    Membro Avatar de LostOne
    Qual memoria comprar?
    Qual seria a melhor opção pra rodar DFI NF4 Ultra-D / Venice 3000+ e tentar colocar 280 x 9 (por aih).
    1) 2 x US$ 106 Crucial Ballistix:
    Crucial 512MB DDR Ballistix PC-3200 w/ Aluminum Heat Spreaders - Model BL6464Z402, DDR400(PC3200), 184 Pin DDR SDRAM, Non-ECC, Unbuffered, Cas Latency: 2-2-2-6, Support Voltage: 2.8V, Organization: 64M x 64Bit.
    Lifetime warranty.
    2) 1 x US$ 235 Corsair XMS:
    CORSAIR MEMORY XMS Extreme Memory Speed Series, (Twin Pack) 1GB (2 x 512MB) TWINX1024-3200XL Xtra-Low Latency Matched Pair, CAS Latency: 2-2-2-5, 184pin DDR NON-ECC, 2.75V, Bandwidth: 3.2GB/s, 2x64M x 64 -Bit, Plug-n-FragTM Auto-Configuration.
    Lifetime Warranty.
    3) 1 x US$ 249 Geil Ultra X:
    Geil 1GB (512MBx2) Ultra-X Series Dual Channel 184 Pin DDR PC-3200 w/ Platinum Copper Heatspreader - Model GLX1GB3200UPDC, DDR400, Non-ECC, Unbuffered, Cas Latency: 2 5-2-2, TSOP 32x8 DDR Chips, 6 Layers Ultra Low Noises Shielded PCB with Gold 30u" Plating, Temperature thermometers, Optimized SPD for Dual Channel DDR motherboards.
    Lifetime Warranty.
    4) 1 x US$ 249 Kingston Ultra LL
    Kingston KHX3200ULK2/1G 1024MB KIT ULTRA LOW LATENCY DDR400 PC3200 Memory - 2x512Mb CL2, 2-2-2-5-1 400Mhz, Organization: 2x64M x 64Bit. Recommended for dual channel motherboards -
    Lifetime Warranty
    Membro Avatar de Diablero
    Exorcista
    geil ou corsair, (dessas que vc colocou).
    Algum motivo em especial? São todas TCCD ? Pq não as Crucial Ballistix se elas são mais baratas?
    Membro Avatar de S0ulR£aver
    a HyperX Ultra-LL é TCCD em PCB certificado pela JEDEC
    = ou seja, não é a melhor TCCD que vc pode comprar
    a Geil Ultra-X as novas não estão vindo com TCCD, e sim Winbond UTT
    Se vc quiser TCDD com PCB brainpower, tem essas duas opções legais:
    $208.00
    pqi TURBO 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 500 (PC 4000) Unbuffered Samsung TCCD Dual Channel Kit System Memory Model PQI4000-1024DPL - Retail
    http://www.newegg.com/Product/Produc...82E16820141138
    $245.00
    pqi TURBO 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Samsung TCCD Dual Channel Kit System Memory Model PQI3200-1024DBU - Retail
    http://www.newegg.com/Product/Produc...82E16820141194
    Parece que a razão da PC3200 ser mais cara que a PC4000 da PQI é que os chips TCCD da 3200 são mais "filé"
    Originalmente enviada por S0ulR£aver
    $208.00
    $245.00
    Foda que pra cotar isso aih na A1 vai subir beeem o preço...
    Aquele preço que eu postei eram das memorias que tem lá... E a Corsair XMS lá?
    please heeeelp!
