    AB9 e AB9 Pro
    Ae pessoal
    La vo eu com mais um topico nb. Mas tudo bem.
    Qual o grande diferencial da AB9 Pro que faz o pessoal comprar só essa e se esquecer da AB9 normal?
    Li as especificações la no site da Abit e vi que tem diferenças, mas qual delas é importante? Pra mim, acho que nao preciso de nenhum desses extras da Pro, ou preciso??
    SPECS AB9 normal
    Processor
    Support Intel Core 2 Duo Pentium® & Pentium® D processors with1066/800MHz FSB
    Support Intel® 2006FMB Conroe CPU
    Chipset
    Intel® P965 / ICH8 Chipset
    Memory
    4 X 240-pin DIMM sockets support max. memory capacity 8GB
    Supports Dual channel DDR2 800/667/533 Un-buffered Non-ECC memory
    LAN
    On board Gigabit Ethernet
    Audio
    On board 7.1 CH HD Audio CODEC
    Supports auto jack sensing and optical S/PDIF Out
    Expansion Slots
    1 x PCI-E X16
    2 x PCI-E X1
    2 x PCI
    Internal I/O
    1 x Floppy Port supports up to 2.88 MB
    1 x Ultra DMA 100/66/33 IDE connector
    6 x SATA 3Gb/s connector
    3 x USB header (support 6 ports)
    1 x FP-Audio, 1 x CD-In
    Back Panel I/O
    1 x PS/2 Keyboard, 1 x PS/2 Mouse
    abit Silent OTES™
    1 x S/P DIF In, 1 x S/P DIF Out
    7.1 CH Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround)
    4 x USB 2.0, 1 x RJ-45 LAN connector
    Serial ATA
    4 x SATA 3Gb/s through Intel® ICH8
    2 x SATA 3Gb/s through JMicron® JMB363 support up to 0,1 ,JBOD RAID function
    Form Factor
    ATX form factor 305 x 245mm
    PCB Color: Orange
    RoHS
    100% lead-free process and RoHS compliant
    abit Engineered
    abit SoftMenu™ Technology
    abit μGuru™ Technology
    abit Silent OTES™ Technology
    SPECS AB9 PRO
    Processor
    Chipset
    Intel® P965 / ICH8R Chipset
    Memory
    LAN
    On board Dual PCI-E Gigabit LAN controller supports 10/100/ 1000M Ethernet
    Audio
    Expansion Slots
    1 x PCI-E X16
    2 x PCI-E X1
    2 x PCI
    Internal I/O
    9 x SATA 3Gb/s connector
    Back Panel I/O
    abit Silent OTES™
    1 x S/P DIF In, 1 x S/P DIF Out,
    1 x eSATA
    4 x USB 2.0, 2 x RJ-45 LAN connector
    Serial ATA
    6 x SATA 3Gb/s offer by Intel® ICH8R support Intel® Matrix Storage Tech(AHCI & RAID 0/1/5 /10)
    2 x SATA 3Gb/s offer by JMicron® JMB363 support up to 0,1,0+1,JBOD RAID function
    1 x SATA 3Gb/s offer by Silicon Image 3132 to 0,1,0+1,JBOD RAID function
    Form Factor
    PCB Color: Orange
    RoHS
    abit Engineered
    hardMOB Staff - Moderação
    AEHOOO o/
    eu comprei uma ab9 normal, eu acho q ate q a normal vende muito mais q a pro ...
    a diferença de OC da AB9 pra AB9-PRO é zero. A "grande" vantagem da AB9 é o E-SATA, 3 portas SATA a mais e o dual Gigabit.
    Fora isso... não muda nada.
    nao usaria E-SATA, nem 3 portas Sata a MAIS e o dual Gigabit nao sei o que é.
    Que que é dual Gigabit? O que muda pro Gigabit sem dual? fora a palavra..
    aBS!
    Membro Avatar de igoro
    A PRO tem sistema de resfriamento melhor (heatpipes) e usa chipset ICH8R com suporte a RAID.
    E detalhe que no PY a PRO sai $10 doletas mais cara que a non-PRO. Por aqui, acredito que a diferença não deve chegar nem a R$ 50.
    EDIT:
    Dual Gigabit: Na non-PRO só vem uma porta de rede, e na PRO são duas.
    Última edição por igoro : 02-01-2007 às 17:55
    Citação Citando igoro Ver mensagem
    ? AB9 tb tem heatpipe.
    Membro Avatar de Cherno Alpha
    U.S.S.R.
    AB9 Pro. Muito mais C/B por ser uma mobo com perfil "Deluxe". Quem tem a AB9 simples comprou só por falta de opção, pq desde que chegou a PRO no PY deixou de ser "menina dos olhos" dos grana-curta (como eu ) aqui do forum. Eu tenho uma, compre sem pensar, pois é um monstro.
