    Gargalo em maquina boa!!!??
    um amigo meu comprouuma maquina bem cara... mas que nao ta rendendo nem 20% do que devia...
    athlon 64 3200+ (2200mhz)
    MSI K8MM
    1024 DDR 400
    SANSUNG 120G 7200RPM
    DVDRW LG GSA-4163B
    E A PARTE RUIM... PLACA VIDEO ONBOARD VIA/S3 UNICHROME PRO
    CARA... ATE PARA MOVER UMA JANELA DO WQINDOWS ELE TA EMPANCANDO.. MAS INICIA RAPIDAO E EM OPERACOES QUE NAO geram imagem tb e normal...
    so quero uma confirmaçao de que esse video onboard dessa placa e um lixo ( se nao a placa toda)
    Driver de vídeo do windows, ou mal instalado da isso...
    manda o kra instalar o driver de vídeo corretamente q deve ficar 100%
    isso ja foi feito...
    cara... isso ja foi feito.. peguei o drive mais novo.. e continua na mesma... essa placa onboard so aceita 64mb no maximo (config pelo bios)..
    alguma luz?
    The IGP is a 128-bit graphics engine with a dual pixel pipeline and is clocked at 200MHz. Being an integrated graphics solution, it supports a shared memory frame buffer of up to 64MB. The UniChrome Pro can deliver up to 4.5 million triangles per second and has a fill rate of up to 400 million texels/sec. Not really impressive considering even entry-level discrete graphics cards today are capable of reaching a billion texels/sec fill rate. This comes as no surprise though, and users should already be familiar with the extreme limitations of most IGP's 3D performance.
    olha so.. acho que isso responde...
    a placa de video fede...
    The major feature of the K8M800 chipset is the UniChrome Pro IGP, which is also its major weakness. The performance of the chip was abysmal. Imagine running the state of the art Athlon 64 processor, and not being able to achieve a borderline 30fps in an older game like Jedi Knight II at 800x600. Unreal Tournament 2003 was not even able to execute. As evident from our tests, the IGP is not suited for all forms of 3D work or gaming. Simply inserting an external AGP graphics card brings the performance back on par with most discrete Athlon 64 based solutions. However, why would anyone purchase an IGP solution if they have decided to use a discrete graphics card in the first place?
    Re: isso ja foi feito...
    Originalmente enviada por MokuMoku
    alguma luz?
    isso ai ta com cara de problema nos drivers mesmo
    mesmo com IGP, eh pra ta rapido, soh em jogo q, obviamente, vai ser um lixo, pois o gpu é bem fraco... e nao eh a quantidade de memoria shared com o video q vai fazer a diferença...
    pode ser problema nos drivers agp... veja se o AGP accel ta ativado no dxdiag!
    edit:
    a placa de video realmente fede, mas nao eh por isso q ta lento no windows... eh algum problema nos drivers...
    ....continua
    olha... o comp e para trabalhar com modelagem 3d.. o cara comprou achando que fosse uma daquelas placas mae com gforce onboard... gato por lebre... vendedora meteu labia em quem nao entende da nisso...
    vou comprar uma placa video mesmo ...
    mas realmente colocar o dx9 mais novo melhorasse um pouco...
    nao e a windows que ta lenta.. sao os programas que puxam a placa (autocad e 3dmax)
    Re: ....continua
    Há quantos dias que ele comprou o micro? Tem acho que uma semana para devolver e receber o dinheiro de volta segundo o código do consumidor.
    muita ingenuidade achar que video onboard ia rodar autocad/3dmax satisfatoriamente...
    isso e o que da nao consultar um adviser...
    serio.. eu com a grana que ele pagou pegava um processador 300 pau mais barato.. encontrava umas lojas com precos bons.. e mandava vim uma placa de video top... ~e um cooler que preste.. metia over e priu...)
