    Membro Avatar de natanaelcd
    Essa DDR Samsung tem PCB BrainPower? TCCC com inscrições BP MLL atras.
    To na duvida, e queria a opinião do pessoal.
    As memorias que estou vendendo, todas tem chips TCCC.
    E atras delas, no meio, num espaço que nao tem chip, tem as seguintes inscrições:
    BP MLL
    E186014
    94V-0
    É PCB BrainPower?
    ah, são muito boas de over! 500mhz 2.5-4-4-8 1T 2.6V somente.
    The DIMMs are mounted on a PCB that appears identical to a PCB used on a few other top TCCD DIMMs. The PCB ID is BP MLL E186014, which appears to be the top performing Brainpower PCB used by OCZ, Geil and G. Skill, just to name a few. This PCB has developed quite a reputation for top performance at high speeds with Samsung TCCD, so we expect great high-end results from this Corsair DDR550. Those of you wondering how to identify a Brainpower PCB will be pleased to know that it is distinguishable by just 8 components along the lower edge of the back side of the DIMM - just above the slot fingers. Most other PCBs that we have seen used with TCCD are strewn with components along this edge on both sides. This quick ID method will change with future designs, but if you see DIMM side with just a very few components above the slot, it is likely the brainpower PCB.
    Fiquei feliz agora
    hehe
