    Asus A8n-sli Premium
    Alguem ae já viu ou conhece essa placa, parece ser nova, bios ja suporta 64 X2 e o melhor de tudo é que ela é fanless. O que é otimo, visto que algumas A8N estavam com problemas de overheat por causa de um fan vagaba.
    Veja abaixo algumas difs da versao deluxe
    "A quick take at the above specifications versus those of the Deluxe version of the A8N SLI, show a few major differences to an otherwise very similar configuration. First, Asus' new "AI Cool Pipe" technology has been incorporated into the design, offering completely silent operation, at least at the motherboard level. More details to follow on this. Second Asus has refined their dual PCI Express SLI Graphics approach with a jumperless and software/BIOS configurable solution, that no longer requires you to pull out and flip around a PCI Express configuration PCB in between the slots. "
    "What can be said about the new Asus A8N SLI Premium, that isn't obvious to you with all that you've seen in the pages preceding our summation here? Frankly, not much. The performance numbers speak for themselves. The A8N SLI Premium's feature-set is second to none, with its dual on board SATA RAID controllers (one via the nForce 4 MCP), SLI Dual Graphics capability, dual Gigabit Ethernet controllers, and a completely silent cooling solution for the NVIDIA MCP (Southbridge) that also works to keep the CPU power array cool as well. Finally, it terms of overclocking features and general "tweakability", the A8N SLI Premium is easily one of the best equipped boards we've seen come through the labs here for the Athlon 64 in a very long time. And it performed admirably, overclocking our A64 FX-57 chip to a snappy 3.1GHz."
    http://www.hothardware.com/viewartic...?articleid=704
    Preço?
    Balaca? ehhee
    minha a8n ta com dissipador zalman no chipset e ta tranquilo..
    jr.
    Toskinho esse "Fanless" hein
    n3w
    n3w está offline
    a abit tbm ta com a an8 fanless
    so q ela fez um esquema bem legal com uma saida traseira
    Originalmente enviada por //\\//3W
    Poutz axei outra merda
    Membro Avatar de Repolho Roxo
    Esse negócio de fanless não sei não hein...
