Página 1 de 3 1 2 3 Última
    UmK
    UmK está offline
    AMD's 3GHz K10 to break 30,000 3DMark06
    a fonte não é das mais confiadas por muitos, mas mesmo assim:
    http://www.theinquirer.net/?article=41970
    The particular processor was none other than a single socket Barcelona or Agena FX, call it what you will. The reference motherboard containing RD790 chipset packed two HD 2900XT cards, and the memory installed was Corsair’s Dominator PC2-9136C5D, or the same ones we have been using ever since they came out. There was a Raptor hard drive, and that was about that. OCZ will like the fact that PP&C Quaddie CrossFire PSU was installed in the system.
    Windows Me II (Vista) Ultimate was installed as the operating system of choice. For some odd reason, the 32-bit version was installed in a system with 4GB of memory, needless to say the system detected 3.24GB, and benchmarketing commenced.
    When running at 2.5GHz, the 3DMark06 score ended at 23.768, so we were thrilled to see such a good score coming from two 512MB cards. This showed the clear potential of this four core processor marchitecture, but the helter skelter ride happened after we overclocked the processor to 3.0GHz.
    When clocked at 3.0 GHz and equipped with two overclocked HD2900XT cards in CrossFire, Agena FX or single-core Barcelona smashed an index of 30,000 3DMarks 06. Yes, you’ve read it right - the barrier of 30,000 was passed to, barely, 30.031
    parece que a corrida de revesamento vai ter um novo líder novamente. bom pra mim. vo comprar mesmo um x2 4000+ e depois upgradar pra um desses cavalos ae.
    estranho é não ter nenhum tópico sobre isso aqui ainda
    tava querendo ver a reação do pessoal q enterrou a AMD antes da hora
    Blá
    soh acredito vendo
    e otra
    um C2D overclokado gargla alguma placa d video existente?? O.o
    eu axava q nao
    mas vamo ver, tem os Penryn da intel tb
    tomara q esse K10 seja td issu q falaram ae mesmo
    e ate agora n tem reacao de ninguem, fonte nada confiavel
    issu ae ker dizer qse nada
    é bom mesmo que seja metade do que eles estão dizendo. Caso contrário, pode chamar o coveiro.
    Previsão de lançamento ?
    Membro Avatar de toledo
    Citação Citando UmK Ver mensagem
    Nao tem nada por que e rumor ... . Esperando pra ver .
    Dá pra ter credibilidade? Não dá... parece uma criancinha de 12 anos postando...
    Ai ai Windows ME II, nota-se claramente o calibre do cara que postou esse lixo
    E ainda manda a perola dos 4Gb! Até meu pai sabe que 32bits não mapeia 4Gb de RAM.
    Membro Avatar de Diablero
    Exorcista
    deve ser mentira mesmo.
    mas o socket dos barcelonas vai ser AM2 ??
    Membro Avatar de Cherno Alpha
    U.S.S.R.
    Se o cara acha o Vista uma merda, ele foi criativo em chamar de Windows ME 2 pq sim, o ME era como vc disse, parece que foi feito por uma criancinha de 8 ao invés de 12 anos.
    Ele colocou os 4 GB mas ressaltou que só os 3.24 são usados.
    Logo, pq a notícia não tem credibilidade?
    PS.: Talvez tenha entendido o que o cara quis dizer por tb achar o Vista ruim, mas não ao nível de um ME...
    Não entendi o problema, pelo que entendi ele só comentou que o sistema que disponibilizaram para eles estava com 4GB de RAM mas estranhamente com um S.O. de 32 bits e que por isso não estava mapeada toda a ram, e que acharam isso estranho e passível de ser comentado... Nada demais.
    E eu ri de Windows ME II... ehehe
    Blá
    estranho?
    eh completamente entendivel o pq dele n mapear 4Gb
    e um carinha q solta issu na net deveria saber como issu funciona, ate pq eh muito simples
    como q alguem n sabe como funciona o endereçamento de memoria posta o primeiro bench de um aguardado proc?
    pra mim issu n tem credibildiade nenhuma
    uhahuahua pessoa fica de briguinha invés de esperar pra ver!
