Página 1 de 4 1 2 3 ... Última
    Membro Avatar de -|SLayerR|-
    XBOX 360: Triple-Core 3.2GHz + ATi R5xx GPU + 512Mb GDDR3 + all wireless!
    É... depois que passou na MTV ta chovendo em tudo que é canto essa notícia. XBOX 360, o sucessor do XBOX lançado, e dessa vez promete por os Videogames na frente na eterna guerra VG x xPC.
    As especificações são monstras:
    Xbox 360 Specs:
    CPU
    3 symmetrical cores running at 3.2 GHz each
    2 hardware threads per core; 6 threads total
    1 VMX-128 vector unit per core; 3 total
    128 VMX-128 registers per hardware thread
    1MB L2 Cache
    9 billion dot product operations per second
    Custom ATI GPU:
    500 MHz Clock Speed
    10 MB embedded DRAM
    48-way parallel floating-point dynamically-scheduled shader pipelines
    Unified shader architecture
    500 million triangles per second polygon performance
    16 gigasamples per second pixel fillrate using 4X MSAA
    48 billion shader operations per second
    Memory:
    512 MB GDDR3 RAM
    700 MHz DDR
    Unified memory architecture
    22.4 GB/s memory interface bus bandwidth
    256 GB/s memory bandwidth to EDRAM
    21.6 GB/s front-side bus
    Overall System Floating-Point Performance:
    1 TFLOP
    Ainda conta com HD d 20Gb, controles Wireless e outras coisas.
    Aki review da Vodoo Extreme detalhando o Hardware: http://ve3d.ign.com/articles/613/613...0&RSSid=613247
    Confiram aki entrevista com um doido da Microsoft explicando o hardware: http://xbox.gamespy.com/xbox-360/per.../613063p1.html
    Mais reportagens sobre o poderoso Hardware do Xbox 360:
    http://www.anandtech.com/video/showdoc.aspx?i=2414
    http://features.teamxbox.com/xbox/11...e-Xbox-360/p1/
    Foda hein! Quero soh ver o preço huahauhauaua
    BOMsoMITO 2018!
    Uia ^^
    + assustador q os Specs é esse video
    http://www.fileplanet.com/dl.aspx?/p...er_mtv_gow.avi
    PQP !
    Re: Uia ^^
    PQP !
    Tem vídeo ateh do Quake IV!!
    Aki tem vários:
    http://ve3d.ign.com/articles/613/613562p1.html
    Re: Uia ^^
    PQP !
    Not logged in? Don't have a GameSpy ID?
    Signing up with GameSpy is EASY, and lets you download from FilePlanet's public servers for FREE.
    It's also good for lots of other stuff:
    FilePlanet: Get access to 200,000+ game downloads
    GameSpy Arcade: Play your favorite games online, find new games to play, and find your friends or other gamers online with .
    ForumPlanet: Post in GameSpy's game discussion forums at
    Click here to create a GameSpy ID account!
    rapidshare alguem?
    Re: Re: Uia ^^
    Originalmente enviada por #Spidey#
    rapidshare alguem?
    gamespy/fileplanet e esse cadastro de merda ....
    BOMsoMITO 2018!
    Re: Re: Re: Uia ^^
    Originalmente enviada por Deco Rj
    Vale a pena !
    Re: Re: Re: Re: Uia ^^
    Vale a pena !
    po ja catei em outro lugar, pekeno demais o video.
    sei la, achei meio esquisito..nao gostei nao.
    to baixando um novo do stalker, pra ver se anima
    hhaouiHEoiuahuoiPEhOIPEU um monstro em forma de console... eu acho q esse console supera um pc hein??
    Eh so ligar num monitor ehehe... TV = BOSTA
    O vídeo do QIV tem 1.4mb e é um belo **.
    Tem seçao de console pra q?
    Topico oficial do xbox 360 E3
    http://forum.hardmob.uol.com.br/show...hreadid=363714
    Nov 1999
    Quando chiparem ele vai ficar muito interessante
    BOMsoMITO 2018!
    Uia ^^
    Originalmente enviada por dk.savage
    Meu primo perguntando :
    - Sera q vai dar pra chipar sem fio tb ?
    AJKEaEOAejaEOAkeaEOAkeae
    Membro Avatar de TMFX
    Re: XBOX 360: Triple-Core 3.2GHz + ATi R5xx GPU + 512Mb GDDR3 + all wireless!
    Put, mas ficou feio né? Podiam fazer preto também =/
    Membro Avatar de Arraso
    Apr 1999
    O hardware atual do PC pode fazer coisa melhor. Mas aí todos reclamam se não fazem jogos pra rodar numa GF4 MX
    nem o Pc mais foda com 2 Gf6800 ultra e o quanto d ram vc kiser ....
    arquitetura dedicada r0x
    Membro Avatar de NIex
    apl525 here
    Alguem poe o video no rapidshare ou me empresta um login
    EDIT:
    FILEPLANET TOSKO, FIZ LOGIN E BAIXEI UM VIDEO, AGORA PARA OS OUTROS ELE QUER INSTALAR ACTIVEX CONTROL, PQP, ME POUPE NEH
    Aff e eu achava o rapidshare lixo..
