    Membro Avatar de ermail
    Monitor LCD LG L1950S é bom?
    Encomendei um Monitor LCD LG L1950S, alguém sabe dizer se ele é bom?
    Se não for bom, estou pensando em vender ele assim que chegar e comprar outro.
    Alguém sabe dizer se ele é DVI? É que no ebay, estão vendendo ele como DVI.
    link do ebay: www.ebay.com.au
    Especificações:
    Narrow Bezel Design
    : Ideal for commercial use - Ultra Narrow Bezel disign enables monitors to be tiled making them ideal for trading floors, banks, airports, design center and etc.
    Quick Response Time
    : Quick response time realizes smooth and flicker free images.
    Built-in Power Adapter
    : For reduced cable clutter and easy wall-mounting
    OSD Lock
    : OSD Lock function prevents unwanted changes to display settings
    Auto Adjustment Function
    : Automatically sets image position, phase and pitch
    LightView Function
    : LightVeiw function allows users to freely adjust brightness and color temperature according to their computing situation like photo, text, movie (Day/Night).
    Certified TCO-03
    : More strict regulations than TCO-99, it gurantees user's excellent workplace regarding ergonomics, visual performance and environment.
    Panel
    Size 19.0"
    Resolution 1280 x 1024
    Pixel Pitch 0.294mm
    Brightness 250 cd/m2
    Contrast Ratio 500 : 1
    Viewing Angle 160/160 (H/V)
    Response Time 12 ms
    Display Colors 16.2M
    Sync Range
    Horizontal Frequency 30 ~ 83 kHz
    Vertical Frequency 56 ~ 75 Hz
    Input Signal
    Video Signal RGB Analog
    Sync type Separate, Composite, SOG
    Connectors
    PC 15 Pin-D sub
    Plug & Play
    DDC DDC 2B
    Power Supply AC 90~264 V (47 ~ 63Hz)
    Power Consumption
    On 43W
    Stand-by / Suspend 1W
    DPM Off 1W
    User Control
    Button Menu(1),LightView (-/+),Set/Auto(1),Power(1)
    Functions LightView, OSD Lock, Auto Adjustment, Gamma Control
    Mechanical
    Dimension(W x H x D) Set : 412.8 x 420.3 x 230.3 mm
    Stand Swivel(+/-175),Tilt(+5/-20)
    Regulations
    Safety UL,UL-cUL,TUV-GS,SEMCO
    EMC FCC-B,CE
    Low radiation TCO-03
    Ergonomics ISO 13406-2
    Power saving EPA Energy Star
    ETC VCCI-2 (Japan),C-TICK (Australia),GOST (Russia)
    Alguém tem esse monitor ou sabe algo sobre ele?
    Ajuda aí pessoal, por favor, é que o monitor chega para mim amanhã e a depender eu nem vou abrir a caixa.
    Input Signal
    aparentemente n.
    Membro Avatar de Gung@
    Gunga
    o L1950H vendido aqui no Brasil, apesar de constar no site apenas RGB, possui DVI.
    É essa que é minha dúvida, será que com esse tb ocorre isso? É que as especificações dos dois são idênticas.
    Olhem as especificações do L1950H no site da lg Brasil.
