Página 1 de 6 1 2 3 ... Última
    7800 ultra a caminho?
    ichi..parece q a Nv vai pisar no pescoco msm..
    NVIDIA_G70.DEV_0090.1 = "NVIDIA G70"
    Today we took a look into the NVIDIA ForceWare 81.40 which has been leaked by The French website, Station Drivers. I’ve opened the setup information file (NVDISP.INF) and noticed a lot of new Hardware DeviceID entries. ..
    NVIDIA already said there won’t be Ultra version of the 7800 series. For some reason I don’t really believe them. I did some research and spoke to a lot of people regarding this matter and if I were NVIDIA, I would wait until ATI releases their R520 series and then I would release a monster card to deal with the X1800 XT. In the DeviceID above, you can see the order of the cards. You can see unrevealed entry above the 7800GTX. According to my sources, I have strong reasons to believe that it would be the GeForce 7800 Ultra. If it smells like cheese, and looks like cheese, Then.. It’s cheese.
    http://www.ngohq.com/home.php?page=A...read&arc_id=46
    Parece q vai dar o obvio: com capacidade de prodcao facil de uma 7800 mais forte, e dx10 vindo ae, a Nv deve lancar uma 512mb bombada pra dominar o natal e acabar de capitalizar no Sm3.
    ".Quadro version of the 7800GTX is already running at 500/1050 mhz in nvidia reference design.So it is possible for nvidia to get higher core clocks with a better cooler.A 512MB version is coming for sure
    ps. Sera q sai antes do x1800? ..
    ps2."NVIDIA releases their upcoming 512 MB version of the 7800 GTX scheduled to be by the first of November." eita pior q sai antes..e ainda deve ser o msm preco das x1800 :/
    Membro Avatar de Darktag
    Doe sangue.
    JESUS
    hardMOB Staff - Moderação
    AEHOOO o/
    Originalmente enviada por Darktag
    JESUS
    Asy
    Asy está offline
    Membro Avatar de Asy
    NinaAgdal>All
    Normal... já havia dito isso noutro tópico.
    Membro Avatar de DYnHo
    depois sai uma x1800 xtpe, como sempre
    Membro Avatar de toledo
    Originalmente enviada por DYnHo
    So se for com LN2 box pois o clock ja ta la na casa do caralho e o cooler ja esta meio grandinho .
    Originalmente enviada por Deco Rj
    O que foi que eu falei ?
    Membro Avatar de XOTISNEGUER
    OVER 9000 NG/DL
    nossa.. vai ser du caralho essa hein
    terei de pedir pro papai noel
    se papai noel nao colaborar, terei de começar a vender meus patrimonios para poder fazer um sli zinho basico de 7800ultra.
    7800 ultra palha ! quero ver a 7800 ultra blaster @ master fucker !
    pqp cada dia uma novidade ;(
    Membro Avatar de Repolho Roxo
    Pode ser uma 7800 pura também.
    Membro Avatar de TM99
    queria ver uma 7800 rodando a 650/1350 XD
    cancel
    Achei que a Nvidia avia cancelado a 7800U...
    O que será que fez ela mudar de ideia? :P
    Re: cancel
    A Ati de perna aberta
    ps."ATI also implied that if it wanted to make extreme fast platinum edition clock that it would be able to push the chips even higher than 625MHz/1500MHz."
    lol..vai ispludi. Ln2 platinum diamond adamantium edition uhauahahu..
    Re: Re: cancel
    iuhaiuhaui
    falei..
    ati vai ficar usando 16 pipes até a morte prematura dela =(
    adamantium edition rox =P
    Membro Avatar de andrepmrj
    gente uma duvida qual foi o mair clock que nego ja rodou em uma 7800gtx ????
    vi faz um tempo 702/1.506... em julho isso eu acho...talvez alguem já tenha batido.
    Acho q tem mta gente subestimando a ATI ...esse chip ta imaturo ainda .... tem muito a melhorar com drives como aconteceu com a GTX ...
    Querendo ou nao a ATI ja passou pela dificil transicao q eh o 0.09 .... q a intel apanhou e apanha ate hj ..... a placa ainda tem 16 pipes .... e eh superior a gtx mesmo com 50% a menos de pipes ....
    claro ... vcs vao falar do clock alto ... mas acredito q hj as 2 placas rodando no mesmo clock ... teoricamente com o mesmo numero de pipes ..... fika claro quem tem o melhor chip !! E acredito hj ser + facil a ati fazer chips com + pipes do q a nvidia entrar nos 0.09 sem ter problemas tb!!
