    Membro Avatar de D.O.G.
    \o\ \o/ /o/ !!!!FINALMENTE!!!! \o\ \o/ /o/
    New Intel Macs: iMac, MacBook Pro
    Tuesday, 10 January 2006
    Steve Jobs rarely disappoints.
    During his Keynote address today, El Steve announced that Apple's first Intel based computers will be the iMac and the MacBook Pro, although the entire product line will be making the transition this year (!). The iMac will be based on a dual core processor (presumably Yonah) and will be equipped with iLife 06 and iWork 06 universal binaries from the start. Pro apps will be universal by March. The software Steve demoed was running on an Intel Mac – did you expect any less? The new iMacs will be shipping today in 17" and 20" models.
    Microsoft is working on porting Office to Intel and Steve noted that they’ve worked hard to make sure that Office ran well under Rosetta. Quark unibin will be released today. On Photoshop, Steve said, “The Performance of Photoshop in Rosetta isn't going to be powerful enough for a professional ... it's fast enough for those of us who use it occasionally.”
    OS X 10.4.4 will also be released today with some new widgets. A new iLife with “photocasting” is out this morning as well.
    We’ll have full analysis of this news later today (after I watch the keynote!). Thanks to MacRumors and engadget for their live coverage of the news.
    The days of the Intel Mac are upon us.
    http://www.apple.com/macosx/
    Imaginem como seria um mundo sem a M$...
    Nossa que dah hora ... Pena que não manjo de inglês
    Jan 2004
    WTF?
    Membro Avatar de John Miller dK
    ah to com preguiça de ler....resume ai =/
    hardwaht?
    comer crua a bruschetta!
    Oct 2005
    resumindo: chegaram os novos pcs da apple com processor intel!
    Membro Avatar de respider
    2003, bitches
    tem mto mais programa pra linux que mac
    se quer livrar da MS vai pro linux que é de graça e não precisa piratear o mac
    ps: mac é mto bom também, bem melhor que windows
    o que fode é falta de variedade
    Nego ta começando a confundir boteco com hardwhat ¬¬
    E pra piorar: OLD : )
    WOW!
    Não acredito que esse dia chegou! AAAAAAAHHH finalmente!
    Melei até a bermuda aqui (tô sem cueca)
    hardwaht?
    Estava pensando a mesma coisa..
    UmK
    UmK está offline
    Re: \o\ \o/ /o/ !!!!FINALMENTE!!!! \o\ \o/ /o/
    Originalmente enviada por SweetDick
    só com a apple? ia ser ainda pior
    Nao se encaixa no hardwhat pq a intencao nao e' discutir apenas aspectos tecnicos... por exemplo: quando voce ta' bebendo num boteco e' proibido falar de informatica???? acho q aqui cabe a mesma coisa
    Galera... so' to esperando o OSX 10.4.4 estar disponivel para compra-lo!!!! uhuuuuuu!!!
    Aqui nao é um boteco, aqui é um forum de internet, tem areas separadas para cada assunto, boteco seria o off, onde fica os assuntos que nao se encaixam em nenhuma das outras areas, nesse caso o assunto se encaixa na hardwhat..
    putz mas fazer o que né, tem gente que colocou o boteco como pagina inicial da hardmob no favoritos, 60% da hardmob, só acessa o boteco, como eu disse no outro topico, o boteco está perto da independencia.
    Nao colou a desculpa do boteco... moderador aqui nao quer saber disso...
    o assunto era pra ter sido postado na hardwhat
    Membro Avatar de TheKnight | TK
    transferindo o tópico em alguns segundos...
    Membro Avatar de Arraso
    Apr 1999
    Transferido.
    Membro Avatar de Taliban
    Originalmente enviada por willywonka
    Eu sou meio leigo em hardware e não entendi mto bem a noticia.
    A apple num tem uns micros mto mais fuderosos que a microsoft??
    Pq isso seria bom??
    Só pra eu entender...
    Originalmente enviada por Taliban
    Pq isso seria bom??
    a microsoft nao faz micro, ela faz software, a apple usava uma arquitetura propria dela, e a microsoft usa pc / ibm pc (acho que é isso).
    se der pra rodar esse OS em qualquer cpu que tenha sse3, e tenha uma boa compatibilidade (se der pra rodar full no meu a64) eu até tenho coragem de comprar.
    Membro Avatar de daniel_cps
    e as arveres some nozes
    WOOWOWWOOWOWOWOW
    OS TIGER NOS PCS ????
    GUD GUD
    eu dúvido muito q a apple vai liberar o mac os pros pcs
    no máximo sai uma versão hackeada toda zuada e feita pra só uma config de pc (um proc. , uma mobo, uma vga e etc...)
    pra mim esse mac os nos pcs vai ser apenas mais uma distro de linux... (não se referindo a tecnologia)
    quer apostar que vai rodar sem problemas no pc?
    a arquitetura eh a mesma por que nao instalaria?
    Originalmente enviada por AlexandreLudolf
    Okay.
    This is the -first- installable DVD release of OSX for Intel Machines. This DVD *should* install on most any modern x86 machine.
    This ISO is for -TESTERS- and has not been widely tested accross different system configurations.
    So, your job is to report success or failure involving the install process.
    Please report your problems and or success stories to: [email protected]
    If needed, you can find bender12 and br0adband at irc.osx86project.org in the
    #osx86 channel or maybe #osx86.dvd also.
    Also, you MUST have an SSE2 or SSE3 Processor.
    Before proceeding, it might be wise to check your system specifications against *Known Working* configurations.
    This information may be found on the OSX86Project.org wiki.
    Specifically:
    http://wiki.osx86project.org/wiki/index.php/HCL - Whole Systems
    http://wiki.osx86project.org/wiki/index.php/HCLPart - Specific components
    This release includes the following
    * TPM (Trusted Platform) Crack
    * Maxxuss v0.4.1 mach_kernel SSE3 emulation
    * Modified boot files so installation can happen on most Generic x86 PCs
    eh pelo visto, nao eh tao trivial de instalar em qqer PC... SSE2 e SSE3 são o que? processadores dual core da intel?
    wkk
    wkk está offline
    oq acontece é q oa pcs da apple iram sera montados com chip intel mas todo o resto do hardware sera diferente do resto dos pcs comuns, eu vi por ae q na placa mãe
    q seria montado esse sistema teria um chip q o mac os só c instalaria com a prezença desse chip,enfim apesar do mac só funcionar em chips intel, isso nao seria posivel em qualquer frankenstem dos q todos nos temos em casa pq q placa mae usada sera vendida separada para qualquer pc
    nossa q supimpa!! eles permitiram q instalassem o mac os num pc normal!!
    mas esse beta não eh da apple... oh no!!!!! o q vamos fazer!?!?!?!
    le direito o meu post
    Originalmente enviada por Daikatana
    pode ate ser uma placa mãe made in apple, mas o que importa, que é o chipset vai ser intel tb
    Acredito que vai surgir hack pra funcionar 100% em determinados pcs.
