    Membro Avatar de corvoO
    ñ c esaute joven
    Oct 2004
    SLI em 2 vga...... SEM BRIDGE !!!! ... NO P4...novo brinquedo da MSI.
    BOAS NOTICIAS P DONOS DE VGA's PCI-E
    The P4N Diamond features a world-first digital SLI connection. The four current NForce 4 SLI motherboards that are available on the AMD platform, along with several unreleased motherboards that we have seen here at CeBit feature a 'bridged' solution for changing the mode that the two PCI-Express x16 slots operate in. DFI used a large batch of jumpers on their nF4 SLI series of motherboards, while the other three AMD solutions from ASUS, Gigabyte and MSI all use a switchable 'card' that changes the PCI-Express lane configuration.
    MSI's latest P4N Diamond motherboard controlls this configuration via a digital connection that is all handled by the motherboard's BIOS - there is no user interaction required at all. Depending on whether the motherboard has one or two video cards connected determines which mode the PCI-Express lanes operate in. This means that if one video card is installed in the system, the slot is given a full allocation of an x16 lane; when two video cards are installed, the BIOS automatically allocates each x16 slot with the equivalent bandwidth to a PCI-Express x8 slot, allowing for SLI to be set up with minimal user configuration.
    The great thing about this is that you can interchange from a single card to a dual video card configuration without having to change any 'hard' settings on the board itself - this SLI solution is completely 'jumperless', so to speak. Unfortunately, we could not get pictures of the actual layout of the PCB, as MSI have covered the section of the motherboard over with a sticker for the time being. However, we understand that there are two parallel rows of IC's underneath the sticker that control the PCI-Express lane configuration. We understand that MSI are awaiting a patent for the technology before revealing what is underneath the sticker in between the two PCI-Express lanes.
    We'll leave you with a few pictures - you can just about see the start of the two rows of IC's at the I/O end of the PCI-Express slots.
    MANEIRO !!!
    tradução porca e muito resumida.. a MSI tah fazendo um serie de mobos novas "P4N diamond", que não precisam do BRIDGE p fazer SLI entre as placas...
    o SLI será controlado digitalmente pela BIOS, que ira detectar se tem 1 ou 2 vga plugadas e configura de acordo.
    DETALHE: P/ P4 LGA 775... quem falo q eram ruins ??
    bom, eu nao tinha visto essa noticia, mas pelo q eu li ai, apenas setar o sistema como SLI, nao precisara mover jumpers e nem daquele acessorio pra deixar os dois slots com 8x lanes no PCI-E, é tudo via bios.. não disse q elimina a necessidade do bridge... precisar ou nao do bridge é uma coisa, setar SLI via bios é outra...
    ñ c esaute joven
    Oct 2004
    mais uma
    Nada d+, so assim a Nvidia/Fabricantes passem a "dar" o bridge...
    estão cobrando um caminhão de dolares pelo bridge
    **Edit** Pq diabos ainda querem fazer mobos cor de merda? puta coisa feia!!!
    Membro Avatar de Repolho Roxo
    A MSI pegou essa mania da azoz...
    É a mesma coisa que a Asus A8N-SLI Premium.
    A bridge continua, duh, dãh... só não tem aquele 'card' pra selecionar SLI ou single.
    fui
    Membro Avatar de §APØ
    Nem sei koe dessa tal de bridge
    Alguem pode expricar resumidamente em uma linha de texto?
    Membro Avatar de Bolovo
    Especialista em TUDO
    Originalmente enviada por §APØ
    3 Imagens valem mais que 1 linha :P
    O mais forte do universo!
    legal mas.....
    pra que pentium 4?
    to muitissimo bem servido com Athlon64 e FX...... pra GAMES nao tem pra ninguem......
    Originalmente enviada por RetardadoMental
    legal mas.....
    pra que pentium 4?
    Conhece os leigos?
    Conhece os leigos?
    90% dos consumidores??????? aeh..... esqueci deles...
    Membro Avatar de TM99
    Originalmente enviada por Alan[B!]
    nao eh isso
    oq eles tao falando la eh daquela parada de ter que trocar um chip de posição entre os 2 slots pcie pra vga pra mudar de 1-16x pra 2 - 8x
    [inveja on]
    bom, to felississimo com a noticia. ainda bem q vcs podem comprar 2 dessas vgas e nao precisam mais se preocupar em ficar setando brigde e o escambau. nois os outros 95% vamos continuar com as 5200~5600 da vida hueuheu
    [inveja off]
    nao eh isso
    isso ae.. aquela plaquinha que fica no meio do PCIE.
    O bridge e obrigatorio pra VGAs nvidia rodar corretamente, ja que e preciso comunicar entre elas, quando o usei o SLI tinha uma opcao do driver que mostrava a divisao de carga entre as VGas, a tela e dividida no meio na horizontal, cada VGA toma conta de uma banda da tela. O bridge deve servir pra isso pra cada uma saber o que fz...
    Pessoal, não é com ausência de VGA BRIDGE(que liga as duas vgas) e sim do SLI CARD(no meio dos dois Pci-E) que ela funciona...
    Por que nos SLI's normais tem o SLI CARD que o usuário na hora que fizer SLI tem que colocar como SLI ATIVADO e quando não vai ele tem que colocar como NORMAL.
    Essa placa detecta automaticamente isso, se o SLI está ativado ou não, não necessitando do SLI CARD.
    Simples Assim.
    Membro Avatar de NIex
    apl525 here
    Asus A8N-SLI Premium Allows SLI to be Enabled in Software
    http://www20.tomshardware.com/mother...323/index.html
