    Mar 2006
    Como ligar audio frontal na C51GM-M?
    No manual está escrito assim:
    1 AUD_MIC Front Panel Microphone imput signal
    2 AUD_GND Ground Used by Analog Audio Circuits
    3 AUD_MIC_BIAS Microphone Power
    4 AUD_VCC Filtered +5v used by Analog Audio Circuits
    5 AUD_F_R Right Channel audio signal to Front Panel
    6 AUD_RET_R Right Channel Audio signal to Return from Front Panel
    7 REVD Reserved
    8 Key No Pin
    9 AUD_F_L Left Channel audio signal to Front Panel
    10 AUD_RET_L Left Channel Audio signal to Return from Front Panel
    Os conectores do gabinete são 7:
    MIC IN (R)
    GND
    MIC POWER (L)
    Line out FR
    Line out RR
    Line out FL
    Line out RL
    Liguei eles assim, vejam se está correto:
    MIC IN (R) 1
    GND 2
    MIC POWER (L) 3
    **(não tem este pino no gabinete)** 4
    Line out FR 5
    Line out RR 6
    **(Reserved)** 7
    **(Não tem este pino no conector)** 8
    Line out FL 9
    Line out RL 10
