    Membro Avatar de Turco-Gyn
    Essa Radeon 9600pro é boa ?
    Queria saber se essa marca (o fabicante) ela é boa ?
    http://www.newegg.com/Product/Produc...82E16814270005
    Specifications
    Model
    Brand XGI
    Model V8 256MB AGP
    Chipset
    GPU Volari V8
    Memory
    Memory Size 256MB
    Memory Interface 256-bit
    Memory Type DDR
    3D API
    DirectX DirectX 9
    OpenGL OpenGL 1.3
    Interface
    Interface AGP 4X/8X
    Ports
    D-SUB 1
    DVI 1
    TV-Out HDTV Out
    VIVO No
    TV Tuner No
    General
    RAMDAC 400 MHz
    Max Resolution 2048x1536
    Operating Systems Supported Windows XP 2000 ME 98 NT 4.0 and 5.0
    System Requirements Intel Pentium 4 Prescott class processor or higher (LGA775 processor package) or AMD Sempron/Athlon
    128MB System RAM (256MB recommended)
    One available AGP compliant slot
    50MB of available hard disk space for full installation
    CD-ROM or DVD-ROM drive
    VGA or DVI-I compatible monitor
    Features
    Features BroadBahn Memory Architecture
    V-Drive
    On Screen Performance
    Cipher Video Processor
    Volari V5 processors feature XGI's legendary Cipherª video processor. Leveraging this advanced de-interlacing technology means video files play with a smooth, flicker-free and fluid motion that amazes even industry professionals. And unlike competing video processors, the Cipher™ video processor converts both incoming and outgoing video feeds, ensuring that all your videos are displayed with the highest possible on-screen quality.
    ColorAmp Engine
    Each Volari™ V5 processor also feature XGI’s cutting-edge ColorAmp™ Engine - driven by a proprietary algorithm that analyzes on-screen environments and automatically optimizes color intensity and gamma levels to provide the most accurate on-screen color and display brightness.
    Intelli-Vision Engine
    The Volari™ V5 processor's proprietary Intelli-Vision™ Engine makes calculated adjustments to display brightness when entering 3D mode, providing clearer and sharper graphics display performance ideal for today's 3D gaming.
    Reactor Unified Driver
    Harness the superior power of the any Volari™ V5 processor with XGI's Reactor™ unified driver. Packed with useful features and fully compatible with Direct3D and OpenGL APIs, the Reactor™ unified driver allows an advanced level of processor-tuning that easily meets the demands of today's avid gamers. The Reactor™ unified driver works across all graphics boards incorporating Volari™ V5 processors, making driver management virtually effortless.
    Packaging
    Package Contents HDTV Cable
    Driver CD
    User’s Manual
    Tem uma da MSI só q na frente do nome dela ta escrito "REFURBISHED": MSI Radeon 9800PRO RX9800PRO-TD128 Video Card - OEM
    Eu queria ela mas to com medo de ser com defeito.
    Valew ae pessoal !!!
    up porra
    a placa das especificações e do link da neweeg eh uma xgi volari ... naum compre
    hardMOB Staff - Moderação
    AEHOOO o/
    vc passou o link pra uma xgi volari v8 ...
    Originalmente enviada por DarkRider
    ela nao presta ??? é essa mesmo q quero saber .. putz
    Originalmente enviada por Turco-Gyn
    prestar presta...mas naum tem driver descente... vc ter uma placa com a capacidade de uma 9800pro mas que mal consegue rodar CS por causa dos drivers
    pegue essa grana e compre uma 9600pro ... fuja de xgi
    Membro Avatar de Jhonny Stequino
    Cara, não compraria nem essa placa nem uma 9600pro, tem coisa melhor pelo mesmo preço pra se comprar.
    Tenta comprar uma 6600 normal
    Originalmente enviada por flashfs
    Cara, qualo valor de uma 6600 normal AGP 8X ??
    olha q bosta q tah no faq :
    Q1 I get very poor performance with my games. How can I fix this?
    A1
    Please update the latest driver from XGI web site ( http://www.xgitech.com/sd/sd_download.asp) or set the quality of the game to low or decrease the display resolution.
    AUHAUHHUHHUAHUAHUAUAUHUHAHUHUUHAUHHUAHUHAA
    Originalmente enviada por TMO-SP
    mais que 100 dolares e menos que 200
    as boa é tudo pci/express
    ae q vc se engana... muitas AGP aceintam mods e coisas do tipo
    A1
    Não entendi, qual foi a piada? A placa não é top, e tem muitos jogos pesados por ae...
    offtopic:
    Turco to com uma 9600xt pra vender, baratinha.
    Msn pra contato: [email protected]
    tentei de mandar mp mas sua caixa ta cheia.
    Sou de gyn também.
