    Membro Avatar de ermail
    Monitor LCD LG L1950S, é bom?
    Estou querendo fechar a compra desse Monitor LCD LG L1950S lá em cobija, preciso confirmar isso ainda hoje, alguém sabe dizer se ele é bom?
    Especificações:
    Narrow Bezel Design
    : Ideal for commercial use - Ultra Narrow Bezel disign enables monitors to be tiled making them ideal for trading floors, banks, airports, design center and etc.
    Quick Response Time
    : Quick response time realizes smooth and flicker free images.
    Built-in Power Adapter
    : For reduced cable clutter and easy wall-mounting
    OSD Lock
    : OSD Lock function prevents unwanted changes to display settings
    Auto Adjustment Function
    : Automatically sets image position, phase and pitch
    LightView Function
    : LightVeiw function allows users to freely adjust brightness and color temperature according to their computing situation like photo, text, movie (Day/Night).
    Certified TCO-03
    : More strict regulations than TCO-99, it gurantees user's excellent workplace regarding ergonomics, visual performance and environment.
    Panel
    Size 19.0"
    Resolution 1280 x 1024
    Pixel Pitch 0.294mm
    Brightness 250 cd/m2
    Contrast Ratio 500 : 1
    Viewing Angle 160/160 (H/V)
    Response Time 12 ms
    Display Colors 16.2M
    Sync Range
    Horizontal Frequency 30 ~ 83 kHz
    Vertical Frequency 56 ~ 75 Hz
    Input Signal
    Video Signal RGB Analog
    Sync type Separate, Composite, SOG
    Connectors
    PC 15 Pin-D sub
    Plug & Play
    DDC DDC 2B
    Power Supply AC 90~264 V (47 ~ 63Hz)
    Power Consumption
    On 43W
    Stand-by / Suspend 1W
    DPM Off 1W
    User Control
    Button Menu(1),LightView (-/+),Set/Auto(1),Power(1)
    Functions LightView, OSD Lock, Auto Adjustment, Gamma Control
    Mechanical
    Dimension(W x H x D) Set : 412.8 x 420.3 x 230.3 mm
    Stand Swivel(+/-175),Tilt(+5/-20)
    Regulations
    Safety UL,UL-cUL,TUV-GS,SEMCO
    EMC FCC-B,CE
    Low radiation TCO-03
    Ergonomics ISO 13406-2
    Power saving EPA Energy Star
    ETC VCCI-2 (Japan),C-TICK (Australia),GOST (Russia)
    Alguém sabe a diferença do LG L1950S para o LG L1950H?
    Ve se lá não tem o LCD 19" BENQ FP91G. È 8ms e parece que está no mesmo preço que o L1950S ou menos até..
    Eu não sei dizer se este é bom ou não, mas estou acompanhando o topico do BenQ e estão falando que ele é o melhor que tem no PY, não sei em cobija.
    Membro Avatar de Domino Hurley
    Dec 2004
    A diferença q vi é só que o L1950H tem ajuste de altura.
