Página 29 de 99 Primeira ... 19 27 28 29 30 31 39 79 ... Última
  1. #701
    DFI NF4 BETA BIOS 325
    DFI NF4 Beta Bios 325:
    Testado e postado pelo bigtoe da OCZ no forum da Xtremesystems.org
    http://homepage.ntlworld.com/a.leach80/NF4LD325.zip
    Mirror:
    http://www.fileshosts.com/DFI/NF4_SLI_D/bios/
    As mudanças feitas na Bios se referem à alguns problemas e limitações de "Drive Strenght".
    Seguem abaixo infos do Bigtoe referentes aos testes dele.
    In bios you have 2 options for drive strength, first off im going to address Dram Drive strength options Auto to 8.
    If you leave the option at Auto this will set a weak drive strength, this is good for TCCD based modules but bad for anything else. From testing and debugging the board i have concluded the following.
    Options 1 3 5 7 are all weak, as is Auto,setting 1 is actually the weakest option with 7 being as close to the normal weak setting DFI will allow us.
    Options 2 4 6 8 are the Normal settings, with 8 being the highest strength setting.
    If you are using TCCD you may want to try 3 5 or 7 as the drive settings as they usually seem to allow the modules to clock well.
    If you are using VX, or the new BH Gold, or any other modules from the OCZ range you may want to try 8 or 6.
    Im waiting for confirmation from DFI on this info, from my testing this does seem pretty accurate.
    You guys have to remember you can't use the settings you were using before, make sure you play with the following.
    TRC 8 works well
    TRFC
    Drive strength
    Idle cycle
    TRAS
    Retirado de http://www.xtremesystems.org/forums/...ad.php?t=57762
    Trident: Coloca na area de BIOS do seu site.
    [ ]´s
    O bios da Ultra-D e o mesmo da SLI-DR???
  4. #703
    Membro Avatar de BIGX333
    300mhz com mult 4x, em 1/1, aplica divisor 5(o menor do A64), e assim a memoria roda a 240mhz e não 300mhz...
    Boa tava com preguica de procura a forma pra calcula =X
  5. #704
    a forma é simples
    em 1/1 usa-se o divisor inteiro imediatamente superior ao multiplicador usado
    ex
    se usar mult 10.5, tipo 10.5x250 = 2625mhz 1/1(como o shaft usou), a controladora de memoria vai impor divisor 11 e nao 10.5, pq ela so tem divisores inteiros(9, 10, 11, etc..), ai o clock da memoria fica em 238mhz(10.5 x 250 = 2625mhz/11 = 238mhz), e não nos esperados 250mhz.
    Mas existem excessoes, como o mult 4, ja q o divisor minimo da controladora é 5 e não 4, então ela usa o divisor 5, reduzindo em muito o clock da memoria, como eu calculei ali em cima(300x4 = 1200mhz/5 = 240mhz).
    Ja usando divisores, existem mais alguns detalhes...
    Usando divisor 5/6 pra obter 166, a controladora vai aplicar um divisor para deixar o mais proximo possivel dos 166mhz, mas nunca em um clock acima de 166mhz... lembrando q isso é sobre um clock de referencia de 200mhz, ja q a controladora sempre tenta simular um divisor 5/6, e 5/6 de 200mhz é 166mhz...
    ex, se vc aplicar divisor 5/6 na bios(166mhz), em uma configuracao 200x11 = 2200mhz, ele vai usar divisor 14 pras memorias, gerando 157mhz nas memorias, e não o 13 q geraria o numero mais proximo 169mhz, porque 169mhz é maior do q 166mhz q é o q o divisor 5/6 indicaria... e assim vai
    no final das contas, o memory divider helper q o trident postou resolve tudo, mas é bom saber como funfa
    Aff...
    Vou ter q penar pra me adaptar
  7. #706
    Membro Avatar de Hade
    ae galera.....
    essas dfi nf4 ultra sli vale o preço.... ou é melhor pegar a sem sli e fazer a gabiarra??????
    e com relação aos 3200 939 eles são bons pra over???
  8. #707
    Eu diminui o mult a vera pra ver se a memo suportava uai
    Quando fui troca a BIOS na casa do meu amigo no RJ, deu um quebrada no socket da BIOS da mobo, sera que esse sera a motivo da BIOS nova que comprei da MoboFix n ter dado certo? Ou é o CPU
    olhem a SS abaixo...
  9. #708
    a forma é simples
    ex
    To viajando e nem sequer fumei um...que porra doida
  10. #709
    Alguns resultados com BH5, bom ate agora tudo normal, em relacao a asus e MSI neo2...
  11. #710
    Originalmente enviada por The Shaft
    creio q não... se tiver dando contato no socket, beleza.. eu mesmo ja mexi em varias mb's com esse socketzinho quebrado em um canto, é usual isso... falando nisso, bem q poderiam pensar em um socketzinho diferente, justamente pra evitar esse probleminha né... ainda acho q pode ter sido o CPU... vc nao viu nada de anormal na MB?
    belo clock na bh5, faw!
    qual o max q deu pra rodar um sandra? superpi?
    e ai, resolveu o problema do command rate?
    Acho que foi meu CPU que quebro
    De acordo com um amigo meu a mobo se acende as luzes (4 luzes vermelhas) e elas não se apagam é porque o cpu não foi detectado.
    Se for isso...até melhor sabe, tenho garantia de 3 anos e minha mobo mando concerta essa porra da socket da bios e pronto ^^
    rezem por mim seus kenguinha
  13. #712
    boa sorte ai
    vai que vc consegue um venice na troca! heuaIOaehE
    da proxima vez toma um poco mais de cuidado com a voltagem ai.. principalmente no ar!
