    Membro Avatar de daniel_cps
    e as arveres some nozes
    ATI faz cagada de novo.. ADIOU as x1600 p dezembro. [traduzido]
    pois é pessoal...
    a ATI adiou o lançamento da serie X1600 p dezembro, que só devem chegar aos consimidores ano q vem
    texto em ingles:
    IT'S NOT every day we hear an executive say that he and the company he leads chickened out. Yet ATI told the press that the key reason why it won't have its RV530, Radeon X1600 generation of cards till December because it chickened out and cancelled its wafer orders.
    Back in the summer, when R520 had its nasty current leakage problem, the same chap who, incidentally, used to like and still likes AMD, confirmed that RV530 had the same problem. If you remember this bug prevented the card from working effectively at more than 500MHz. The Radeon X1600XT works at 600MHz but was indeed affected by that bug. As soon as ATI fixed the bug for R520, it applied the same technique and fixed RV530 all the troubles were gone.
    At that time the company decided to cancel its massive wafer orders for RV530 and its takes time to re-order and produce them again. Of course TSMC is producing wafers and chips for both ATI and Nvidia.
    In the mean time, yields of R480 and R430 at 110 nanometre were so good that ATI could sell those chips at mainstream price and poistion its highly-overclockable X800GT and top-performing X800GTO card and against Nvidia's bigh guns in mainstream.
    ATI will get its first chunk of RV530 chips in December while the first cards are expected in middle December. We don’t think you will be able to buy any of those cards before Yule but they should be out just shortly after.
    >>>>>>>> FONTE: THE INQUIRER <<<<<<<<<<<
    http://www.theinquirer.net/?article=26980
    Editei sim Nitrium
    TRADUÇÃO
    Nao é todo dia que vemos um alto executivo dizer que a empresa que ele comando "ficou com medo, amarelou". Entretando a ATI falou que o principal motivo que ela não terá seu novo chip RV530, core da serie x1600, até dezembro é pq eles amarelaram e cancelaram todos os pedidos dos "WAFER"
    (o que são esses wafers ? é como eles chamam os chips soltos qnd vem da TSMC ? essa eu não sei favor me ajudarem, desculpe a ignorancia)
    No ultimo verão (verão americano é em JULHO), quando os R520 tiveram os problemas de fuga de corrente, foi confirmado que os chips RV530 tbm sofriam do mesmo problema. Se voce se lembra este bug impedia os chips de passarem os 500mhz e trabalharem estaveis, como as x1600xt tem clock de 600mhz elas foram tambem de fato afetadas por este problema. Assim que a ATI arrumou o bug nos R520, a mesma solução foi implantada na serie RV530 e todo os problemas se resolveram.
    Naquela epoca, a ATI resolveu cancelar seus pedidos ENORMES de wafer p serie RV530, e leva algum tempo para pedir novamente, e efetivamente voltar a produzi-los, ja que a TSMC fabrica chips para ambas NVIDIA e ATI.
    Enquanto isso, os chips r480 e r430 eram tão bons mesmo na tecnologia de 110 nanos, que a ati resolveu vender placas com esses chip no mercado mainstream a preço das concorrentes e posicionar a altamente overclockavel X800GT e a de performance TOP X800GTO p copetir diretamente com as otimas placas da Nvidia neste segmento.
    A ATI recebera sua primeira leva de chips RV530 em dezembro, as placas só são esperadas para meados de dezembro. Nós nao achamos que voce conseguirá comprar nenhuma desas placas antes do final do ano, mas deverão sair já na sequencia...
    Feb 1999
    Fonte?
    Fonte?
    editado.
    mals
    Feb 1999
    editado.
    mals
    Ainda não editou lálálálálá... feio.
    Feb 1999
    Putz, mas o que é isso...
    Baita cheiro de desespero no ar.
    Nao achei no google.. posta a fonte ai, mas sinceramente eu nao duvido nem um pouco..
    Membro Avatar de bd.grinder
    Tomara q mudem essa placa... se saisse ela do jeito q vi nos bench ia ser fiasco.
    agora traduzido para nossos amigos preguiçosos...
    abraços. !
    A X1600XT tem um desempenho tão irregular que não dá pra comparar com placa nenhuma.
    Chega a perder da GF6600GT em alguns testes!
    E chega a encostar na GF6800GT em outros, deixando a GF6600GT e a GF6800U comendo poeira!
    Ela vai muito bem no 3dmark05, por exemplo!
    As X800GT e GTO estão com preços excelentes. A ATi não está mal servida nesse mercado. Pelo contrário. O único defeito dessas placas é a falta do suporte ao SM 3.0 mesmo.
    Sinceramente, a ATi deveria cancelar definitivamente esse ***LIXO*** chamado X1600XT. Uma placa absurda, com 12 pipes e 4 TMUS!!! 4 TMUS! Que lixo! 4 TMUS pra custar US$ 249,00!
    Pedala ATi!
    fui
    PS: A ATi tem que subir o clock dessa X1600XT para uns 700Mhz se quiser 'salvar' alguma coisa.
    wafer é a placa com os chips impressos. essa porra aki ó :
    esses aí são wafers de 300 mm da nova fab36 da amd, em dresden.
    E o mel é a pasta termica
    se algum funcionario tropeçar e quebrar será que vai ser demitido?
    O mais forte do universo!
    ah to tranquilo, o "importante" é q a ATI esta de cabeça na nova tecnologia...... quando ela for completamente dominada será um belo salto de performance...... isso é certeza
    espero q tudo se resolva ate o fim do ano, a ATI pode aguentar tranquilamente......
    nussa, so faltava a Nv lancar g7600 .90 fuderosas junto com a 7800ultra/512 antes do natal pra azucrinar de vez o barraco da ATi.
    se nao fosse a 6800.. eh tanta placa forte pra tao pouca coisa q a Ati nao lancou essa placa pq tem trocentas outras vendendo com essa msm performance.
    Membro Avatar de Repolho Roxo
    Ela viu a maravilha de placa que fez e tá mudando as presas as spec delas.
