    Membro Avatar de Sherman
    Probleminhas:ASPIENUM.vxd onde consigo esse arkivo?
    seguinte meu primo tem o win98 tá com esse problema,precisa desse arkivo...Alguem sabe onde pego?alguem pode me mandar?
    Abraçao valeu
    Baixa o arquivo:
    http://www.chickensys.com/bin/aspi.zip
    e faça o seguinte:
    # Extract winaspi.dll, wnaspi32.dll, and aspienum.vxd into your system directory.
    # Extract sparrow.mpd and apix.vxd into your iosubsys directory in your system directory.
    # These are the original Windows95/98/ME distribution files - this is to get you back to installed Windows status
    # Extract and run aspi32.exe, this will update the files to 4.06 (1021) status
    # Extract and run aspichk.exe, this will help you see if all the files are matched and are the correct versions.
    e pronto.
    [ ]´s
