    Membro Avatar de andrepmrj
    nvidia news 8600 GT & GTS
    CeBIT 2007 : NVIDIA GeForce 8600GT Photos Review
    Bluetooth 11 March 2007
    Introduction
    NVIDIA is slated to announce this new DX10 graphics card soon. Before you head over to CeBIT, here is the specifications of the card and photos of the card.
    The GPU used is labelled G84-300. The GPU clock runs at 540MHz and GDDR3 at 1400MHz. G84 does not support HDCP. There is another version G84-305 comes with HDCP support.
    The 8600GT is supposed to take over the mainstream market of the 7600GT and 7600GS from May 2007. There will be 128M and 256MB versions of the 8600GT cards. Both cards will support GDDR3 128bits Dual DVI, HDTV and HDCP.
    The card looks like the normal 7600GT. THere is no 6 pin aux power connector. There is two DVI-I and a SLI connector Slot on top.
    The 8600GT and 8500GT will be announced on the same day but will be on sale from 1st may 2007.
    Pricing of 8600GTS is around $200-250
    8600GT is around $150-180
    8500GT is around $90
    8600GT:
    8600GT vs 8600GTS
    CeBIT 2007 : NVIDIA GeForce 8600GTS Photos Review
    Introduction
    The GPU used is labelled G84-400. The GPU clock runs at 675MHz and GDDR3 at 2000MHz. The card is HDCP Ready.
    The DX10 card, 8600GTS is supposed to take over the performance market of the 7900GS and 7950GT. from 17 Apr 2007. There will be 256MB and 512MB versions of the 8600GTS cards. Both cards will support GDDR3 or GDDR4 128bits and comes with Dual DVI, HDTV and HDCP.
    The card is slightly longer than the 8600GT. It also comes with a 6 pin power connector. There are two DVI-I and a SLI connector Slot on top.
    The 8600GTS will be announced and available from 17 Apr.
    POSTADO POR VALHALLA NO BF2 BRASIL.
    Nada de benchs
    Membro Avatar de firefox
    Kilauea
    e q caiam os precos das 7xxx hehehe
    vai ser na hora certa
    Membro Avatar de daniel_cps
    e as arveres some nozes
    maneiro...
    quero ver benchs da 8600GTS contra a 7950GT e a minha X1950XT...
    Membro Avatar de Mahoney
    Citação Citando firefox.hacker Ver mensagem
    Nem sei se vai compensar. Por que há rumores da 8600GT ser superior a 7900GT.
    Citação Citando daniel_cps Ver mensagem
    maneiro...
    Quero saber disso também hehe
    To de olho nelas!
    Kilauea
    Citação Citando Giminitrous Ver mensagem
    se for por isso, melhor ainda, esse valor ta muito bom e ainda mais sendo superior e com direct novo, demogou, camagada hhehe
    Deve ficar um pouquinho pior qua a 7950GT eu acho... Mas DX10, e consumindo menos aparentemente.
    Membro Avatar de Peleyer
    128bits na memoria, mas roda a 2000mhz...
    essa 8500GT, bom preço, mas sera que o dempenho vai ser como uma 7600GT por exemplo?
    Membro Avatar de Arraso
    Apr 1999
    8500GT me parece ser uma 8600GT com memórias DDR2 e cooler passivo.
    Então deve ser melhor que 7600GT sim.
    o fato de nao precisar de alimantação extra ja me deixa satisfeito
    nao ter que trocar de fonte \o/
    eu bem queria essa gts. mas com minha TT 430 com 18a em UMA 12v acho que nem vai rolar! =/
    Membro Avatar de Cardone
    Se essa 8600GT realmente for superior a 7900GT, vai haver uma queda felomenal nos preços.
    Membro Avatar de Lord Magus
    Que é o que aconteçe todo ano... 7600GT > 6800 Ultra. 6600GT > 5950 Ultra... E por ai vai =P
    Membro Avatar de Proper
    Belém-PA
    Dúvido que a 8600 GT seja superior a 7900 GT. A 8600 GTS eu acredito que sim.
    Citação Citando Proper Ver mensagem
    hehe sinceramente eu espero que não.
    Desse jeito vo ter que vender logo minha 7900GTX pra não desvalorizar mais ainda
    eu acho que elas vao ficar no pareo.
    assim como a 7600GT é pouca coisa melhor que uma 6800GT e pau a pau com uma 6800U
    enfim. eu espero e MUITO que ela pelomenos se iguale a 7900GT. e acho que a 8600GTS va se igualar a uma 7950
    Membro Avatar de Cherno Alpha
    U.S.S.R.
    No PY devem chegar a US$ 260, 210, 130 respectivamente... alguém discorda?
    Membro Avatar de neptune
    Jul 2006
    só espero que não pulem a 8900, ou que demorem pra lançar a série 9..
    queria ver também GDDR4 nas placas logo, mas acho que vai demorar um tempinho, as primeiras devem ser com gddr3 ainda
    tem uma 8800 Ultra no .inf do driver mais novo, além de umas outras
    NVIDIA_G80.DEV_0191.1 = "NVIDIA GeForce 8800 GTX"
    NVIDIA_G80.DEV_0193.1 = "NVIDIA GeForce 8800 GTS"
    NVIDIA_G80.DEV_0194.1 = "NVIDIA GeForce 8800 Ultra"
    NVIDIA_G80.DEV_019E.1 = "NVIDIA Quadro FX 4600"
    NVIDIA_G84.DEV_0400.1 = "NVIDIA GeForce 8600 GTS"
    NVIDIA_G84.DEV_0402.1 = "NVIDIA GeForce 8600 GT"
    NVIDIA_G86.DEV_0421.1 = "NVIDIA GeForce 8500 GT"
    NVIDIA_G86.DEV_0422.1 = "NVIDIA GeForce 8400 GS"
    NVIDIA_G86.DEV_0423.1 = "NVIDIA GeForce 8300 GS"
    Citação Citando marciopl Ver mensagem
    Pular as 8900? Acho dificil tem que ver o R600 como vai ser, fora que GDDR4 também acho que vai demorar e muito... o custo fala mais alto, so na next gen GDDR4.
