Página 2 de 5 Primeira 1 2 3 4 ... Última
    Membro Avatar de CommanderBR
    Seagate ATA 100 - 2MB Buffer
    Seagate ATA 100 - 8MB Buffer
    Como vcs fazem pra ver se é bom ou ruim ??
    Qto menor o acess time e maior o burst rate, melhor ??
    Originalmente enviada por Spidey-BR
    caracules, q merda
    o meu hd ta nos 5Mb/s
    eh um seagate barracuda IV 40gbs
    eu cheguei a pensar q era o bt, mas jah fexei e da no msm
    q merda eh essa?
    caracules, to doido aki...
    HD Tune: ST340016A Benchmark
    Transfer Rate Minimum : 2.8 MB/sec
    Transfer Rate Maximum : 5.1 MB/sec
    Transfer Rate Average : 4.9 MB/sec
    Access Time : 14.8 ms
    Burst Rate : 5.0 MB/sec
    CPU Usage : 96.8%
    HD Tune: ST340016A Information
    Firmware version : 3.19
    Serial number : 3HS7TANS
    Capacity : 37.3 GB (~40.0 GB)
    Buffer size : 2048 KB
    Standard : ATA/ATAPI-5
    Supported mode : UDMA Mode 5 (Ultra ATA/100)
    Current mode : UDMA Mode 5 (Ultra ATA/100)
    S.M.A.R.T : yes
    48-bit Address : no
    Read Look-Ahead : yes
    Write Cache : yes
    Host Protected Area : yes
    Device Configuration Overlay : yes
    Automatic Acoustic Management: yes
    Power Management : yes
    Advanced Power Management : no
    Power-up in Standby : no
    Security Mode : yes
    Firmware Upgradable : yes
    Partition : 1
    Drive letter : C:\
    Label : OS & Appz
    Capacity : 3890 MB
    Usage : 90.85%
    Type : NTFS
    Bootable : Yes
    Partition : 2
    Drive letter : D:\
    Label : Gamez
    Capacity : 5169 MB
    Usage : 99.11%
    Type : FAT32
    Bootable : No
    Partition : 3
    Drive letter : E:\
    Label : Media
    Capacity : 27337 MB
    Usage : 99.62%
    Type : NTFS
    Bootable : No
    Partition : 4
    Drive letter : F:\
    Label : Backup
    Capacity : 1537 MB
    Usage : 95.25%
    Type : FAT32
    Bootable : No
    HD Tune: ST340016A Health
    ID Current Worst ThresholdData Status
    (01) Raw Read Error Rate 65 45 34 227987390 Ok
    (03) Spin Up Time 70 70 0 0 Ok
    (04) Start/Stop Count 100 100 20 277 Ok
    (05) Reallocated Sector Count 100 100 36 17 Ok
    (07) Seek Error Rate 84 60 30 250655756 Ok
    (09) Power On Hours Count 87 87 0 11971 Ok
    (0A) Spin Retry Count 100 100 97 0 Ok
    (0C) Power Cycle Count 98 98 20 2653 Ok
    (C2) Temperature 38 53 0 38 Ok
    (C3) Hardware ECC Recovered 65 45 0 227987390 Ok
    (C5) Current Pending Sector 100 100 0 1 Ok
    (C6) Offline Uncorrectable 100 100 0 1 Ok
    (C7) Ultra DMA CRC Error Count 200 200 0 0 Ok
    (C8) Write Error Rate 100 253 0 0 Ok
    (CA) (unknown attribute) 95 248 0 5 Ok
    Power On Time : 11971
    Health Status : Ok
    deve ser pq o hd esta muito entupido... hd entupido fica lento mesmo.
    EDIT - fazendo a média, vc est´pa com 96.21% do hd totalmente utilizado... eu acho que isso é coisa demais cara...
    ORB
    ORB está offline
    2 Barracudas 7200.8
    [img][/img]
    seagate barracuda SATA 80Gb
    em uma Asrock K7VT6
    Membro Avatar de corvin
    FRIGG OFF
    Maxtor 6E040L0
    Asus A7V8X-MX SE
    Athlon XP2600 256KB L2 (esqueci qual é o modelo, tem 3 ...)
    eMule, IE, Winamp e MSN abertos
    36ºC de temperatura tá normal?
    caracules, q merda
    q merda eh essa?
