    XGP - Mais ein?
    Ok ok...
    Explica ai que premio thor de marretada eh esse negocio de xgp?
    Pelo que li por ai, a biostar lancou uma placa para a64 com pci-e com um tal de xgp onde uma placa agp manda seus dados pelo barramento pci-e?
    Explica esse negocio para mim ai turma...
    Membro Avatar de Diablero
    Exorcista
    xplica vc pra nois
    qual o site da biostar?
    pci-e n. pci.
    pelo menos a maioria q eu vi é assim, fora as q usam o chipset ULI, mas ele tem agp e pci-e msm.
    pci-e n. pci.
    Ah tipo...sei la qual a diferenca. Fala portugues ^^
    Sei que chamam o troco de XGP. ^^
    Eh essa budega ai mesmo.
    Acho que vi para uma placa para a64 tb.
    Mas so da biostar's. ^^
    Dentre as placas testadas a r9800pro ta no meio ^^
    Membro Avatar de daniel_cps
    e as arveres some nozes
    TFORCE4 U
    Processor:
    AMD Athlon 64 x2 (dual core), Athlon 64 FX, Athlon 64 and Sempron processors
    • Chipset:
    NVIDIA nForce4 Ultra
    • Memory:
    4 x 184-pin DDR400 memory modules
    Maximum 4GB system memory
    Dual-channel memory architecture
    • Slots:
    1 x PCI Express 16x
    2 x PCI Express 1x
    3 x PCI
    1 x XGP (See additional info below)
    • IDE:
    Up to 4 EIDE devices
    Ultra DMA 33/66/100//133
    • I/O:
    1 x Parallel, 1 x Serial
    1 x PS/2 mouse, 1x PS/2 keyboard
    10 x USB 2.0 (4 rear, 6 front)
    6 x 7.1 channel audio jack
    1 x RJ-45 LAN jack
    1 x Floppy connector
    2 x IDE connector
    1 x Front audio header
    4 x SATA connector
    1 x IrDA
    1 x SPDIF Out
    1 x CD-in connector
    1 x System fan connector
    1 x CPU fan connector
    • SATA:
    Up to 4 SATA2 drives
    NVIDIA RAID Technology
    SATA RAID 0, 1, 0+1
    • Audio:
    Realtek ALC850 AC97 Rev 2.3 8-channel audio
    • Firewire:
    VIA VT6307
    • LAN:
    NVIDIA Gigabit MAC + VITESSE Gigabit PHY (supports 10/100/1000Base-T Ethernet)
    NVIDIA Secure Networking Engine
    Additional Info:
    Xtreme Graphics Port is Biostar's unique engineering solution of adding limited AGP graphics card support to the nForce4 chipset. The XGP slot is not compatible with all AGP cards but has been tested with AGP cards listed below.
    daniel, o q o teu post tem a ver?
    geno, q porra de placa escrota é essa? ela n tem pci-express não!
    • XGP:
    Xtreme Graphics Port is Biostar's unique engineering solution of adding limited AGP graphics card support to the Intel 845GV chipset. The XGP slot is not compatible with all AGP cards but has been tested with AGP cards listed below
    isso é um pci disfarçado em agp
    arrumei =*
    Ve essa placa ai que o daniel postou po.
    Tem o agp e o pci-e.
    Daniel..essa placa ai que vc postou eh da biostar's ne?
    Poxa..queria a opiniao da turma ai sobre esse negocio de xgp.
    Queria saber se presta mesmo hehehe.
    NF4 ultra com AGP...
    hardMOB Staff - Moderação
    AEHOOO o/
    sera se vale a pena ???
    Originalmente enviada por DARKrider
    eu chuto que não
    pra esse tipo de coisa acho que os ULI se saem melhor
    eu chuto que não
    sim. o resto é só pci disfarçado como eu falei lah em cima.
    edit:
    I just got a response from Biostar, this time with backup from their tech dept. As suggested earler, the XGP interface is based on the 33MHz PCI bus, not an independent AGP interface. As such, you can't expect much performance out of it. Sure, it'll handle the latest video cards, but at PCI speeds. So what's the use, really? If you've got a decent AGP card and want a Socket 939 MB, you aren't going to see anywhere near the card's potential with an XGP interface.
    confirmado. é pci msm.
    eu chuto que não
    Corrigindo:
    Tem placas com esse chipset com os dois barramentos? AGP e pci-e?
    Como pode?
    Se o for deve ser um absurdo de cara.
    Corrigindo:
    Como pode?
    pelo contrario. é mto barata
    e é foda overcloca p/ kct, nivel de nf4 ultra com as configs certas e algumas sorte
    edit: review
    http://www.techpowerup.com/reviews/A...39Dual-SATA2/7
    http://www.anandtech.com/mb/showdoc.aspx?i=2524&p=1
    After around 350 HTT the board started to act strange. It did no longer reboot properly, even though the rest worked fine. A solution to this was to power it off and power it on again, when it hung/crashed.
    considerando o preço dela, chegar a 350 de htt estavel e + do q isso com alungs probleminhas... tá MTO bom, concorda?
    edit: review
    POWERED BY ASROCK
    edit: review
    Se eu concordo? Nem tanto
    Quando a esmola eh D+ o santo desconfia.
    Alem d+ eh uma AsRock.
    SEi nao...^^
    SEi nao...^^
    ué, tem dois reviews a favor, tem bios modded pela ocworkbench dexando fazer um puta over... quer mais o q? um suquinho?
    SEi nao...^^
    fala assim não da asrock... eu tenho uma e gosto
    Membro Avatar de miesso
    Oct 2004
    boazinha essa mobo (asrock)
    Ok...
    MAs so tem ela com esse recurso?
    Falando nisso..onde tem essa placa para vender? ^^
    Ok...
    sim
    newegg, axo q ainda n tem no py.
