    Monitor Ergo Hewlett Packard 1600
    Gostaria de saber se vale a pena comprar este monitor por 500 reais. Quais são as desvantagens em relação aos monotores tela plana, flatron, etc.
    Tô na dúvida!
    Hewlett Packard HP Ergo 1600
    Hewlett-Packard built high performance, reliability and innovative features into this professional-level 21-inch display. The Hewlett-Packard monitor is a great choice for professional users who run high-end business and design applications that require more workspace, sharper picture and higher refresh rates. Hewlett-Packard monitors are optimized to run on HP CPUs, but are also suitable for other branded computer systems. This 21-inch color monitor supports a 1600x1200 high resolution. It's matched with an anti-reflective, anti-static coating to yield high-end crisp, bright contrasted images. This combination of features produces the sharp, clear images required for advanced applications. The on-screen display with digital controls uses an illustrated approach for easy and precise picture adjustments, including color level, color temperature, tilt, zoom, and geometry controls.
    General
    Display Type Display / CRT
    Width 50.5 cm
    Depth 51.9 cm
    Height 48.7 cm
    Weight 27 kg
    Enclosure Colour White
    Localisation English / Europe
    Compatibility PC
    Display
    Diagonal Size 21"
    Viewable Size 20.0"
    Dot Pitch / Pixel Pitch 0.25 mm
    Max Resolution 1600 x 1200 / 75 Hz
    Max Sync Rate (V x H) 150 Hz x 95 kHz
    Factory Preset Resolution Modes
    Front Panel Controls Power on/off, OSD-position
    On-Screen Controls Contrast, brightness, H/V-position, H/V-size, pincushion distortion, degauss, trapezoid, parallelogram, colour temperature selection, reset settings
    Interface VGA (HD-15)
    Image Colour Temperature Adjustable
    Video Input
    Analogue video Signal RGB
    Expansion / Connectivity
    Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15)
    Miscellaneous
    Cables Included 1 x display cable
    1 x power cable
    Compliant Standards Plug and Play, FCC Class B certified, CE, MPR II, CSA, UL, TUV GS, DHHS, EN 60950, EN55022, EPA Energy Star, ISO 9241, NEMKO, NUTEK, PTB, TCO '92, VCCI-II
    Power
    Form Factor Integrated
    Voltage Required AC 110/220 V ± 10% ( 50/60 Hz )
    Power Consumption Operational 160 Watt
    Power Consumption Stand by / Sleep
    8 Watt
    Imagens Anexadas
    Mar 2001
    Acho q não vale a pena não hein, 500 reais nem tela plana eh o esquema. Espera mais uns 3 meses e compra um LCD de 17 que ja vai ta uns 500
    Um Pai de Familia
    Oct 2005
    Membro Avatar de senomaR
    Nops, não vai baixar mais do que está... a tendência é até uma pequena alta nos preços...
    Ao menos é o que dizem os especialistas...
    Citação Citando DarkWolf
    pois então... na verdade nem é 500 é 600 pila +-
    É que assisto filmes pelo computador e queria um monitor beeem grande... 17 não me serve...talvez um 19 wide viria bem!