    CPU Usage : 96.8%
    S.M.A.R.T : yes
    48-bit Address : no
    Write Cache : yes
    Security Mode : yes
    Partition : 1
    Drive letter : C:\
    Label : OS & Appz
    Capacity : 3890 MB
    Usage : 90.85%
    Type : NTFS
    Bootable : Yes
    Partition : 2
    Drive letter : D:\
    Label : Gamez
    Capacity : 5169 MB
    Usage : 99.11%
    Type : FAT32
    Bootable : No
    Partition : 3
    Drive letter : E:\
    Label : Media
    Capacity : 27337 MB
    Usage : 99.62%
    Type : NTFS
    Bootable : No
    Partition : 4
    Drive letter : F:\
    Label : Backup
    Capacity : 1537 MB
    Usage : 95.25%
    Type : FAT32
    Bootable : No
    Health Status : Ok
    desliga o smart na hora de fazer o teste
    ? o smart influencia na performance?
    hardMOB Staff - Moderação
    AEHOOO o/
    aqui nao fez a minima diferenca, pelo menos eu acho
    Feb 2005
    Ta certo isso ? Alguem da uma olhadinha pra mim
    fexa tudo antes de usar. e dá ALT + PRINT SCREEN p/ pegar só a janela ativa
    acho que o smart influencia sim
    ow... pq não dah uma editada no 1º post e coloca os 5 melhores HDs e usuarios em diversas categorias como por ex. top 5 burst rate, em taxa media de transferencia e em access time
  13. #37
    AEHOOO o/
    esse ultimo ae ta judiado o.O
  15. #39
    [img]http://img373.imageshack.us/img373/5488/....
    Seagate 160 gb Sata
    meio fragmentado, mas tá valendo :P
    Viper...Viva ao Suporte NCQ....rulando com todo mundo aí..hehehe
    Esse num tem nem jeito mais...olhem só... mas ainda tá servindo como meu backup faz 1 ano e 6 meses firme e forte!
    Abraços pessoal...
    Dica: Como eu montei uma base de dados de Processador A64...o criador deste tópico poderia fazer o mesmo com o HD´s..pro pessoal saber escolher depois quando for comprar... pq dessa forma tá muito confuso....
    Abraços..
    Mário
  16. #40
    Blz, vou aproveitar o feriado e organizar direitinho os tops.
    Abraços []'s
  17. #41
    Originalmente enviada por Fenomeno
    Abraços []'s
    FAz assim oh, acho que ficaria bem legal:
    Capacidade: 40gb
    Coloca todos as variaveis na primeira linha ( o q vc vai comparar) e na primeira coluna os modelos que estão nas 5 primeiras posições...
    Acho que vai ficar bem legal...
    Abraços..
    Mário
    PS: Se precisar de ajuda..estamos aí...bem legal a iniciativa...
  18. #42
    Feb 2005
    cade o Ranking?
  19. #43
    NEO
    NEO está offline
    Membro Avatar de NEO
    Dec 2000
    Soh pra quebrar o gelo.....
    Compaq/HP BD07288277 72.8GB 10K RPM Wide Ultra320 SCSI
    __________________________________________________ __________________
    Dos HD´s de casa eu coloco outra hora, to precisando dar uma formatada e colocar os arquivos em dia... =P
    PS: eu acho interessante (em caso de ranking) se o pessoal colocasse tb a controladora q está usando, a minha mobo por ex (A8V Deluxe) tem 2 controladoras SATA, e cada uma dá um resultado levemente diferente da outra.
  20. #44
    Originalmente enviada por Mark Abene
    cade o Ranking?
    Vou fazer nesse feriado, agora que já acumulou uma quantidade boa de posts com SS dos resultados.
  21. #45
    2x raptor 36gb
  22. #46
    Seagate 10K RPM Ultra SCSI 320, só que a controladora é ultra 160 PCI 64bits mas to usando em um slot PCI normal
  23. #47
    Uma pergunta
    essas controladoras SATA a parte, melhoram velocidade ou coisa do tipo??
    ninguem tem um SATAII 16Mb buffer com NCQ? hehe
  24. #48
    Sep 2005
    Ia pegar um raptor mas vendo esses testes to vendo que a diferença nao compensa o tamanho vo pegar um outro seagate sata 250gb mesmo inves de um raptor 36gb
  25. #49
    Sep 2005
    Aki , com sistema rodando , msn , downloads , tudo normal nao parei nada...
    ta bom , pensei que o RAPTOR quer tava querendo comprar ia dar muita diferença so no seek time que foi bem melhor mas nao compensa p36gb por 250gb
  26. #50
    Membro Avatar de digo23
    Jan 2004
