isso =D
    se a dfi e msi lançarem essas placas, é só pegar um lapis e voilá, SLI REAL ao preço de Ultra!
    e tbm:
    The Gigabyte 3D1 is a single video card with two 6600GT GPUs. It will only work in x8/x8 (nVidia) SLI mode on a Gigabyte SLI board. However, we did find the 3D1 will operate in x16/x2 mode on both DFI boards with jumpers in "normal" position. We have added test results to our charts with both single 6600GT and x16/x2 dual video mode with the 3D1. The Gigabyte 3D1 provides the interesting possibility of a form of SLI performance on single x16-slot Ultra boards with the SLI mod.
    edit:
    The discovery that the Ultra chipset can be easily modded to SLI removes a major obstacle to SLI performance on the cheaper Ultra boards - if the manufacturer made provisions for SLI. Once the SLI mod is complete, the system and nVidia drivers see the chipset as a full SLI chipset. This removes the driver issues and the ability of nVidia to turn off support in "non-complying Ultra SLI chipsets".
    The DFI LANParty UT nF4 Ultra-D will sell for about $140. With the simple mod, it is a fully capable nF4 SLI motherboard. As you will see in our upcoming reviews, it is also one of the most enthusiast-friendly boards to land on the market since the DFI Socket 754 motherboard. For now, the only board that we know which can be fully converted from Ultra to SLI is this DFI LANParty UT, but there are others on the way, and we are sure it will not be the last. As new Ultra boards with dual-video capabilities arrive, we will let you know if they are up to the conversion task.
    Membro Avatar de corvoO
    ñ c esaute joven
    Oct 2004
    da mesma forma de fazendo a ligação das pontes num athlon XP liberava os mults,
    ligando essa ponte pintada numa Nforce4 Ultra faz ele virar uma Nforce4 SLI !!!
    Q LINDO !!
    ñ c esaute joven
    Oct 2004
    mto fera !!! a nvidia tomou no ** agora...
    pq?
    Membro Avatar de CoachCarter
    Vai vender Ultra para caralho e se dar mal???????
    Que nem a amd, com os mobiles, os XP1700 1.5v....
    Jun 2001
    Muito boa essa, mas que pena essa plaquinha da gigabyte não funcionar em 8x8 nessa DFI, mas bom temos que esperar sair a da asus dai talvez funcione na boa
    Apr 2000
    Postei isso a uns 2 dias e falaram q era old, mas voltando ao topico por enqt acho q soh a dfi q faz isso, pois soh ela que vi com slot pci express 2x...
    Membro Avatar de Mirage
    Gold member
    eh bem antigo sim
    jah tinha saido um teste antes
    ficava 8x4x
    fizeram testes com 8x2x tb
    ficava quase a mesma coisa
    a perda maxima foi de 10%
    isso com um chipset antigo, mas a nVidia vai bloquear isso nos proximos drivers =\
    mas usando o lapis vai dar para burlar isso
    Membro Avatar de Diablero
    Exorcista
    Não vai não, no caso especifico da DFI, qdo vc faz esse mod, a sua placa mãe passa a ser reconhecido como NF4-SLI , e isso vai burlar os drivers.
    Os drivers vão bloquear as outras"tecnologia sli, como da outra placa DFI e a da VIA.
    ja comprei minha sli mesmo uahuhauhahuahuahu
    tomei no ** auhuhauhahua que se foda auhuhauhahua
    Originalmente enviada por Jota Morane
    oq vc posto realmente era, le o review q vc vai entender do q eu tô falando.