    This public server is full.
    BTW.
    Tava lendo este artigo, tem bastante coisa sobre ele..
    http://features.teamxbox.com/xbox/11...-Dissected/p1/
    Microsoft has designed a liquid cooling system that dynamically adjusts the flow of the liquid and the speed of the fans depending on the temperature and power consumption.
    uia ^^
    E tem esses video tb.
    http://movies.teamxbox.com/xbox360/thecolony_v1.wmv
    http://movies.teamxbox.com/xbox/xbox360_mtvteaser.wmv
    Direct link rlz.
    Originalmente enviada por Guitar Hero
    Ai que ja se engana isso era nos consoles atuais que usavam hardwares diferentes nesta nova geraçao alem de usar pratimente peças de pc sao "multifuncionais" justamente como um pc, os pcs estao cada vez se otimizando especificadamente para 3d e jogos enquanto os vg estao se otimizando para fazerem algumas coisas que os pc fazem, se o x360 nao vier com um windows dentro nao digo nada.
    Agora bom vai ser o preço pq o x360 mesmo custando 500 a 700 dolares acho que vai estar dentro do preço pela qualidade do hardware, eu ia fazer um up no pc para A64 mas acho que vou guardar um dinheiro para comprar um VG e deixar o pc mais para trabalho mesmo, se continuar assim os VG vao acabar com o pc pelo preço.
    Isso aí humilha qualquer PC atual, por longa distância.
    Qual PC atual tem banda de memória > 20 Gb/s?
    Algum processador pra PC pode executar 6 threads simultaneamente?
    A banda de memória do sistema, compartilhada, será metade da banda da R520/G70... porém pra compensar reparem que a VGA tem integrada esses 10Mb de Edram, com a 'pequena' banda de 256 Gb/s.
    Tá bom, na época do lançamento vc pode até ter duas G70 ou duas R520 que terão um poder maior, mas as CPUs e a banda do sistema não vão ter chegado nem perto...
    mesmo que o PS3 seja 3 ou 10 vezes mais rápido, esse hardware aí vai dar para os desenvolvedores brincarem sem reclamar por um bom tempo até atingirem sua capacidade máxima
    show d+
    flw
    Uma coisa que esqueci de perguntar esse GPU do X360 nao vai ter SM 3.0?
    Po, neguinho acredita em tudo que sai na net.
    Sinceramente tenho quase certeza que é fake essas especificações.
    Originalmente enviada por Pacote-San
    Apesar de estar certo, Attention whore?
    pow, vg ta voltando a ser mais interessante pra mim.
    antes só pc tinha modo online.
    agora vgs tão se tornando "multimedia tmb". sem contar que é totalmente plug&play, inumeros títulos e softhouse, e é só sentar no sofa e relaxar. ainda mais que se paga muito menos num vg do que num PC TOP p/ jogos q não vai chegar nem na metade do poder do X360.
    não vou upar meu pc nunca mais pelo visto, só vou deixar ele pra assistir filmes/mp3/net.
    po tenho q discordar ...
    Tv grande eh muito show pra jogar..Fps e jogos de corrida entao pqp...fica bem legal.
    a fuidez da tv + o tamanho da imagem da muito mais imersao, se vc tem home 5.1 bom entao, eh apagar a luz da sala e viajar.
    esse console foi o primeiro q eu tive um poco de vontade de comprar..primeiro pelo power, segundo pq cansei de esperar jogo de pc. mas o preco dese coisa ae deve ser bem salgado e o uso limitado a jogos de console.
    ae entao ainda prefiro uma boa Vga com video out.
    esse console eh apenas um bom pc daki a 6 meses, so q em comparacao com os p4 caketicos atuais e os a64 single core realmente eh melhor.
    quando fizerem jogos orientados pra dual-core e 64 bits (como o port do farcy por ex.) o pc deve voltar a lideranca absoluta.
    eu quero ver msm eh o tao do Cell, da sony. A arquitetura da coisa bota esse xbox no chinelo, o Cell eh tao poderoso q vai poder simplesmente EMULAR um bom pc
    outro dia eu ate ri sozinho quando li mais ou menos o seguinte:
    "como o Cell vai fazer pra competir com a enorme quantidade de programas feitas pra plataforma pc/x86?"
    Bom, o ideal seria programacao dedicada, mas como sabemos q isso demora pra ter volume, o Cell simplesmente emularia um processador x86"
    tipo..o treco eh tao fora de escala q emula um p4 4ghz numa boa...ueuheuhehu
    Originalmente enviada por *Slicer2k*
    Ja tem muita gente que usa xbox para assistir filmes/escutar mp3/postar em foruns.
