    Membro Avatar de -|SLayerR|-
    A verdade por trás da CPU do Xbox360 e do PS3!!
    A AnandTech fez um artigo interessante comparando o real poder das CPUs do XBOX360 (Xenon) e do PS3 (Cell). O resultado é revelador! Apesar dos números essas CPUs ficam ATRÁS de um Pentium 4 ou Athlon 64.
    Logo vê se que o que eles tem de bom mesmo é o GPU. E que os PCs vão continuar na frente dos VGs
    Link: http://groups-beta.google.com/group/...6ea78ea9?hl=en
    Vejam alguns trechos:
    "Right now, from what we've heard, the real-world performance of the Xenon CPU is about twice that of the 733MHz processor in the first Xbox. Considering that this CPU is supposed to power the Xbox 360 for the next 4 - 5 years, it's nothing short of disappointing. To put it in perspective, floating point multiplies are apparently 1/3 as fast on Xenon as on a Pentium 4.
    The reason for the poor performance? The very narrow 2-issue in-order core also happens to be very deeply pipelined, apparently with a branch predictor that's not the best in the business. In the end, you get what you pay for, and with such a small core, it's no surprise that performance isn't anywhere near the Athlon 64 or Pentium 4 class."
    The most ironic bit of it all is that according to developers, if either manufacturer had decided to use an Athlon 64 or a Pentium D in their next-gen console, they would be significantly ahead of the competition in terms of CPU performance.
    The Cell processor is no different; given that its PPE is identical to one of the PowerPC cores in Xenon, it must derive its floating point performance superiority from its array of SPEs. So what's the issue with 218 GFLOPs number (2 TFLOPs for the whole system)? Well, from what we've heard, game developers are finding that they can't use the SPEs for a lot of tasks. So in the end, it doesn't matter what peak theoretical performance of Cell's SPE array is, if those SPEs aren't being used all the time."
    pra mim nao eh novidade
    Email inválido
    só tem um detalhe....no console vc não tem que fazer upgrade e todos os jogos rodam no máximo e iguais
    Originalmente enviada por Decio_Piccinini
    no maximo do console, o q varia de console p/ console e normalmente é pior q no pc
    UmK
    UmK está offline
    foi a primeira coisa q pensei qdo apareceu pela primeira vez esses consoles. de onde q ia surgir do nada uns monstro fuderosos assim e barato ainda? eu sabia q era tudo balela
    anyway, ainda são fortes o suficiente pra rodar unreal3, entao nao tao tao mal assim
    so que hj em dia a relação ta que os vgs tem gpus melhores que as atuais 7800 gtx e tem processamento de sobra e plataforma dedicada
    Sinceramente com o preço e velocidade que estao saindo as peças de pc para mim ficou inviavel a cada 6 meses tem coisa nova nao da logo o pc morre para jogo pq nem os americanos tem tanto dinheiro para bancar upgrade a cada 6 meses eu ja parei vou ficar com meu pc do jeito que esta so vou pegar uma fonte nova, gravador dvd e talvez mais 512 de memo mais que isso never vou de ps3 ou x360 para jogos mesmo.
    Em 640 e 60fps até eu faço gráficos decentes Quero ver agora com 720 e 1080...
    Originalmente enviada por geleiatk
    Tem esse lado, por outro lado essas porkeras não rodam com filtros de imagem e são feitas para fikarem 4 - 5 anos no mercado, ou seja, uma hora vai gargalar bonito!
    Originalmente enviada por Alvinho
    por acaso serão esses 2 padrões dos Vgs
    sim uma hora vai gargalar + pensa kra
    qnd o ps2 saiu o melhor que tinhamos eram pcs com 750 mhz no maximo com geforce 2 GTS
    ele era mtooooo inferior e vc viu o que ele fazia ?
    o lance eh que eles colokaram uma parada cavala pra fikar mesmo mto tempo no mercado
    e otra pela diferença vc pode ver que eles vão ser equivalentes ao que vai sair ano que vem pra pcs então veja bem a relação ?
    Mesma merda de sempre, porra otimizada so pra um fim e consegue ser pior...
    Video Gayme sux!
    Video Gayme sux!
    pior ?
    roda underground num pc com 200 mhz no cpu e uma gpu tosca com uma vga de 4 mb
    edit: e com 32 mb d ram
    pior ?
    vc nao quer comparar o PS2, cpu risc 128bit + GPU com poder de processamento proximo ao de uma GF3, com um pentium 200mhz MMX de qse 1 decada atras, neh?
    Se for pra comparar dessa forma, seria completamente normal entao comparar tb A64 2.4ghz x P4C 2.4Ghz... wow...
    ai q ta wrobel, o pika ta pensando assim ....
    Aí ta uma relação bem desequilibrada. No começo de 1999 tinhamos PCs 600-650MHz mas até o final do mesmo ano e começo de 2000 já começavam a surgir os Athlon 1GHz. O PS2 só surgiu depois disso, no começo talvez na frente do PC mas até quando durou?
    Um VG é feito para durar 3 - 5 anos, colocam um hardware X, imutável e ponto. Já nos PCs a história é diferente, o avanço é exponencial, 3-5 anos dita MUITA coisa, ainda mais relativo a performance.
    Como mencionado no artigo o Xbox360 tem o dobro de poder do primeiro Xbox, vc acha que uma coisa dessas se manterá na frente dos PCs por 3 - 5 anos? Certamente que não, muito possivelmente os PCs JÁ ganham deles de lavada e, se por acaso, eles ainda tiverem algo de melhor, com certeza isso estará superado até a data de lançamento dos respectivos consoles.
