    Membro Avatar de Onilink
    Pescador de Caranguejo
    Jan 2006
    DDR2 de 333mhz, wtf?
    Salvem caros.
    Report do meu PC novo no PCWizard:
    Information SPD EEPROM (DIMM0) :
    Manufacturer : Unspecified
    Part Number : 515230125641351700
    Serial Number : E4511756
    Type : DDR2-SDRAM PC2-5300 (333 MHz)
    Format : Regular UDIMM (133,35 x 3)
    Size : 1024 MB (1 ranks, 4 banks)
    Module Buffered : No
    Module Registered : No
    Module EPP : No
    Width : 64-bit
    Error Correction Capability : No
    Max. Burst Length : 0
    Refresh : Reduced (.5x)7.8 µs, Self Refresh
    Voltage : SSTL 1.8v
    Prefetch Buffer : 4-bit
    Manufacture : Week 35 of 2007
    Supported Frequencies : 200 MHz, 266 MHz, 333 MHz
    CAS Latency (tCL) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @333 MHz
    RAS to CAS (tRCD) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @333 MHz
    RAS Precharge (tRP) : 3 clocks @200 MHz, 4 clocks @266 MHz, 5 clocks @333 MHz
    Cycle Time (tRAS) : 9 clocks @200 MHz, 12 clocks @266 MHz, 15 clocks @333 MHz
    Min TRC : 12 clocks @200 MHz, 16 clocks @266 MHz, 20 clocks @333 MHz
    Information SPD EEPROM (DIMM2) :
    Serial Number : 72581756
    Module EPP : No
    Width : 64-bit
    Voltage : SSTL 1.8v
    A memória que eu comprei é xing-ling, sofreu um downclock, ou esses dados não mostram nada? O.o
    Membro Avatar de Cherno Alpha
    U.S.S.R.
    é só multiplicar por 2
    Jan 2006
    Citação Citando Apoca Ver mensagem
    I'm noob
    Valeu ae mano, verdinhas pra tu, podem fechar o tópico.
    Membro Avatar de cLIX
    Double Data Rate
