    Dica de mem barata pra A64
    Tenho uma A8N-SLI
    Estou pensando em uma destas:
    DDR PC3200 GEIL 1GB VALUE DUAL
    Peso: 100 gr
    Geil 1GB (512MBx2) Ultra Series Value Dual Channel 184 Pin DDR PC-3200 w/ Blue Heatspreader - Model GE1GB3200BDC, DDR400, Non-ECC, Unbuffered, Cas Latency: 2.5 7-4-4, Support Voltage: 2.55V-2.95V, Bandwidth: 3.2GB/s, 2x64M x 64Bit, Optimized SPD for Dual Channel DDR motherboards.
    Lifetime Warranty.
    US$ 115.00
    DDR PC3200 GEIL 1024MB DUAL (A que mais me agradou destas baratas)
    Peso: 100 gr
    GEIL 1024MB(2x512MB) PC-3200 (400MHz) Dual DDR RAM, 6 Layer Lower Noise PCB Copper Heat Spreader, Dual Channel SPD Enhanced, Special design for dual channel motherboard, 184-pin DDR Memory PC-3200(400MHz) Voltage:2.6-2.9, CAS 2 6-3-3 1T, Model#: GL1G3200DC
    Lifetime Warranty.
    US$ 182.00
    DDR PC3200 CORSAIR 1GB TWIN CAS2
    Peso: 100 gr
    Corsair TWINX1024-3200C2 1GB DDR400 XMS3200 Dual-Channel Memory w/ Heat Spreader - This memory kit consists of two CMX512A-3200C2 400MHz 2 x 64M x 64 memory modules that were specifically designed for motherboards using chip sets with dual memory channels (e.g. Nforce2). Lifetime Warranty
    US$ 159.00
    Ou outra dica de vcs que possa ser encontrada na A1
    Cheguei a pensar nessa:
    DDR PC4400 CORSAIR 1GB TWIN CAS25
    Peso: 100 gr
    Corsair XMS Extreme PC4400 1024Mb (2x512Mb) TWINX1024-4400C25 DDR550 TwinX Pack Low Latency 184 Pin - Retail, Non-ECC, Unbuffered, Cas Latency: 2.5-4-4-8, Support Voltage: 2.75V, Bandwidth: 4.4GB/s, 2x64M x 64, Lifetime warranty.
    US$ 274.00
    Mas MUITO cara
    Esta aqui tem alguma coisa a ver com as lendárias OCZ rev2 ou nada a ver:
    DDR PC3700 OCZ 1GB GOLD DUAL REV3
    Peso: 150 gr
    OCZ 1GB (512MBx2) DDR PC-3700 GOLD EDITION REVISION 3 Dual Channel Series 184-Pin - Model OCZ4661024ELDCGER3-K DDR466(PC3700) 184-Pin DDR SDRAM, Non-ECC, Unbuffered, Cas Latency: 2.5-3-3-8, Support Voltage: 2.8V, Bandwidth: 3.7GB/s, 2x64M x 64Bit. Lifetime Warranty.
    US$ 215.00
    TKS
    Nenhuma dica?
    Pode ser alguma que não está na lista
    Membro Avatar de Cardone
    Comprei com o gbgigli, boa memória TCCD 1GB DDR PC3200 CORSAIR 1GB TWIN XL Xtra-Low Latency Matched Pair, CAS Latency: 2-2-2-5.
    Tem na A1 tb
