    Problema com ATI TV Wonder em Sony Vaio
    Fala galera, beleza?
    To com um problema com um Sony Vaio recem comprado pelo meu amigo. O modelo é o SONY VAIO VGN-AR550U.
    ( http://www.newegg.com/Product/Produc...82E16834117538 )
    Acontece que ele vem com uma placa ATI TV WONDER Digital Cable Tuner, e ela só fica branco e preto pois é NTSC!
    Eu nunca tive uma placa de TV então não entendo nada... Alguém me ajuda a fazer esta placa funcionar em colorido!
    As especificações do notebook estão abaixo.
    VALEU AE!
    aBs
    Especificações:
    Model
    Brand SONY
    Series VAIO AR Series
    Model VGN-AR550U
    General
    Operating System Windows Vista Ultimate
    CPU Type Intel Core 2 Duo T7100 1.8G
    Screen 17" WXGA+
    Memory Size 2GB DDR2
    Hard Disk 240GB
    Optical Drive DVD Super Multi
    Graphics Card NVIDIA GeForce 8400M GT
    Video Memory 895MB Total Available Graphics Memory
    Communication Modem, LAN and WLAN
    Card slot 1 x Type II/Type I card slot with CardBus support
    1 x ExpressCard /54 Slot
    Battery Life 1.5-3.0 hours
    Dimensions 16.4" x 11.8" x 1.32"
    Weight 8.4 lbs.
    Tech Intel Centrino Duo Mobile Technology
    Other Features TV Tuner: ATI TV Wonder Digital Cable Tuner (NTSC and ATSC Support)
    CPU
    CPU Speed T7100(1.80GHz)
    CPU FSB 800MHz
    CPU L2 Cache 2MB
    Display
    Screen Size 17.0"
    Wide Screen Support Yes
    LCD Features XBRITE-HiColor Technology
    Display Type Wide XGA+
    Resolution 1440 x 900
    Operating Systems
    Graphics
    GPU/VPU NVIDIA GeForce 8400M GT
    Graphic Type Dedicated Card
    Hard Drive
    HD Capacity 240GB
    HD RPM 5400rpm
    HD Interface SATA
    HD Spec 2 x 120GB
    Memory
    Memory Speed DDR2 667
    Memory Size 2GB
    Max Memory Supported 4GB
    Memory Spec 1GB x 2
    Optical Drive
    Optical Drive Type DVD Super Multi
    Optical Drive Interface Integrated
    Optical Drive Spec DVD±RW : Yes
    DVD+R DL Write : 2.4x max.
    DVD-R DL Write : 2x max.
    DVD+R Write : 8x max.
    DVD+RW Write : 4x max.
    DVD-R Write : 8x max.
    DVD-RW Write : 4x max.
    DVD-RAM Write : 5x max.
    DVD-RAM Read : 5x max.
    DVD Read : 8x max.
    CD-R Write : 8x max.
    CD-RW Write : 8x max.
    CD Read : 24x max.
    Communications
    Modem Integrated V.92/V.90 Modem with (RJ-11)
    LAN 10/100Mbps
    WLAN Intel PRO/Wireless 4965AGN Network Connection (802.11a/b/g/n)
    Bluetooth Yes
    Ports
    Card Slot 1 x Type II/Type I card slot with CardBus support
    USB 3
    IEEE 1394 1
    Video Port 1 x VGA, 1 x S-Video TV-out
    Other port 1 x HDMI Connection Output
    Audio Ports 1 x Microphone jack; 1 x Headphone jack
    Audio
    Audio Sony Sound Reality - Audio Enhancer
    Built-in microphone
    Speaker Internal Speakers
    Input Device
    Pessoal alguém me ajuda!
    Qualquer ajuda que pelo menos me direcione pro problema!!
    não sei nem por onde começar!!!
