    Membro Avatar de ermail
    ViewSonic VA1912WB 19" Widescreen é um bom LCD? Sobre alfândega (ajuda)!
    Estou querendo comprar um ViewSonic VA1912WB 19" LCD Monitor (Black) no amazon, ficará 290 dólares com o frete até minha casa no Brasil ($230 do monitor + $60 do frete via USPS). Alguém sabe dizer se esse monitor é bom?
    Outra dúvida tem chance de eu não pagar impostos? Se eu pagar impostos ficaria por quanto? Valeria a pena mesmo pagando impostos comprar esse LCD?
    Model
    Brand ViewSonic
    Model VA1912wb
    Cabinet Color Black
    Display
    Panel Active Matrix, TFT LCD
    Screen Size 19"
    Widescreen Yes
    Display Type WXGA+
    Maximum Resolution 1440x900
    Recommended Resolution 1440x900
    Viewing Angle 160°(H) / 160°(V)
    Pixel Pitch 0.294mm
    Display Colours 16.2 Million
    Brightness 300 cd/m2
    Contrast Ratio 500:1
    Response Time 8ms
    Horizontal Fresh Rate 30~82kHz
    Vertical Fresh Rate 50~85Hz
    Connectivity
    Input Video Compatibility RGB analog (75 ohms, 0.7/1.0 Vp-p)
    Digital (TMDS, 100 ohms)
    Connectors 15-pin mini D-sub, DVI-D
    D-Sub 1
    DVI 1
    Power
    Power Supply AC 100-240V, 50/60Hz
    Power Consumption 32W (typ)
    Convenience
    User Controls Basic:
    Power, 1, down, up, 2
    OnView:
    Auto image adjust, contrast, brightness, input select, audio adjust, ViewMatch® color adjust (sRGB, 9300K, 6500K-default, 5400K, user color RGB), information (resolution, H. frequency, V. frequency, pixel clock, model number, serial number, web site), manual image adjust (H. size, H. position, V. position, fine tune, sharpness), setup menu (language, resolution notice, OSD position, OSD timeout, OSD background), memory recall
    Regulatory Approvals UL, cUL, FCC-B, CB, CE, NOM, TUV/Ergo, ICES-003, Argentina TUV/S, TUV/GS, (covers ISO 13406-2), TCO'03, GOST-R, SASO, PCBC, TUV-S, BSMI, CCC, ENERGY STAR, PSB, C-TICK, RoHS
    Adjustable Stand Tilt Adjustments
    Built in TV Tuner No
    Built in Speakers Dual integrated stereo speakers
    Features . Wide-screen experience
    . ClearMotiv™ technology
    . Dynamic Structure technology
    . High brightness and contrast
    . OSD/power lock secures your settings
    . Full 19" viewable wide screen with 16:10 aspect ratio
    . Stylish slim-bezel design
    . OnView controls for superior screen adjustability
    . Integrated power supply
    . PC and Mac compatible
    Dimensions
    Dimensions (W×H×D) 17.8" x 15.4" x 7.8"
    Weight 9.9 lbs.
    Temperature Range 32-104°F (0-40°C)
    Humidity Range 10-90% (no condensing)
    link do monitor: http://www.amazon.com/gp/product/B00...lance&n=172282
    Última edição por ermail : 21-06-2006 às 12:56
    Membro Avatar de Cardone
    Coloca mais informações do monitor...
    CMZ
    CMZ está offline
    Usuário com Pendências
    se ele tivesse dvi eu pensaria em até arriscar pedir e pagar o imposto, mas como não tem é melhor comprar no py mesmo alem de mais barato vem mais rapido =)
    Email inválido
    olha
    eu trouxe um Viewsonica VX924 dos USA....
    e paguei imposto sim....paguei os 790 dolares do monitor...mais 120 de frete...e mais 60% de impostos...mas valeu cada centavo pago....o monitor tem meros 3ms de tempo de resposta...e eh um avião literalmente...
    se precisar de maiores detalhes...vem msn...de ajudo!...[]'s
    Citação Citando ]PF[.PhoeniX
    Agora coloquei, será que vale a pena?
