    Creative Inspire 5200 x Logitech Z-640
    Galera, to pra comprar um jogo de caixas 5.1.
    Qual vocês acham melhor dessas duas??
    Logitech Z-640 5.1
    Descrição do produto
    Heart-Pounding Home Theater Sound on a Budget
    Experience Dolby Digital sound for music, movies and games
    Included adapter provides instant connectivity to video game consoles
    Innovative, dual-chamber subwoofer delivers twice the bass energy of similar subwoofers
    Four stylish satellites stand on desk or mount on wall to provide smooth mid and high frequencies
    Center channel speaker with system controls rests on your monitor or your desk
    Magnetic shielding in speakers protects your equipment
    Internal power supply eliminates bulky wall adapters
    Two-year warranty
    Specifications
    Total output power: 71.2 Watts RMS
    Subwoofer power output: 25.7 Watts RMS
    Satellite speaker power output: 45.5 Watts RMS (2 x 7.3w front 2 x 7.3w rear 16.3w center)
    Total peak power: 140 Watts
    System frequency response: 35Hz - 20kHz
    Signal-to-noise ratio: >75 dB
    Input impedance: > 5,000 ohms
    Shielded satellites for use near video monitors
    System Requirements
    PC
    For 5.1 surround sound: any 4 or 6 channel sound card
    For Dolby Digital 5.1 sound: sound card or software DVD player with built-in Dolby Digital decoding
    Video game consoles
    A PlayStation®, PlayStation®2, Xbox™, or Nintendo GameCube™ using stereo RCA (red and white) audio cables
    TV
    TV with stereo RCA audio output jacks (stereo RCA cable not included)
    Creative Inspire 5200 5.1
    Specifications
    System 75 watts system power*
    Speakers Rated Power @ 10%: 6 Watts RMS per speaker (x 5 speakers)
    Signal-to-Noise Ratio: 75 dB (typical)
    Subwoofer Rated Power @ 10%: 17 Watts RMS
    Overall Frequency Response: 40Hz to 20kHz
    Cables Front Left/Right Speaker (permanent connection): 2m / 6.5ft (RCA Black plug)
    Rear Left/Right & Center Speaker (permanent connection): 4m / 13.1ft (RCA Black plug)
    Triple stereo line-in audio: 2m / 6.5ft (Gold - plated)
    Volume Control: 2m / 6.5ft (Color - Black)
    Sockets (refer to the Back Panel of the Subwoofer) Audio Inputs: 3.5mm stereo mini jack
    Front: Lime Pantone 577C
    Rear: Black
    Center/Subwoofer: Orange Pantone 157C
    Speaker Out: RCA jack
    F/L & R/L: White
    F/R & R/R: Red
    Center: Black
    Volume Control: DIN
    Power Adapter Output: 12 V AC/ 4.2A
    Adapter Cable Length: 12 ft / 3.7m (Overall Length)
    Type: In-line type (Color - Black)
    O som será usado para MP3... Fazer um som ambiente no quarto ou na sala...
    Membro Avatar de Peleyer
    Guarda um pouco a grana e pega a Z-5300 que vale bem mais que qualquer uma dessas duas...
    Originalmente enviada por Peleyer
    qual é a faixa de preço dessa?
    Originalmente enviada por K1RK
    680-690, mas com o frete fica um pouco mais caro.
    Z-640
    mas isso é mais que o dobro já velho... não quero gastar tudo isso... =/
    Bah, entao fica com a Z-640 mesmo... :[
    Membro Avatar de Tcool
    Jan 2001
    Z640... comprei e com certeza estou curtindo... fidelidade exelente ao som e pode ser encontrada por um preco legal...
    Originalmente enviada por Tcool
    E quanto a potência? Pra usar em um quarto, ou numa sala, vai tranquilo sem chiar?
    obs: tu compro em POA? se sim, pagou quanto e onde?
