    Erro ao gravar / apagar dados de um DVD+RW *Novo*
    Boa noite pessoal !
    Não sei se alguém aqui já teve problemas com mídias zerinho de DVD+RW ?
    Tudo que vou gravar dá erro e se eu quiser apagar também da erro. Meu gravador é um Pioneer DVR-112DBK Preto e já comprei com a última versão do firmware.
    O log do erro é este:
    8:40:30 #15 Text 0 File Cdrdrv.cpp, Line 9234
    ---- DVD Structure: Physical Format Information (00h) ----
    Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
    Book Type: DVD+RW (9), Part Version: 1.1x (2)
    Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
    Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable
    Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
    Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
    End Physical Sector Number of Data Area: 26053F h
    End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
    Data in Burst Cutting Area (BCA) does not exist
    Disc Application Code: 0 / 0 h
    Extended Information indicators: 1 h
    Disc Manufacturer ID: INFODISC
    Media type ID: A10
    Product revision number: 1
    Number of Physical format information bytes in use in ADIP up to byte 63: 57
    Media Specific [16..63]:
    00 00 01 49 4E 46 4F 44 - 49 53 43 41 31 30 01 39 ...INFODISCA10.9
    23 00 9C 7C 5C 02 28 00 - 96 7E 70 02 28 00 9C 7B #..|\.(..~p.(..{
    68 02 28 04 04 20 E0 00 - F0 00 00 00 00 00 00 00 h.(.............
    8:40:30 #16 Phase 98 File dlgbrnst.cpp, Line 1746
    Start formatting disc before burning
    8:40:30 #17 SPTI -1065 File SCSIPassThrough.cpp, Line 179
    CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1065)
    Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x20
    Sense Qual: 0x00
    CDB Data: 0x04 11 00 00 00 00 00 00 00 00 00 00
    Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 20
    Buffer x04c3e8c0: Len xc
    0x00 82 00 08 00 23 05 40 98 00 00 00
    8:40:30 #18 Phase 101 File dlgbrnst.cpp, Line 1746
    Formatting disc failed
    8:40:30 #19 Text 0 File DVDPlusRW.cpp, Line 674
    Start write address at LBA 0
    DVD high compatibility mode: Yes
    8:40:30 #20 CDR -1065 File ThreadedTransferInterface.cpp, Line 1779
    Invalid command
    F: PIONEER DVD-RW DVR-112D
    8:40:30 #21 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1779
    Could not perform start of Disc-at-once
    8:40:30 #22 Phase 38 File dlgbrnst.cpp, Line 1746
    Burn process failed at 2.4x (3,324 KB/s)
    Alguém sabe o que pode estar passando ? Nenhum outro software funciona, não é apenas o Nero.
    Última edição por CoCoZeTa :o) : 28-03-2007 às 21:43 Motivo: Mudar o título para DVD+RW ao invés de DVDRW