    Jun 2007
    Citação Citando ||JONY||__KoK Ver mensagem
    estranho?
    Vc não traduziu isso errado não cara?
    "For some odd reason, the 32-bit version was installed in a system with 4GB of memory, needless to say the system detected 3.24GB, and benchmarketing commenced."
    "Por alguma razão estranha, instalaram a versão 32bits numa maquina com 4gb de memória; obviamente, isso implica que o sistema apenas detectou 3.24gb."
    Não quer dizer que ele não sabia que o OS 32 bits não ia mapear 4gb; mas sim que apenas ele não teve a mão de obra de eliminar o OS 32bits e instalar o vista 64!
    Blá
    tava me referiundo ao post do hinotori
    hehehehe
    Membro Avatar de JimMorrison
    Nada de errado na minha opinião.... o dito site é tão famoso por seus fakes qto a AMD com suas já quase eternas promessas do K10, ou seja, normal pros dias atuais.
    opções:
    1- fake
    2- 3dmark05(forçando a barra, jah que precisa de um C2D a 4.9Ghz+- pra fazer esse score com 2 HD2900XT)
    3- Quad Cross-Fire
    E tem outra coisa que nao bate.. como 20% a mais de clock em um processador pode gerar 25% a mais de pontos em um 3dmark?
    Citação Citando VUDENTZ Ver mensagem
    opções:
    1- fake
    3- Quad Cross-Fire
    Bom...o kra disse q eram duas HD 2900XT, intaum eliminamos a 3ª
    Eh trivial q a 2ª eh descartavel, pois ele citou 3DMark06 varias vezes, fora q seria dificil acreditar q um C2D 4.9Ghz seria superado por algum processador single-core em 3Ghz
    Axo q soh sobra a 1ª
    E qnt a sua pergunta...eh 20% de oc no processador + overclock das HD 2900XT em 830/900
    Citação Citando Apoca Ver mensagem
    Você sabe como que o Windows ME funciona? E sabe pq ele foi esculaxado, detonado e chamado de merda?
    Essa do ressaltou foi foda, um cara ta fazendo um "teste" desse calibre e deveria saber o que fazer num sistema de 4Gb, e mais pra que 4Gb nesses benchmarks?
    Membro Avatar de TM99
    Pikachu, vc obviamente nao le o Inquirer e pertence a turma dos que tem preconceito contra qualquer informação que eles divulguem. Sugiro que passe a ler o site, pq eles acerta MUITO MAIS DO QUE ERRAM.
    Anyway o site é famoso por fazer piadinhas (é um tipo de jornalismo divertido e as vezes mata vc de rir quando vc ta lendo), tipo o proprio ME II e Chipzilla (intel) Graphiczilla (Nvidia) Chimpzilla (AMD), Vole (Microsoft) e por ai vai..
    Fato que o cara mencionou que era OBVIO que o OS 32 bits nao ia mapear os 4gb de ram, alguns entenderam errado.
    Outra coisa, ninguem parece que sacou, mas o Barcelona/Phenom é quad Core, e como usa a controladora integrada fodona dele, ele usando DDR2 800 tem mais bandwith de memoria do que qualquer core2duo com DDR3. No teste eles overclocaram o Phenom pra 3ghz, o bus HT da memoria foi la pra 1066, oque deu mais de 11gb/s de bandwith (o maximo que o core duo anda pegando eh 8-9 e isso com over pra caralho no FSB).
    Eu não duvido nem um pouco desse processador ter IPC maior que o core duo, povo ja comenta isso a meses... Agora ninguem sabe é quantos %.
    Como o Phenom vai ser 65nm ele vai ter algumas limitações de clock se comparado ao penry. Ainda assim vai ser um puta processador e é o motivo pra mim estar migrando pra plataforma AM2 ao invés de ir de intel.
    Não sei se vai ser salvador da AMD, mas com certeza vai ser bom o suficiente pra segurar o tranco por uns bons anos, especialmente por ser um quad core.
    O benchmark foi feito em um computador EMPRESTADO pela AMD, os caras não puderam reinstalar o OS pra resolver as tretas da RAM, só ler o texto q eles falam isso.