    Características da tela
    Resolução Máxima : 1280 x 1024 @ 75Hz
    Frequência Horizontal : 30 ~ 83 KHz
    Frequência Vertical : 56 ~ 75 Hz
    Características físicas
    Sinal de Vídeo : RGB Analógico (Separado)
    Conector de Entrada : 15 Pin D-Sub
    Alimentação : 90 ~ 264 Vac (47 ~ 63Hz) Fonte interna no monitor
    Dimensões (L x A x P) : 413x437x243 mm
    513x249x526 mm (Embalagem)
    Peso : 5.7 Kg (Líquido), 7.9 Kg (Embalagem)
    Cor Frontal : Prata
    Cor Traseira : Cinza Escuro
    Cor Base : Cinza Escuro
    Características especiais
    Imagem : Lightview
    Pedestal : Ajuste de altura
    Plug & Play
    DDC : DDC 2B
    Certificações
    Segurança : UL, CUL, TUV-GS, SEMKO
    EMC : CE, FCC-B
    Emissão Radiação : TCO-03
    Ergonomia : ISO 13406-2
    Economia de Energia : EPA Energy Star
    ETC : GOST, C-TICK, VCCI-2
    Garantia
    Atendimento Balcão : 1 ano
    Energia
    Normal : 45 W
    Suspenso/ Standby : 1 W
    Desligado : 1W
    Painel TFT
    Pixel Pitch : H: 0.294mm V: 0.294mm
    Tamanho : 19" ( 48,26 cm diagonal Visual)
    Brilho : 250 cd/㎡ (Padrão)
    Contraste : 500 : 1 (Padrão)
    Ângulo de Visão : H : 160˚ , V : 160˚
    Suporte de Cores : 16.2 M Cores
    Tempo de Resposta : 12 ms (Padrão)
    Email inválido
    aparentemente pelos dados! eh um bom monitor sim!...
    mas tudo depende do $$$$ quem vc pagara por ele...
    falai por quanto achou!...vamos tomar por base o custo x beneficio!
    Originalmente enviada por super3x
    Paguei R$1142,00. O preço foi bom?
    Originalmente enviada por ermail
    p/ 19 pol eu axo q sim. e por esse preço provavelmente n tem dvi msm (EU AXO, até pq 15 pin D-sub é a entrada normal.. )
    Mais esse LCD ficou por esse preço só, pois minha sogra vai trazer ele de cobija (uma cidade da muamba, tipo o PY). Na verdade eu paguei 425 dólares do monitor + 75 dólares por ter passado do limite da cota para entrar no Brasil (malditos ladrões, me cobraram 75 dólares a mais na alfândega).
    Mais é isso que estou falando, no L1950H vendido aqui no Brasil, o site diz que ele é RGB Analógico, só que na verdade ele é DVI.
    Mais esse LCD ficou por esse preço só, pois minha sogra vai trazer ele de cobija (uma cidade da muamba, tipo o PY). Na verdade eu paguei 425 dólares do monitor + 75 dólares por ter passado do limite da cota para entrar no Brasil (malditos ladrões, me cobraram 75 dólares a mais na alfândega.
    numa boa, com a sua placa de video eu vendia esse monitor à uns 1200 reais ou algo assim e pegava um crt bolado. vc n vai usar nada do potencial da placa de video se ficar limitado em 1280x1024
    O pior é que na peça que fica o meu PC não cabe CRT, eu tive até que fazer umas modificações para caber esse LCD 19" Com certeza com CRT iria ficar show de bola mais pelo menos o LCD de 19" já deve ficar legal.
    cara, compre um crt de 19" BOM por 1k~900 reais e com a sobra compre um movel novo eheuaheu
    sinceramente é a melhor opção
    É que o movel do gabinete é embutido na parede, para mexer nessa peça tem que mudar o gabinete todo, e aí $$$$$
    Email inválido
    ae manO!
    pago barato pra caralho!...e pelas caracteristicas....o monitor eh muito bom!
    relax....otima compra....
    sucesso pra vc
    Membro Avatar de daniel_cps
    e as arveres some nozes
    porra.... comprou onde ???
    manda MP
    manda MP
    Minha sogra vai trazer ele pra mim de cobija (uma cidade da muamba, tipo o PY), fica na Bolívia essa cidade. O único jeito de comprar lá é indo lá, pois fica em outro país.
    Hoje a tarde o LCD estará chegando, eu irei tirar fotos dele e do hyundai LCD 19" L90D+ de minha noiva, para eu poder fazer um pequeno review.
    Email inválido
    massa....
    manda o review pra nois ai!...
    dps vou fazer um mini review do meu tb!...
    ViewSonic Vx924
    []'s!
    massa....
    ViewSonic Vx924
    []'s!
    Hoje pela tarde eu já vou começar a postar as fotos e dados do monitor.
