    Qual Memo?
    Kingston ValueRAM Dual Kits 184 Pin 512MB(256MBx2) DDR PC-3200
    Model# KVR400X64C3AK2/512
    Item # N82E16820141413
    Specifications:
    Manufacturer: Kingston
    Speed: DDR400(PC3200)
    Type: 184 Pin DDR SDRAM
    Error Checking: Non-ECC
    Registered/Unbuffered: Unbuffered
    Cas Latency: 3
    Support Voltage: 2.6V
    Bandwidth: 3.2GB/s
    Organization: two 32M x 64 -Bit
    Warranty: Lifetime
    OU
    Corsair XMS Extreme Memory Speed Series 184 Pin 512MB DDR PC-3200 - OEM
    Model# CMX512-3200C2
    Item # N82E16820145416
    Specifications:
    Manufacturer: Corsair
    Cas Latency: 2-3-3-6 1T
    Bandwidth: 3.2GB/s
    Organization: 64M x 64 -Bit
    Warranty: Lifetime
    Qual delas e melhor?
