    Vale apena pegar esta placa? Specs no tópico...
    Tá 185 essa placa...
    Vendi minha X1550... tava quernedo alguma outra um pouquinho melhor, pra rodar os jogos aqui...
    Final do ano eu devo pegar uma outra placa TOP, então essa é + mais quebra galho... e já que é baratinha, seila...
    Costumava jogar tranquilo na minha X1550: Scarface, Enemy Territory - Quake Wars, Super-Bikes Riding Challenge, Moto GP 2007, Test Drive Unlimited
    ttp://www.gecube.com/products-detail.php?prod_cat_pid=193&prod_cat_id=197&prod_i d=66443
    RADEON HD2400PRO, 256MB DDR2, On-board HDMI + S-video TV port, DVI ( Dual-Link, HDCP) Low profile Edition.
    VPU Radeon HD2400PRO (RV610) (65nm)
    Memory 256MB DDR2(HyperMemory to 1G)
    Bus support PCI-Express x16
    HDTV Support
    HDMI TV output Multi-Channel audio (5.1 surround) + HD Video - Native HDMI support
    Product Description
    The ATI Radeon™ HD 2400PRO is a feature-rich upgrade from integrated graphics for an immersive experience with DirectX® 10 gaming and HD video. Connect to big-screen TVs with HDMI port and built-in 5.1 surround sound audio to enjoy Blu-ray™ and HD DVD movies instantly. ATI Catalyst™ graphics configuration software is designed for quick setup and stable operation with Windows Vista™.
    ¡@ Product Features
    Certified for Windows VISTA Premium.
    Design based on ATI Radeon HD2400PRO series.
    On-board with 256MB DDR2 high speed memory.
    Unified Superscalar Shader Architecture built-in 120 stream processing units.
    Built-in HDMI native support for HD video with multi-channel (5.1) support
    The tall bracket and the extensive S-video cable will tag along wih the retail box which are for the TV-out function usage.
    Hardware processing UVD (unviversal Video Decoder) delivers sharp images and vibrant color fidelity with 1080p/i playback of Blu-ray and HD DVDs.
    Dual DVI display port supports resolutions up to 1920x1200 (single-link DVI) or 2560x1600 (dual-link DVI, HDCP).
    Windows Vista with comprehensive DirectX 10 support.
    Shader Model 4.0
    Nov 2004
    a placa eh mais moderna, mas tem desempenho pior em todos os jogos por ser de 64bits.
    A nao ser que tu faça um puta dum overclock nela, mas acho q nao compensa. Pega uma 2600pro, q tá na faixa dos 280 reais.
    fallow
    Blz!
    Valeu Pancho!
