    [OVERCLOCK] Dê Opiniões
    To com a configuração do meu pc da seguinte forma.
    Multiplicador: 11x
    FSB: 200
    vcore: 1.688
    Estou fazendo 5777 pontos em media no 3dMark03 (Com o Path)
    O que vocês acham ? Tá na media ou da pra melhorar?
    Se da pra melhorar o que posso fazer pra melhorar?
    OBS: Consegui colocar 11.5 x 200 mas não ficou estavel...
    File Name
    Benchmark
    Width 1024
    Height 768
    Anti-Aliasing None
    Post-Processing No
    Texture Filtering Optimal
    Max Anisotropy 4
    Vertex Shaders Optimal
    Force PS 1.1 in GT2 & GT3 No
    Repeat Tests Off
    Fixed Framerate Off
    Comment
    3DMark Score 5783 3DMarks Game Tests
    GT1 - Wings of Fury 180,8 FPS Game Tests
    GT2 - Battle of Proxycon 38,0 FPS Game Tests
    GT3 - Troll's Lair 34,2 FPS Game Tests
    GT4 - Mother Nature 37,4 FPS Game Tests
    CPU Score 675 CPUMarks CPU Tests
    CPU Test 1 75,2 FPS CPU Tests
    CPU Test 2 12,0 FPS CPU Tests
    Fill Rate (Single-Texturing) 1710,6 MTexels/s Feature Tests
    Fill Rate (Multi-Texturing) 2923,4 MTexels/s Feature Tests
    Vertex Shader 18,1 FPS Feature Tests
    Pixel Shader 2.0 54,0 FPS Feature Tests
    Ragtroll 23,9 FPS Feature Tests
    No sounds 0,0 FPS N/A Sound Tests
    24 sounds 0,0 FPS N/A Sound Tests
    60 sounds 0,0 FPS N/A Sound Tests
    System Info
    Version 3,6
    CPU Info
    Central Processing Unit
    Manufacturer AMD
    Family AMD Athlon XP_M
    Architecture 32-bit
    Internal Clock 2205 MHz
    Internal Clock Maximum 3000 MHz
    External Clock 200 MHz
    Socket Designation Socket A
    Type
    Upgrade ZIF Socket
    HyperThreadingTechnology N/A
    Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE, PAE
    Version AMD Athlon XP_M
    Caches Level Capacity Type Type Details Error Correction Type Associativity
    1 128 KB Internal Synchronous
    2 512 KB External Synchronous
    DirectX Info
    Version 9.0c
    Long Version 4.09.00.0904
    DirectDraw Info
    Version 5.3.0000001.0904
    Primary Device RADEON 9800 PRO
    Display Devices
    Display Device
    Description RADEON 9800 PRO
    Manufacturer ATI Technologies Inc.
    Total Local Video Memory 256 MB
    Total Local Texture Memory 256 MB
    Total AGP Memory 128 MB
    Driver File ati2dvag.dll
    Driver Version 6.14.10.6553
    Driver Details 8.152-050629m-024085C-ATI
    Driver Date 28/6/2005
    Driver WHQL Certified VERDADEIRO
    Max Texture Width 2048 px
    Max Texture Height 2048 px
    Max User Clipping Planes 6
    Max Active Hardware Lights 8
    Max Texture Blending Stages 8
    Fixed Function Textures In Single Pass 8
    Vertex Shader Version 2
    Pixel Shader Version 2
    Max Vertex Blend Matrices 37
    Max Texture Coordinates 8
    PCI
    Name RADEON 9800 PRO
    Vendor ID 0x1002
    Device ID 0x4e48
    SubSystem ID 0x00021002
    Revision ID 0x0000
    Capabilities AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures, Two Sided Stencil Test, Mipmapped Volume Textures, Mipmapped Cube Textures, Spherical Mapping, Automatic Mipmap Generation, Hardware Rasterization, Shading, Transform and Lighting, Scissor Test, Legacy Depth Bias
    VGA Memory Clock 338 MHz
    VGA Core Clock 378 MHz
    DirectShow Info
    Version 6.05.01.0900
    Memory Info
    Total Physical Memory 512 MB
    Free Physical Memory 359 MB
    Total Pagefile Memory 1249 MB
    Free Pagefile Memory 1062 MB
    Memory Arrays
    Memory Array
    Max Module Capacity 1536 KB
    Location System Board
    Use System
    Supported Error DC
    Supported Speeds
    Supported Types
    Supported Voltages
    Memory Slots Installed Enabled Size Form Factor Frequency Slot Manufacturer Type
    0 B DIMM 0 Hz DIMM1 [Bank0/1]
    0 B DIMM 0 Hz DIMM2 [Bank2/3]
    512 MB DIMM 0 Hz DIMM3 [Bank4/5]
    Motherboard Info
    Supported Slot Types ISA, PCI, AGP
    Manufacturer http://www.abit.com.tw/
    Model AN7 (nVidia-nForce2)
    Version 1.X
    BIOS Vendor Phoenix Technologies, LTD
    BIOS Version 6.00 PG
    BIOS Release Date 23/11/2004
    BIOS Properties Plug and Play, Flash, AGP
    AGP
    Revision 3
    Rate 8x (8x enabled)
    Available Rate 0x00000008
    Selected Rate 0x00000008
    Aperture Size 0 B
    Sideband Addressing supported (disabled)
    Fast Write supported (enabled)
    UP!
    caraio..é um mobile e num foi com 11.5x200???
    mas pow..2200mhz é um over bem baixinho!!
    tenta subir + o FSB e diminuir o multiplicador q é melhor!!
    ou seja...é melhor 220x10 do que 11x200!!
    mas o seu ai..2.2ghz tá na media..tipo..um oc normals!!
    mas mobile..deve ir mais longe se vc num deu azar de pegar um ruim de oc!! seim..tem mobile ruim de oc!! hehehe
    rodo estavel com
    10x220
    será que é bom tentar diminuir mais o multi e almentar o fsb ?
    será o que tah me ferrando é minha memoria 512 generica?
    UP!
    Membro Avatar de Skitter
    Originalmente enviada por psytrancebr
    será?
    rodo estavel com
    10x220
    tenta 200x11.5 e 200x12 com 1.775 na bios (aprox. 1.75 real), é qto o meu precisava
    Essa voltagem nao é perigosa nao ?
    11!
    não é não.
    Dependendo de como ficar a temperatura vc pode usar com essa tensão diariamente sem problema nenhum.
    PS e edit na msg anterior: 200x11.5 e 200x12
    e n, n é n. usava diariamente no meu mobile numa dfi infinity @ vcom 21b + sfII
    Vo testar essa configuração e digo como ficou...
    Rodo estável em:
    Mult : 12x
    FSB : 200
    vcore : 1785
    AGora está bom ?
    rodava aqui com meu mobile 200 x 12.5 com 1.70 de core
    processador bom que peguei de mobile
    tenta rodar 12.5 tambem com esse core que vc esta
    Vou tentar... porém não é preferivel aumentar o FSB ?
    primeiro se descobre o limite do processador e depois o limite das memorias ou vice-versa, mas nunca ambos juntos
    minhas memorias eram xing link fazendo isso, e nao me dava bem em mexer com os divisores hehehehehhe sei la, noob mesmo
    entao ia estuprando no multiplicador auhauhuhauh
    Rodo estável em:
    Mult : 12x
    FSB : 200
    vcore : 1785
    AGora está bom ?
    temperatura??
    58° volcano 12 50%
    58° volcano 12 50%
    max ideal é 55º~53º... diminui isso ae
    2300 com honra !
