    Configurar Memoria para Desempenho
    Eu comprei 2 pentes de memoria KINGSTON de 512 DDR 400 daqueles que vem próprio pra dual channel e coloquei na minha maquina... essa da assinatura... Queria saber como configurar as memorias na bios para melhorar o desempenho. Tem varias configurações lá de memoria na bios, mas nao entendo nada...
    Alguem pode me dar uma luz ?
    Ai embaixo segue dados do CPU-Z
    CPU(s)
    Number of CPUs 1
    Name AMD Athlon 64 3000+
    Code Name Venice
    Specification AMD Athlon(tm) 64 Processor 3000+
    Family / Model / Stepping F F 2
    Extended Family / Model F 2F
    Brand ID 4
    Package Socket 939
    Core Stepping DH-E6
    Technology 90 nm
    Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, SSE3, x86-64
    CPU Clock Speed 1852.8 MHz
    Clock multiplier x 9.0
    HTT Bus Frequency 205.9 MHz
    L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
    L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
    L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
    L2 Speed 1852.8 MHz (Full)
    L2 Location On Chip
    L2 Data Prefetch Logic yes
    L2 Bus Width 128 bits
    Mainboard and chipset
    Motherboard manufacturer Gigabyte Technology Co., Ltd.
    Motherboard model GA-K8N-SLi,
    BIOS vendor Award Software International, Inc.
    BIOS revision F7
    BIOS release date 02/08/2006
    Chipset nVidia nForce4 rev. A3
    Southbridge nVidia nForce4 MCP rev. A3
    Sensor chip ITE IT8712
    Graphic Interface PCI-Express
    PCI-E Link Width x16
    PCI-E Max Link Width x16
    Memory
    DRAM Type DDR-SDRAM
    DRAM Size 1024 MBytes
    DRAM Frequency 205.9 MHz
    FSBRAM CPU/9
    CAS# Latency 3.0 clocks
    RAS# to CAS# 3 clocks
    RAS# Precharge 3 clocks
    Cycle Time (TRAS) 8 clocks
    Bank Cycle Time (TRC) 11 clocks
    DRAM Idle Timer 16 clocks
    Command Rate 2T
    # of memory modules 2
    Module 0 Kingston DDR PC3200 - 512 MBytes
    Module 1 Kingston DDR PC3200 - 512 MBytes
    Software
    Windows version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
    DirectX version 9.0c
    Última edição por psytrancebr : 11-07-2006 às 22:57
    Upa! Ninguem ?
    voce pode mudar:
    CAS# Latency 3.0 clocks -> para 2.5 na bios
    Command Rate 2T -> para 1T na bios , este item pode vir como Command Rate, CPC On/off (on é 1T), etc
    esses dois itens já vao melhorar bastante a performance
    valeu pela dica... vou testar... to no trabalho agora... qd chega em casa eu vejo