    Opa, vamo la, RAID tambem nao uso...
    Acho que a AB9 ja ta suficiente viu...
    OPINIOES???
    Citação Citando Dale Ver mensagem
    OPINIOES???
    Com ctz a AB9 é suficiente, mas no PY pelo menos as duas estão pelo mesmo preço, então pq não pegar a Pro? Eu peguei a AB9 pq na época não tinha a Pro por esse preço, se tivesse eu teria pego.
    Se ta o mesmo preço é claro que se deve levar a PRO por causa do ICH8R (q é "menos pior", mas também eh uma bosta como o ICH8).
    Po galera valeu aí!!
    Com certeza vou ficar com a Pro, nunca tive heatpipes :O
    To bem decidido, to só esperando alguma promoção pós Natal...
    alguem sabe de algo rolando aí? hehehehe...
    AbS valeu aeeeeeeee
    U.S.S.R.
    AbS valeu aeeeeeeee
    ow, a AB9 simples tb tem heatpipes. AB9 Pro = ICH8R + 9 SATA + E-SATA + Duas portas Gigabit
    Ahm... tinha entendido diferente. Bom, mas mesmo assim, se o chip aí é melhor e ainda vem com duas "placas" de rede vale a pena. Até na hora de revender.
    Valeus
    Membro Avatar de Lord Magus
    Além do preço ser quase o mesmo né =P
    gigabit é uma placa de rede que transfere a 1 Giigabit por segundo(teoricamente)
    A AB9 PRO vem com 2 desses equanto a AB9 vem apenas com 1.
    PS: realmente já postaram que a AB9 PRO tava com preço menor ou igual o da AB9. Sendo assim vai na AB9 PRO.
    So uma duvida, as duas sao da mesma controladora?
    bizzaro a PRO custar menos q a nao-pro o.O
    uma "bosta" pq? e o "R" é "menos pior" pq suporta raid? qual que é bom?
    Citação Citando zuelber Ver mensagem
    Pega o datasheet dos ICH8 e se assusta... a Intel por exemplo removeu suporte a diversos features dentre eles o NCQ nos ICH8.
    O ICH8 nao tem suporte a IDE-PATA, nao tem suporte a AC'97, nao tem suporte a um bando de coisa, eh um southbridge capadissimo e que por exemplo aqui em casa ja me deu MUITO problema.
    O NCQ inclusive no ICH8R que tem NCQ só é ligado qndo o RAID entra em ação, oq não é viavel para todos os usuarios.
    Por ter removido o suporte a PATA passou a ser um inferninho pra gente aqui no BR que nao tem acesso a DVD+-RW SATA, fazer qualquer coisa, performance ridicula usando a controladora externa, falta de drivers, problemas de performance, etc etc etc, levei 3 dias pra instalar o Windows aqui por problemas com a controladora!
    o ich8 é triste mesmo..
    também estou com diversos problemas.
    ter removido o suporte ao PATA foi precipicitação total, mas que aki eu nunca tive problema com o JMicron (so tenho um DVD nele e drivers do windows update) uso o raid do ICH8R e uma Audigy2 ZS velha de guerra
    todos esses problemas que vc citou podem acontecer com o ICH8R tb? se nao, é mais um motivo pro criador do topico pegar a PRO
    edit: o ICH8 fica como low-end e o R como high?
    Última edição por zuelber : 03-01-2007 às 13:53
    é, entao, to ficando com medo desse papo de PATA e DVD RW SATA.. coisas que eu nao tenho, eu uso IDE normal. Se o ICH8R for melhor e der um suporte a essas coisas eu fico com a PRO, se ele for capado tambem ai eu vou de Asus né... 100 reais a mais e eu pego a P5B que ninguem reclama dela
    Membro Avatar de AccellX®
    A asus tbm usa o mesmo southbridge... ou seja, a mesma porcaria da Intel..
    A Intel realmente sabe granhar dinheiro.. capa tudo oq pode.. e manda pra vender.. o pior eh que capricha de um lado e piora do outro.. dai ela fica sozinha no mercado e fode tudo..
    Vamos torcer pros concorrentes (680i e rd600) façam alguma coisa descente em termos de preços....
    Sim podem acontecer com ICH8R sim, ambos nao funciona NCQ sem RAID, logo esqueça o suporte a NCQ
    Ambos nao tem IDE, logo tem q usar a controladora externa...
    Sobre o AC'97 eu sei q nao tem (li no Datasheet), mas pra isso eu caguei, também uso uma Audigy2 ZS.
    Sobre ser high end ou low end, nao sei nao...
    AEHOOO o/
    e tudu uma merda nessa ab9 e ab9 pro, to com medo serissimo dela, vou montar o c2d no minimo semana q vem... to vendo q vai dar merda e das grandes... :/
    comecei a me cagar tb
    agora ja nao sei mais nada
