Página 2 de 2 Primeira 1 2
    Membro Avatar de El Palestrino
    keyzersoze
    o mod é garantido? se for prefiro ela a uma 6800gt...
    Do techpowerup, talvez possa ajudar...
    Not only the Sapphire GTO² can be modded, the regular GTO cards from Connect 3D are also moddable. However, the success rate is unknown. If you try this mod, please let me know of your results.
    Success 40 : 1 Failed (last update Oct 28 2005).
    The steps to do the mod are exactly the same as the Sapphire GTO² mod outlined on page 2.
    You just use another Bios.
    However, there are some drawbacks compared to the Sapphire GTO² cards:
    1. Sapphire uses faster 1.6ns memory, while Connect3D uses only 2.0ns.
    2. Sapphire uses a guaranteed R480 core, while Connect3D uses only R423.
    Membro Avatar de toledo
    chego à tudo isso?
    sem mod nenhum ou vc edito a voltagem p/ da ultra?
    Chegou sem mod, a VGA era boa .
    Hoje esta com meu irmão , rodando em stock
