    Nov 2007
    Fonte Seventeam ST-420 BKV
    Comprei Hoje uma fonte Seventeam ST-420 BKV mas me disseram q ela nao é boa isso e verdade ou a fonte guenta tranquilo ?
    amd athlon x2 5.0
    2gb ddr 800
    hd 250 sata
    ge force 8600gt fatal1ty
    Membro Avatar de anjo_do_inferno
    Citação Citando AngelPrince Ver mensagem
    amd athlon x2 5.0
    2gb ddr 800
    hd 250 sata
    segurar, segura... sobre a fonte veja a analise do clubedoharware... http://www.***************.com.br/artigos/1304
    espero ter ajudado []s
    Nov 2007
    e a huntkey
    que acha se for uma huntkey LW-6450SG?
    ou uma thermaltake W0070RU - TR2-430W ?
    sobre a thermaltake, nao acho que seria 1 boa escolha pro momento atual, olhe as specs da fonte aki: http://thermaltakeusa.com/product/Po...70/w006970.asp, ela tem mta carga pra linha de 3,3v e 5v, as configurações demandam mais na linha de 12v, e no caso a TT oferece apenas 18, olhe esse review aqui da 8800GT FATAL1TY
    Le pouvoir "The Power"
    We'll now show you some tests we have done on overall power consumption of the PC. Looking at it from a performance versus wattage point of view, the power consumption is really not bad. Our test system is a Core 2 Duo X6800 Extreme Processor, the nForce 680i SLI mainboard, a passive water-cooling solution on the CPU, DVD-ROM and WD Raptor drive. Have a look.
    Videocard
    System Under load
    GeForce 8600 GT 231w
    GeForce 8600 GTS 231w
    GeForce 8600 GTS 236w
    The methodology is simple: we look at the peak wattage during with the help of a wattage meter. our new meter can record the maximum power consumption from the PC. So after we have finished all out testing session, we look at that meter what the maximum power draw was. Please do understand that you are not looking at the power consumption of the graphics card, but the consumption of the entire PC. It's not the most objective way to test as you have to consider PSU efficiency as well, but it's the closest thing we can do though. We use a Galaxy 1 KW PSU with 80-85% efficiency.
    We had a total system wattage peak at roughly 230-235 Watts which is the same for pretty much any 8600 edition card, it is definitely not excessive.
    My recommendations:
    A single GeForce 8600 GT/GTS requires you to have a 350 Watt power supply unit at minimum if you use it in a high-end system. That power supply needs to have (in total) at least 24 Amps available on the 12 volts rails.
    A second GeForce 8600 GT/GTS installed on this system requires you to have a 450 Watt power supply unit at minimum if you use it in a high-end system. That power supply needs to have (in total) at least 30 Amps available on the 12 volts rails.
    http://guru3d.com/article/Videocards/441/3/
    embora acho que ela aguentaria sem problemas pois ela consome perto dos 11a na linha 12v, em 1 upgrade futuro provavelmente vc precisara trocar a fonte, sobre a Huntkey, ela aguentaria sem problemas tb, ela tb tem o formato para as configurações mais modernas distribuindo mais amperes na linha 12v, embora eu tenha visto algumas criticas sobre "propaganda enganosa da marca"... mas n teria problemas em segurar sua configuração
    analise do user faller sobre as etiquetas aqui (mostra as etiquetas da huntkey) http://www.adrenaline.com.br/forum/s...d.php?t=169303,
    Membro Avatar de mornion
    Dec 2005
    Ela é boa sim, mas digamos que ja passou a época dela, hoje existem fontem bem melhores com a msm ou até menos potencia que ela. Eu tenho uma faz dois anos e ta tranquilona, ja passou por ela uma 6600GT e agora uma 8600GT.
    Última edição por mornion : 30-11-2007 às 10:48
    Membro Avatar de faller
    amd athlon x2 5.0
    2gb ddr 800
    hd 250 sata
    Agora que já compraste, usa. A fonte não é ruim. Tem baixa eficiência, mas vai segurar essa tua config numa boa. Até tenho indicado sua irmã mais nova em casos de configs assim simples, embora pense que uma AVC350 seja melhor que a ST350BKV. Não é uma fonte genérica não. Podes muito bem conviver com essa config por um bom tempo. Ela oferta 26 Amperes nas linhas de 12 Volts (é por isso que chego até a recomendar sua irmã mais fraca, a ST350BKV, que tem 25 Amperes para dar ai nessa linha de 12 Volts) Essa 420 BKV só tem mais potência nas linhas de baixa tensão, 3,3 e 5 Volts, aonde definitivamente não vais precisar mais do que 50 Watts (ela oferta 200 Watts)..
    Abraço...