    Tudo leva a crer agora em melhorias no chip e futuramente versoes com 20...24 ou ate mesmo 32 pipes !!!
    Pra quem fala q a unica placa q a ati fez q prestou foi a 9700 ... nao se esquecam das 8500 ... absurdamente + baratas q as ti4xxx !!
    E eram otimas placas ....
    Sempre tive as duas marcas e nao visto a camisa de nenhuma .... eu compro o q eh melhor ... tanto em performance como em custo ....
    Hj .. o melhor custo eh a 7800GT (GTX ainda eh cara e da gargalo com 99% dos processadores) .... mas nada garante q esse jogo pode estar pra se inverter !!!
    Originalmente enviada por reincarnated
    bom se fosse na epoca das placas de 16 pipelines, ati tava feita, mas nao , ja esmaos na de 24,o que faz a placa da ati ser mais rapida e apenas o clock.
    vela lembrar que a x1800xl em alguns cassos e igual a uma x800xl.
    Concordo .... mas vamos por partes .... vc acha q se a 7800 tivesse o mesmo clock e o mesmo numero de pipes da 6800 ela tb nao teria praticamente a mesma performance ??? como eh o caso da x1800xl e x800xl......
    A nvidia esta fazendo exatamente o q a ATI fez com a 9700 ... o chip foi otimo (6800)... e vai aproveitar durante muito tempo .....
    Eh nisso q eu acredito ..... x1800 com 24 pipes 625/1500 fikaria muito distante de uma 7800gtx 625/1500 !!
    como nenhuma das 2 descritas acima existe .... quem ta fazendo upgrade de vga agora ... vale a pena ir de x1800xt(qdo o preco estiver compativel com das 7800 .. acredito q soh ano q vem)
    .... pq sinceramente acredito q quem tem 6800 e x800 ta muito bem servido de vga .... pq o ganho de performance pra essa nova geracao nao compensa o investimento !!!
    poutz, ta saindo mta coisa....
    eu ia comprar uma 7800gtx com 256mb, mas sera que vale a pena esperar ate novembro para comprar a de 512mb? a diferenca eh mt grande?
    pq se for o caso eu nem fiko esperando para trokar de pc.. eu ja compro o pc agora mas continuo com minha vga ([email protected]) enquanto nao compro uma nova.
    Membro Avatar de daniel_cps
    e as arveres some nozes
    a 7800gtx de 512mb ja foi anunciada emsmo.. saiu a umas 2 semans la no the inquirer.
    Ah mas ae eu aposto a a Nv tem um projeto otimo de 57 pipelines q "no mesmo clock" bla bla bla..
    Q q adianta ter um chip lindo e nao conseguir fabricar...
    Alias, a Nv ja tem placa 32 pipes .90mm rodando Dx10 a algum tempo..entao pode tirar o cavalo da chuva pq msm q a Ati conseguisse o impossivel, so ia gastar mais pra tomar mais naba ainda. Ate na teoria ilusoria mais otimista pra Ati ela ia tomar couro, pq a g80 ja eh uma realidade e a Ati nem o r500 botou pra vender ainda.
    Hheauheauheuahe ..... cara ... vc eh mto nvidia boy =P
    le d novo o q vc escreveu .... contradicao total
    "Ah mas ae eu aposto a a Nv tem um projeto otimo de 57 pipelines q "no mesmo clock" bla bla bla."
    "Alias, a Nv ja tem placa 32 pipes .90mm rodando Dx10 a algum tempo.."
    Vc critica rumores e fala de rumores ....
    Assim fika dificil fazer uma discussao saudavel =P
    rumores?
    enquanto vc ta sonhando com uma r500 24 pipes a Crytek ja ta rodando farcry em dx10 numa g80 32 pipes .90mm ja tem algum tempo..
    hehe eu nao to me contradizendo, a primeira frase foi brincando com o q vc escreveu:P
    rumores?
    enquanto, vc ta sonhando com uma r500 24 pipes enquanto a Crytek ja ta rodando farcry em dx10 numa g80 32 pipes .90mm ja tem algum tempo..
    Eu nao sonho com nda ... vc q ta sonhando ... =P
    haueheuahe
    eu to falando dakilo q ta ai disponivel(nao ta a venda ainda ... mas ja foi apresentado ao publico ... e funcionando) ....tanto q comentei no meu post nao adianta falar ... gtx com 625/1500 e nem r520 com 24 pipes .. pq isso tb nao eh realidade .... g80 e r580 muito menos !!!
    Volto a repetir ... a placa pra se comprar agora eh a 7800gt .... em janeiro provavelmente a x1800xt!
    Quem tem 6800 e x800 nao acho q precise trocar !!