    Agora entrando na questão do preço, mesmo com a desvalorização dos PCs a um nivel bem baixo, os mesmo continuarão custando mais caro que um VG, mas vale lembrar que um PC não serve exclusivamente para jogos
    Membro Avatar de Repolho Roxo
    Normal
    Jan 2001
    Mais uma vez, especificações, numeros, graficos, graficos, graficos. Daqui a pouco vcs vao fazer 1 petição para 1 3dmark dos videogames.
    Tem uma coisa que vcs se esqueceram, se chama diversão, e ela nem sempre esta ligada ao gráfico. Qndo eu percebi que me divertia mto mais nos meus videogames q no meu pc q eu tinha acabado de dar upgrade gastando 1 grana ( na epoca top, xp2400+ watercooled r9700pro bba que foi 1 fortuna ) comecei a me perguntar se valia a pena.
    Acredito que a proxima geração vai sim ser melhor que 1 pc top, mas nao por muito tempo, porem mesmo qndo os pcs passem os consoles, nao trocaria 1 console desse por 1 pc top. Pc eh pra auxiliar o console na compra de jogos ;p navegar bla bla, jogar acho melhor consoles. Basicamente minha opinião eh o contrario da do P1k4chu, pc sux pra jogos, console rlz ;]
    Esse pessoal teria que largar a mão dessa mania de só(mais) gráficos e processamento. E aonde fica a diversão nisso tudo?
    Só dão valor a processamentos e gráficos, mas eles deviam dar mais ênfase em fazer mais jogos legais, divertidos e envolventes e não esse monte de lixo "deslubrante" que aparece aí toda hora.
    Minha opinião.
    Originalmente enviada por insect-by
    Deve ser pq vc não joga FPS (shooters). Não tenho nem como imaginar alguém jogando um UT, UT2004, CS ou até mesmo um War3 num VG. Simplesmente não rola! Se rolasse teria WCG, CPL e outros campeonatos desse nível para VG, o que não acontecesse. Além disso, VG está MUITO atrás no quesito Multiplayer/Lan. Mesmo que já exista multiplayer, internet e tudo mais pra VG, ainda está muuuuito aquém dos PCs.
    Re: A verdade por trás da CPU do Xbox360 e do PS3!!
    [/B]
    Claro! No começo, nenhum desenvolvedor consegue usar todo o poder da plataforma... Plataforma nova, não se conhece muito, se subutiliza... Compara os jogos de PS2 no início com os atuais... Alguém já viu os gráficos do PS3? Não vi NENHUM jogo de PC naquele nível...
    Não confio no Anand pra falar de VG simplesmente pq ele não tem noção de como funciona desenvolvimento em VG, de que não é nada padronizado, ou seja, quando chega um hardware novo, DEMORA até conseguirem aproveitar o potencial! Um VG tem que durar 3-5 anos justamente por causa disso, repara que os jogos melhoram sim exponencialmente em função do tempo, de acordo com que os desenvolvedores aprendem a usar tudo...
    Anyway, VGs SEMPRE vão ter uma vantagem em cima de PCs: Eles tem JOGOS.
    Vou plagiar o Diesel feião nessa frase, mas se vc for reparar, no último ano saíram mais modelos de placa de vídeo e de processador novos do que jogos decentes novos!
    Deve ser pq ele não joga SÓ FPS
    Pra PC atualmente tem saído praticamente só FPS, com o ocasional RTS, e uma penca de RPGs coreanos quase todos iguais, mudando só a história, os gráficos e os sprites.
    E VG tá atrás no quesito multiplayer em LAN/WAN, simplesmente pq não é a mesma idéia de PC de cada um jogar em um lugar, VG é pra vc juntar gente no mesmo VG e fazer bagunça...
    Creio que cada um tem seus pontos fortes.
    Eu pessoalmente prefiro PC, devido as diversas coisas que se pode fazer nele, e nao só jogo, além de possuir jogos ótimos tbm claro.
    Eu tinha video game e vendi ele e fiquei so com o PC, mais claro que as vezes da saudades apoiapoa, e como disse pc em FPS eh legal mais o VG tbm na questao de junta a galera numa sala e zua tbm eh show, entao tudu depende do seguinte ponto.
    O que você quer e quanto vc dispoe de R$ pra isso =)
    Em casos extremos agente se aproveita do vizinho mesmo =o
    Jan 2001
    de vez em qndo eu jogo cs ainda. Joguei fps em pc ( ate far cry, depois parei por q fikei sem placa de video boa ).
    To jogando Area51 no ps2, realmente, mouse + teclado para fps e estrategia eh melhor. Porem, proxima geração, controles wireless, o q impede vc usar mouse e teclado sem fio no console?
    E realmente eh como disseram, eu jogo fps sim, mas nao SO fps, q eh onde pc leva vantagem. Nao troco Final Fantasys, Zeldas, Metal Gears, etc etc por 1 fps com ultra graficos violentos, historia 0 diversao -1.
    Ah, qnto multiplayer, proxima geração vai ser beem online, mas como ja postaram tambem, chamar o pessoal pra jogar eh divertido tbm. Ontem jogando Def Jam Fight for NY, ria demais, diversao total.
    Membro Avatar de Arraso
    Apr 1999
    A Epic disse que as texturas do Unreal 3 na nova geração de videogames ainda será menor do que no PC. Metade ou até mesmo 1/4 das texturas padrões (2048x2048!!!!!!).
    Mas por outro lado, só mesmo VGA's com 1GB pra aguentarem tantas texturas enormes.
    Outra coisa: agora todo jogo pra videogame terá anti-aliasing setado por default.
