    MSI NEO4 ULTRA /SLI manual diz que precisa de duas +12V com 18A, verdade ?
    quase certo que vou comprar uma mobo msi neo4 ultra, tava dando uma olhada no manual na net, e ta escrito assim:
    MSI Reminds You...
    1. These two connectors connect to the ATX power supply and have to
    work together to ensure stable operation of the mainboard.
    2. Power supply of 450 watts (and above) is highly recommended for
    system stability.
    3. For ATX 12V power connection, it should be greater than 18A.
    4. For this model, you must use the power supply that with a -5V pin
    supply.
    negocio e que eu fechei negocio numa Seventeam ST-420BKV ATX2.0v. Essa Seventeam tem duas linhas +12V com 16A.
    Vai aguentar ???
