    gca
    gca está offline
    Minha placa mae aceita 8600 fatality?
    Olá, minha placa mãe é http://www.gigabyte.com.tw/Products/...ProductID=2331
    GA-945GM-S2
    Gostaria de saber se a Geforce 8600 Fatality é compativel:
    Brand XFX
    Model PVT84JU1D4
    Interface
    Interface PCI Express x16
    Chipset
    Chipset Manufacturer NVIDIA
    GPU GeForce 8600GT
    Core clock 620MHz
    Stream Processors 32
    Memory
    Memory Clock 1700MHz
    Memory Size 256MB
    Memory Interface 128-bit
    Memory Type GDDR3
    3D API
    DirectX DirectX 10
    OpenGL OpenGL 2.0
    Ports
    DVI 2
    TV-Out HDTV Out
    VIVO No
    General
    Tuner None
    RAMDAC 400 MHz
    Max Resolution 2560 x 1600
    RoHS Compliant Yes
    SLI Supported Yes
    Cooler Fanless
    Dual-Link DVI Supported Yes
    Podem me ajudar?
    Obrigado
    Sep 2005
    Sim totalmente compativel
    Expansion Slots
    1. 1 PCI Express x 16 slot
    2. 1 PCI Express x 1 slot
    3. 2 PCI slots
    fica sussa
    gca
    gca está offline
    Valew!!