    Eu tambem ando surpreso com a falta de interesse desse forum em noticias novas.. antigamente um topico desses ja ia ta na 5a pagina...
    E só pra constar, Windows vista eh um lixo, merece o titulo de ME II mais do que ninguem.
    Última edição por TM99 : 28-08-2007 às 23:49 Motivo: Lembrar que o windows vista eh um lixo.
    sei la né, dificil acreditar, mas espero que seja verdade ahua, como tenho mobo am2 seria so esperar uma versao mais low end dos k10 e "ser feliz".
    Última edição por Spectrobozo : 28-08-2007 às 23:52
    U.S.S.R.
    Sim eu sei. Resultado final: Ficou uma merda.
    Eu concordo que ficou meio estranho, mas não acho argumento forte pra invalidar a notícia...
    Vc vem lendo a respeito dos Barcelonas? Leu sobre o Fiasco do teste que a AMD publicou rodando ele a 2.6 falando que estava a 2.0 e depois teve que admitir a "malandragem", nesses testes mesmo depois de publicarem o teste a reais 2 Ghz, o desempenho foi MUITO bom, por isso que essa notícia apesar de espalafatosa, não é de se condenar...
    http://www.forumpcs.com.br/coluna.php?b=218381
    sobre a nova linha AMD
    e tambem sobre a retrocompatibilidade dos futuros processadores da AMD com o Socket AM2.
    http://en.wikipedia.org/wiki/Socket_AM2+
    Dia que a intel fizer isso o sol nasce no oeste.
    Última edição por TM99 : 29-08-2007 às 0:15
    Blá
    acerta muito mais mesmo
    eh uma area muito logica a computaçao
    eu posso dar VARIOS xutes aki e com ctz a maioria vou acertar
    mas em relaçao ao desempenho desse Barcelona
    axu meio dificil xutar
    mas c ker um xute
    axu q o barcelona vai bater o C2D
    por muito pouco, mas vai bater (c n bater ae ferrou com td, pois a AMD vai ta na merda)
    ja os penryn, duvido MUITO
    o q eu n boto feh eh q os barcelona vao sair fodasticos como tao falando no Inquirer
    vamos ver xD
    mas peryn ja ta mais do que provado que clock por clock com c2d atual nao é tao mais rapido... só estupra em coisa SSE4... se a amd conseguir ficar no mesmo nivel ja ta legal... o problema da AMD nunca foi falta de qualidade nos produtos, muito menos preço..
    UmK
    UmK está offline
    Citação Citando BlackOmega 99 Ver mensagem
    disse tudo no seu post, mas essa parte merece destaque. ta parecendo que o hardwhat virou forum de assistencia tecnica. por isso que nem visito essa merda mais, só passo aqui quando tem alguma noticia / rumor q pode dar uma revirada no mercado, como esse ae (e 90% das vezes saio decepcionado pq ninguem se quer menciona).
    dessa vez me dei ao trabalho de postar a noticia pra ver a discussão e pra variar unica coisa q discutem é a credibilidade da fonte.. decepcionante
    Última edição por UmK : 29-08-2007 às 0:15
    Se você sabe beleza, deve de concordar comigo que não é uma MERDA como falam por ai, a culpa não é da MS, se vc for analisar por esse lado, Linux é mais merda que o WindowsME então... BSD pior ainda... e as minorias então nem se fala né, lixo do lixo.
    E não, eu não venho lendo sobre o Barcelona não.
    To longe de ser Anti-Inquirer, já vi muita noticia certa daí, apenas questionei a credibilidade por comentarios realmente toscos. Se foi brincadeira ou não, não sei. Se foi blz, interessante, relevo. Agora se não foi, não dá para levar fé né.
    E outra, não quero desvirtuar, tem argumentos pra meter o pau no Vista? E no ME também tem?
    Blá
    eu axu q vai ser melhor
    n muito
    mas vai
    o prob foitoda essa demora
    C2D abocanhou uma GRANDE parte do mercado
    MUITO gente q tinha migrado de intel pra AMD na epoca dos AXP e inicio dos A64 volto pra Intel
    vamos ver como vai sair esse K10 e ve c vamos voltar pra AMD novamente xD
