    Membro Avatar de Rajjax
    Lenovo 3000 N200 T7300 etc.. Bom??
    Opa galera , meu pai tem um cliente que ta devendo pra ele, e o cara queria quitar uma parte das dividas com um Note Lenovo 3000 N200
    segue a config completa dele retirados da Newegg
    Brand lenovo
    Series 3000 N Series
    Model N200 (0769A8U)
    Part# 0769A8U
    General
    Operating System Windows Vista Business
    CPU Type Intel Core 2 Duo T7300 (2.00GHz)
    Screen 15.4" WSXGA+
    Memory Size 1GB DDR2
    Hard Disk 160GB
    Optical Drive Dual Layer DVD Burner
    Graphics Card NVIDIA GeForce Go 7300
    Video Memory 256MB
    Communication Modem, LAN and WLAN
    Card slot 1 x Express Card
    Dimensions 14.17" x 10.5" x 1.52"
    Weight 6.33 lbs.
    Tech Intel Centrino Duo Mobile Technology
    Other Features Fingerprint reader, Secure Chip
    CPU
    CPU Speed T7300(2.00GHz)
    CPU FSB 800MHz
    CPU L2 Cache 4MB
    Display
    Screen Size 15.4"
    Wide Screen Support Yes
    LCD Features VibrantView
    Display Type Wide SXGA+
    Resolution 1680 x 1050
    Operating Systems
    Graphics
    GPU/VPU NVIDIA GeForce Go 7300
    Video Memory Dedicated 256MB
    Graphic Type Dedicated Card
    Hard Drive
    HD Capacity 160GB
    HD RPM 5400rpm
    HD Interface SATA
    Memory
    Memory Slots 2 x SO-DIMM
    Memory Speed DDR2 667
    Memory Size 1GB
    Max Memory Supported 4GB
    Memory Spec 1GB x 1
    Optical Drive
    Optical Drive Type Dual layer DVD Burner
    Optical Drive Interface Integrated
    Communications
    Modem 56K
    LAN 10/100Mbps
    WLAN Intel Wireless Wi-Fi Link 4965AGN
    Bluetooth Yes
    Ports
    Card Slot 1 x Express Card
    USB 4
    IEEE 1394 1
    Video Port 1 x VGA, 1 x S-Video TV-out
    Audio Ports 1 x Microphone jack; 1 x Headphone jack
    Audio
    Audio Integrated Sound card
    Speaker Internal Speakers
    Input Device
    Touchpad Yes
    Keyboard Standard
    Supplemental Drive
    Card Reader 5-in-1 Card reader
    Support SD Card, MultiMedia Card, Memory Stick, xD-Picture Card, or Memory Stick Pro card
    Webcam Yes
    Power
    AC Adapter 65-watt AC adapter
    Battery 6-cell lithium ion
    Physical spec
    Dimensions 14.17" x 10.5" x 1.42"
    Weight 6.23 lbs.
    Pela config parece c um bom notebook, essa geforce go 7300 eh razoavel? tpo oq para desktops? uma 6800?
    e na newegg ta saindo por U$1099,00 alguem faiz ideia qto q ficaria aki no BR? pra pode acerta direito qto da divida iria ser quitado..
    falowss e valeus
    Membro Avatar de mornion
    Dec 2005
    A 7300 é mais ou menos como uma 6600, 6500, não é AQUELAS maravilhas hoje mais, mas da um bom caldo perto dos outros videos que temos pra notebook hoje.
    Na minha opinião é um ótimo notebook, eu com o meu Dell Vostro ja to tendo orgasmos (), se vc colocar mais 1GB nele fica o bicho.
    Membro Avatar de diegotmc
    May 2007
    pra um note, a config é bem top. melhor que isso já é aqueles "desktop replacement" monstros
    só perde em portabilidade, por ser um pouco grande. mas isso também pode ser ruim pra uns, e bom pra outros
    hmmmm
    entendi , é pela config eu achei um excelente note, soh falta mais 1 gb de memoria q ai mais pra frente eu compro... mas entao acho q vo fala pro meu pai aceita =)
    mais alguma opiniao?
    falowsss
    achei mto bom, adoraria ter um...
