    update BIOs K7S8X-E Alguem jah fez ou sabe como fazer? [Help]
    fala gente boa...
    qro atualiza minha bios aki....
    jah baixei a ultima versao da bios, veio zipada com dois arquivos: ASRFLASH e K7S8XE_2.20 ...
    agora como fasso? passo pro disket zipada msm ?e do boot pelo disket?
    agora nao sei mais !
    pra nao faze burrada resolvi Pergunta !!
    VLw ...
    Leo
    Aproveitando o topic , o q eh Spread Spectrum? e Over Vcore Voltage? os dois estao DISABLE na bios ? pra q serve eeles??
    AJUDA AEEEEEEE
    up
    Como vc baixou a bios, vc tb poderia ter lido as instruções, ne?
    http://www.asrock.com/support/index_BIOS_INS.htm
    1) Create a bootable system floppy disk.
    2) Download an updated ASRock BIOS file (WinZip format with .zip file extension) from the web site, unzip the BIOS file and save both ASRFLASH.EXE utility and BIOS file to the disk you created in step 1.
    3) Boot from the disk you created in step 2.
    4) At the "A:\" prompt, type ASRFLASH, hit space bar once, and type BIOS file name then press <Enter>. For example: A:\ASRFLASH K7S41GX2.00 <Enter> then you will see a message "Please wait for BIOS loading ROM".
    5) After 30 seconds, you will see the message "Flash ROM Update Completed - Pass", then you have finished upgrading the BIOS.
    6) After finishing upgrading the BIOS, please remove the floppy disk. Restart your system and press <F2> to enter the BIOS setup utility during boot up.
    7) In Exit menu, please select "Load Default Settings" and press <Enter> to continue.
    8) Select "Exit Saving Changes" and press <Enter> to exit the BIOS setup utility.
    9) Now, system is booting up with new BIOS.
    Edit: Spread Spectrum eu nunca soube o q é. Ja o Over vcore dá um aumento de 5% do vcore padrao do seu cpu. Ai vc pergunta. É estável esse aumento de vcore? Bom, aqui foi. Qdo eu tinha essa placa, eu fiz esse aumento pra botar 200 de fsb no meu xp1700 (133) e ficou perfeito.