    Citação Citando CMZ
    Agora eu coloquei o modelo certo. Eu havia me confundido, o que eu vou comprar é o ViewSonic VA1912WB que é DVI e é 10 dólares mais barato que o não DVI Esse vale a pena?
    Citação Citando super3x
    olha
    Me tire uma dúvida, os 60% foram em relação ao preço só do monitor ou do monitor e do frete juntos?
    Email inválido
    so do monitor....
    eh o valor do produto...
    Tenta achar algum LCD que tenha painel 8-bits. Geralmente são os que possuem 16.7m de cores. Se nao achar pede ele mesmo.
    Esse tem Display Colours 16.2 Million, não seria de 8 bits? Estava vendo aqui no amazon, esse é o melhor windscreen 19" da loja que envia para o Brasil, pois nem todas as lijas filiadas no amazon enviam para o Brasil. Será que vale a pena eu trocar o meu LG 1950S por ele (o meu não é DVI e esse &#233?
    Última edição por ermail : 21-06-2006 às 13:16
    so do monitor....
    Esse monitor então ficará por quase R$1000,00. Seria um preço bom?
    Citação Citando ermail
    Esse tem Display Colours 16.2 Million, não seria de 8 bits? Se esse não for, vc sabe dizer algum modelo com um bom preço que tenha painel 8bits?
    Geralmente são os que vem com 16.7m de cores. O Dell 2005FPW 20" Widescreen por exemplo é 8-bits.
    Muito bom, vc mal compra um de 19" comum com esse preço.
    A Amazon entrega no Brasil esse monitor? Pq mesmo pagando os 60% o preço fica bom, só não da pra conseguir o rebate pq tem que morar nos EUA e eles devolvem depois de 30 dias.
    Edit: acabei de fazer uma simulação lá e essa foi a resposta:
    *** We're sorry. This item can't be shipped to your selected destination. You may either change the shipping address or delete the item from your order by changing its quantity to 0 and clicking the update button below. ( See geographical restrictions.) ***
    Depois eles falam que só esses ítens podem ser enviados para fora dos EUA:
    books*
    DVDs
    music
    VHS videos
    Última edição por Fla3DMadness : 21-06-2006 às 13:22
    Citação Citando Fla3DMadness
    Entrega sim...vc clica em "29 used & new" e depois na parte de baixo da tela que abrirá vc clica em "See all 18 New offers", aí vc procura o link para compra do (valor $229.98, o frete fica $60) aí é so clicar em add to card. Foi assim que eu comprei um cooler VF900 no amazon
    Então vale a pena comprar o monitor, não é? Ele é bom mesmo, não é?
    books*
    DVDs
    music
    VHS videos
    Dá para comprar lá sim para entregar no Brasil.
    Siga os passos abaixo para simular a compra:
    No link do produto clique em "29 used & new" e depois na parte de baixo da tela que abrirá vc clica em "See all 18 New offers", aí vc procura o link para compra do (valor $229.98, o frete ficará $60) aí é so clicar em add to card. Foi assim que eu comprei um cooler VF900 no amazon
    Ou então use esse link, que aparecerá todos os parceitos do amazon, aí vc escolhe e clica em add to card.
    link: http://www.amazon.com/gp/offer-listi...&condition=new
    Última edição por ermail : 21-06-2006 às 13:27
    Aí é muito caro pra mim Mesmo esse não sendo de 8bits será que vale a pena?
    Esse teu monitor que vc tem hoje tb não é 8bits, se vc acha que está bom assim vc com certeza vai gostar do modelo wide.
    Eu tb uso monitor de 6-bit e não acho ruim, o problema é maior pra quem trabalha com material impresso, mas de qualquer forma a gente sempre tem que fazer uma prova antes da impressão final.
