    Jan 2001
    Seagate Barracuda 7200.10 (Perpendicular Recording Technology)
    Alguem sabe algo sobre esses novos HDs ?
    Vale a pena comprar eles?
    Achei este aqui :
    Seagate Barracuda 7200.10 (Perpendicular Recording Technology) 320GB 3.5" SATA 3.0Gb/s 16MB
    http://www.newegg.com/Product/Produc...82E16822148140
    Me parece ser muito bom!
    Membro Avatar de BlackBurN_3D
    parece ser bom...
    palmas pra seagate, q sempre ta lançando coisa nova... nao estaciona com um ou dois modelos como é as outras marcas
    Barracuda 7200.10 SATA
    Model Number:ST3320620AS
    Capacity:320 GB
    Speed:7200 rpm
    Seek time:N/A ms avg
    Interface:SATA 3Gb/s
    The Barracuda 7200.10 is the largest, most reliable disc drive around. New perpendicular recording technology supports vertically stored data bits, enabling increased areal density and dependability for workstations and performance PCs. Additionally, the Barracuda 7200.10 is available in SATA 3Gb/s, SATA 1.5Gb/s and ATA/100 interfaces.
    Features Benefits
    Perpendicular Recording increases data density while decreasing moving parts for a more dependable drive.
    Serial ATA 3Gb/s (300MB/s)
    This product is configurable from SATA 1.5Gb/s to SATA 3Gb/s for easy interoperability.
    Adaptive Fly Height
    Adaptive Fly Height offers consistent read/write performance from the beginning to end of your computing workloads.
    Clean Sweep
    Clean Sweep automatically calibrates your drive each time you power up.
    Directed Offline Scan
    Directed Offline Scan runs diagnostics when storage access is not required.
    Seagate SoftSonic
    Seagate SoftSonic motor enables whisper-quiet operation.
    Enhanced G-Force Protection
    Enhanced G-Force Protection defends against handling damage.
    5 Year Warranty
    This product carries an unprecedented five-year warranty.
    É foda essa nova série, vai fundo. Dá uma pesquisada sobre essa nova tecnologia, em alguns meses vamos ter HD's além de 1Tb (o 7200.10 já vai até 750GB... Esse modelo de 320gb usa apenas 2 platters), e claro com maior densidade a transferência aumenta bastante!
    Sep 2005
    Citação Citando Chasin
    Achei este aqui :
    http://www.***************.com.br/artigos/1239
    Feb 1999
    Isso aí já é relativamente "antigo", pelo menos um ano, até tem aquele Flash animado ridículo no site deles "explicando" o que é... depois se achar posto aí.
    NEO
    NEO está offline
    Membro Avatar de NEO
    Dec 2000
    Só compraria se fosse o de 750gb
    Membro Avatar de Daniel Friedman
    Citação Citando NEO
    aproveitando o topico peguei ontem um 160GB 7200.9 e não liga.... tipo tem alguma config de jumper?? ow dei azar msm?
    Jan 2001
    O de 750GB é tecnicamente melhor que o de 320GB? Ou a unica diferença é a capacidade?
    o de 750gbs deve ter mais camadas, então o seeking time deve ser menor
    Vi umas reviews mais antigas desse 7200.10 e se não me engano perdia em vários testes de desempenho para modelos da WD.
    Me pareceu que nesse primeiro momento a vantagem é a capacidade por camada de disco mesmo, mas em desempenho não tem ainda uma evolução significativa.
    Nunca percebi alguma melhora de seeks apenas pelo fato de possuir mais platters cara, nao tive tempo de procurar algo específico, mas acho que dá no mesmo!
    O aumento de seek inerente ao dobrar o espaço é igual ao aparente ganho de se dobrar os platters. E no caso de por exemplo dois HDs de 300GB sendo que um deles tem 3 platters de 100GB e o outro, 2 platters de 150GB, o que pareceria ser mais "eficiente", 3 cabeças cobrindo 300gb contra 2, na verdade também se equivale, pois no de densidade maior as cabeças precisam percorrer menor distância pra alcançar os mesmo dados
    No fim das contas eu dou preferencia a contagem de platters menor, talvez por menor barulho/aquecimento/probabilidade de estragar
    Última edição por |nobre| : 28-06-2006 às 11:25
    Jan 2001
    Entendo.
    É que estou precisando comprar um HD novo, ai vi este modelo e me interessei.
    Na verdade quero comprar algo pra nao me encomodar. Estou montando uma maquina nova (boa e potente), e quero escolher um HD bom e com uma capacidade significativa. Os raptor estão fora de opção pelo preço.
    Alguem me sugere algum HD em especifico?
    Membro Avatar de TheJokerFW
    Vou ter 5 unidades deste HD ateh o inicio da prox semana
    Se tiver interessado depois me de um toque...
    Irei pegar 1 pra mim e realizar testes tbem!
    Abracos
    Última edição por TheJokerFW : 20-07-2006 às 13:32
    Membro Avatar de firefox
    Kilauea
    Citação Citando gbgigli
    Abracos
    o de 750??
    Dec 1999
    Abracos
    Tenho interesse dependendo do preço.
    É o de 350, né ?!