    é oque eu to achando
    Mais de qualquer mobo vo manda pros caras da moboFix bota uma nova e fica tudo certinho não acha hehehehe ? ^^
    A mobo tá certinha...
    hehehehe
    Po OCZ malefica essa hiem hahahaha "A piranha voadora" lol
  15. #714
    ae galera....
    alguem me ajuda ae sou noob demais em amd...
    até agora so vejo rewius da DFI LANPARY NF4 COM SLI......
    tem alguma diferença de desempenho entre a que tem sli e a que nao tem??
    outra coisa... os 3,2 939 são bons pra over???
    ajuda ae galera please
  16. #715
    ae galera....
    olha, a diferenca entre a nf4 sli e a ultra-d é: um resistor no chipset, e alem disso, vem com o bridge pra SLi
    nao sei se tem mais acessorios, mas a MB é identica... desempenho igual.. mas se vc quizer SLi garantido, eh melhor ir na SLi mesmo. No resto, desempenho identico...
    quanto aos CPUs, é bom sim... oq muda mais eh stepping(CBBHD sao os q tem tido melhores results), mas isso é questionavel, depende um poco de sorte... eu esperaria pelos venice(lancamento 4 de abril), q acho q sao uma pedida melhor q esses winchester... outra boa saida é o 3500+ baseado no nucleo do FX-55(processo sSOI), mas eh dificil encontrar uma loja q o venda com essa informacao de ser o 3500+ baseado nesse nucleo... com o 3500+ sSOI e com os venice, da pra tentar tirar 2,7~2,8ghz no ar, pra uso diario... com um bom cooler...
    Wrobel n se esqueca q a ultra-d eh igual a sli-d e nao a sli-dr(ela tem acessorios a mais e mais alguns sata )
  18. #717
    mais o desempenho.... é o mesmo???
    aa.... nao tenho grana pra fazer sli mesmo.
    quero desemepnho... prefiro então pagar mais barato na mobo e melhor o processador é mais jogo. fora ainda que o frete é mais barato...
    tem certeza né??
    pra quem quer fazer um over bem extremo mesmo... qual processador amd64 v6 indicam...
    pensei nesse venice, mais eu nao manjo muito de amd...
    melhor perguntar
  19. #718
    280 Ta primer, mais a banda nao deu aquelas coisa, pq ainda nao configurei certinho as demais configs de memos, so to achando estanho as TCCD nao rodar direito, sera que posso usar o bios da Ultra D na SLI-DR?
  20. #719
    Pra tccd funfa bem na dfi tem q ser ninja... Configura direitinho e talz.
  21. #720
    E vc vai me ensinar né?
    Senão na próxima compra eu mando o abacate já podre
  22. #721
    tem certeza né??
    melhor perguntar
    o desempenho é o mesmo, como eu disse ali em cima... o layout da placa é identico, so muda algumas coisas como acessorios e bla bla bla.. mas o desmepenho é o mesmo
    fazer over bem extremo? q cooling vc vai usar? heh..
    olha, de qq forma, quem ta comprando agora, recomendo esperar um pouco vir os venice... ou san diego se for o caso...
    pro faw e pro povo q quer configurar direito as TCCD's, deem uma lida nesse topic aki, deve ajudar:
    http://www.xtremesystems.org/forums/...ad.php?t=57317
    leiam tb esse post do trident:
    http://forum.hardmob.uol.com.br/show...29#post4440729
    e esse do [Racer-X]
    http://forum.hardmob.uol.com.br/show...67#post4441567
    Membro Avatar de andrepmrj
    faw e ai entra a dfi e a asus o que voce esta achando, lebrando que eu nao sou tarado po over, pode ate rola um over mas pouca coisa mesmo ????????
    desempenho ente a dfi e a asus , quem esta melhor ?????
  24. #723
    Membro Avatar de Nietzsche
    Feb 1999
    duvida
    estou com uma dfi dessas e uma fonte 20p no caso uma antec 550w
    o que muda da 24p pra essa 20p? estou perdendo algo? estou deixando de ganhar algo?
    porque essa placa e 24p (junto com as s939) e as outras 20p?
    obrigado
  25. #724
    e esse do [Racer-X]
    Valeu fio vo da uma olha, cooler agora to usando WC, bombinha de 4200 Litros..radiar By mim, com 1,80 no core...maximo que vi primer foi 42... Tava pensando em colocar ativa mais to sem saco pra montar tudo, talves semana que vem. Sobre a diferenca pra Asus, pouka viu, a DFI e um saco pra configurar, a asus e so socar a TCCD e rodar, provavel que eu chege de 3gzh a 3,050 com ativa uns 150MHZ a mais com a DFI em relacao a ASUS. A DFI e uma puta placa o pacote dela tem tanta coisa, desde negocinho pra encapar os fios da fonte a malinha pra carregar o CASE pruma lan, mais se nao se importa com 100MHZ e poukinha banda a menos e esse acessorios..hehe, vai de ASUS A8n-SLI preco dela ta bao e so botar pra rodar..
  26. #725
    Gente, onde esta o multiplicador na bios da DFI????
    eu so to encontrando o FSB!!
    e tambem quando tento aumentar a voltagem da memo, ela nao muda, coloco de 2,6 para 2,8 e quando coloco 2,8 volta para 2,6, como faço para ficar no 2,8 mesmo?
    eu coloco 225 de FSB e ja fica instavel, o windows nao entra.
    Acho que tem alguma configuração da bios que nao sei o que é