    O melhor desse que quero comprar é porque ele é DVI e o meu não é...outra coisa legal é que esse é 8ms e o meu é 12ms...mais o que estou levando mais em conta para comprar esse é ele ser wide.
    Off topic: Conseguiu simular a compra da forma que falei?
    Membro Avatar de TheJokerFW
    NA verdade Ermail,
    Voce nao estara comprando diretamente da Amazon... e sim dessa loja chamada Xp Passport.. a Amazon soh ira intermediar o pagamento...
    Como ira comprar de loja a chance de nao pagar impostos eh 0.
    Os impostos sao cobrados em cima do valor do produto + Frete....ou seja... em cima de U$ 290,00.
    Mais infos em:
    http://www.receita.fazenda.gov.br/aduana/rts.htm
    Citacao:
    "Tributação
    60% (sessenta por cento) sobre o valor dos bens constante da fatura comercial, acrescido dos custos de transporte e do seguro relativo ao transporte, se não tiverem sido incluídos no preço da mercadoria.
    No caso de utilização de empresas de transporte aéreo internacional expresso (courier), será acrescentada a tributação de 18% do ICMS;"
    [ ]'s
    Eu tenho exatamente esse monitor..
    Muitcho bom! Soh fiquei triste quando vi um stuck pixel no canto esquerdo do bixin.. mas ta tranquilo, nem reparo mais no stuck..
    8ms, 300 de brilho, 500 de contraste (num eh grande coisa, mas ta bom), Widescreen, tem DVI e eh de uma exelente marca..
    E como o gbgigli disse, vai pagar imposto sobre o monitor E sobre o frete.. fazendo as contas, ainda sim, vai valer a pena!
    Citação Citando gbgigli
    NA verdade Ermail,
    Mais infos em:
    Citacao:
    "Tributação
    [ ]'s
    Daria entao uns R$1,200 ? Se for isso tá ótimo ainda.
    Fiz essa conta tb, é um preço interessante.
    O problema é falta de garantia no BR, não poder testar pra saber se tem dead/stuck pixel e o pior de todos é saber que ta pagando 60% de imposto... melhor nem imaginar quanto conseguiria pagar se alguém trouxesse de lá...
    Como jah disse antes, os modelos de 19' wide não são 8-bit.
    Utilizam a tecnoligia TN que emprega a pior qualidade de imagem, somado a angulos de visão restritos.
    Tecnologia tal como P-MVA e S-IPS podem ser encontradas em alguns monitores de 20' wide.
    Tal como: Viewsonic VX2025wm | DELL fpw2005 | Apple cinema 20' | NEC 20WMGX2 (HDMI/HDTV)
    http://www.newegg.com/Product/Produc...82E16824002319
    http://www.newegg.com/Product/Produc...82E16824116381
    Acredito que o View tenha melhor custoxbenefício
    Citação Citando BARR3L RiD3R
    Da newegg da pra incluir ainda o Sceptre Naga III por $299,99
    http://www.newegg.com/Product/Produc...82E16824112176
    Bom... vc consegue comprar aqui no Brasil mesmo, um monitor LCD de 19" response time 8ms, entrada DVI, (porém não-wide) por 1.060 reais, com nota fiscal e garantia daqui do país (o que lhe garante assistência técnica e troca rápida, caso hajam problemas). E vc recebe em 4 dias (o frete já incluso no preço citado).
    http://www.suricate.com.br/product_i...roducts_id=827
    Dae é algo a se pensar, se realmente vale a pena importar um LCD pagando 150 reais a mais, + demora, + fator garantia complicada, apenas pelo fator "widescreen".
    Vc teria que assumir os riscos - se o monitor chegar com dead pixel ou se apresentar problemas no desenrolar do uso, vc vai gastar uma quantia considerável pra fazer valer a garantia...
    E ae, vale?
