    Fone 5.1 da vcom. Presta?
    http://www.verycom.com.br/produtos/p...aspx?id=hp-680
    q vcs acham?
    ta um preco legal...
    Achei isso aki sobre ele:
    A number of unique products are offered by G-Star Industrial Co., Ltd. The company provides specialized headphones for OEM and ODM manufacturing. Among these headphones are a 5.1 Channel Headphone set and an Active Noise Cancellation Headphone set.
    G-Star has designed and produced three different 5.1 Headphones for OEM partners, and can offer many other variations upon request. The HP-600, HP-650, and HP-680 are all 5.1 Surround sound Headphones. These models offer real 5.1 sound from eight different drivers - 2 subwoofer drivers, and 2 center, rear, and front drivers each.
    The HP-600 series of 5.1 Surround sound Headphones have an internal decoder to provide surround sound from both DTS and Dolby Surround signals. These solutions require a PC with a DVD player, running either WinDVD or PowerDVD software to offer the surround sound performance. Connected to an external DVD player with an internal surround sound decoder also gives 5.1 channel output. However, if the external DVD player does not have a decoder, the unit plays back sound in 2-channel output.
    The HP-600 series also comes with a box unit. This box is a signal amplifier to provide louder sound. The box also has a "just one touch" functionality, allowing users to switch between headphones and normal speaker output. The box unit provides a power-on and a mute function as well.
    Membro Avatar de Repolho Roxo
    Tá quanto o preço?
    em torno de 150 reais
    Sei lá nunca usei um fone 5.1, mas deve prestar sim.
    to vendo aki.. tem 8 falantes essa porra um sub d 4cm... no site da gstar (www.gstar.com.tw) tem mais infos sobre ele
    Originalmente enviada por Neorider
    Deve ser bom mesmo.
    Membro Avatar de andrepmrj
    cara se ele mesmo ja tem amplificador, ja ajuda muito, ja que no zalman os canais de traz nao fican legais, so fica voce comprando o amplificador da zalman mesmo, esse ai deve ser bom sim..
    VCOM anda colocando a etiqueta dela em coisa boa ultimamente em?
    jr.
    Jun 2001
    tah,tb gostei,onde que compra?
    Originalmente enviada por NoShoot
    O TheLittle vende tudo da vcom, ele que me falo do fone, cabo de chegar na distribuidora.. semana que vem ele ta vendendo denovo.
    Ele me disse que vai vender em torno de 160 reais.
    igualzinho o meu, bom quase igual.
    é bom sim!
    esse é o meu,pelo design esse deve ser tipo uma versao mais nova, mas a especificações tecnicas sao quase iguais.
    Membro Avatar de DeatH
    GETTUDA CHOPPAH
    Dec 1999
    esse fone ai eh igual ao da genius,
    q nada mais eh q o fone 5.1 da gainward relabeled, com a diferenca de vir junto um ampli pra um conector G9, mas eu nao tenho certeza se esses fones vem com o rumbler q o gainward tem
    o que seria esse rumbler?
    é uma parada q faz o fone vibrar nos graves, na minha opinião uma merda.
    Jun 2001
    alguem pode postar os dados(msn ou ICQ) do TheLittle?
    Hmm interessante esse fone, mas e as frequencias de som?
    228117576
    e
    [email protected]
    WAT?
    228117576
    e
    [email protected]
    o zalman ainda é superior e o gainward tbm na parte das frequencias, mas vai comparar os valores, acho que o preço ta otimo, o mesmo preço que paguei no meu, só pra nao tem dor de cabeça com ampli de 300 conto do zalman
    Originalmente enviada por _Krapter_
    Po aki eh sussa, so saber regular... nao curto som muito alto mesmo ta belezinha
    no tempo que fui comprar zalman era 250 e esse meu 160 dai eu falei, vo comprar o zalman que é bem melhor, dai chego uns 5 caras falando que zalman é horivel sem amplificador, eu fiquei em panico e comprei esse aki, que tbm funciona bem, nao vejo mal em ter um produdo (*generico*).
    Caro não?
    Paguei 199R$ no meu Zalman to felizão
    Estranho, sobre o amplificador, ou eu sou fresco com ouvido ou nego eh surdo, pq mesmo com os traseiros bugados e o fone funcionando em 15% de seu potencial ja axo alto o suficiente e nao passo de 60% no volume
    opa epra la nao e bem assim, o fone nao tem bug algum, e problema vem das placas de som e nao do fone, que isso fique bem claro, o fone e muito bom sim. a merda dos condecs e que nao funcionan legal...
    se bem que nem to usando mais ele, ja que meu fica dirento em 5.1 nas caixas ahehahehehehhehe
