    Membro Avatar de darkmare
    Dec 2004
    ajuda com provavel sistema am2 ( duvida com mobo)
    estou montando um sistema com:
    5000+ B.E.
    kit 4gb ddr-2 800mhz
    ati 3870 512mb
    a abit custa 99 dolares
    a gigabyte custa 110 dolares
    duvidas:
    1)Existe diferença entre os chipsets 770 e 790 em desempenho?
    2) duvida persiste na escolha da plc mae pois estou querendo alguma com chipset AMD 770 a duvida seria entre essas plc's:
    ABIT AX78 AM2+/AM2 AMD 770
    Model
    Brand ABIT
    Model AX78
    Supported CPU
    CPU Socket Type AM2+/AM2
    CPU Type Phenom / Athlon 64 X2 / Sempron
    FSB 2600MHz Hyper Transport (5200 MT/s)
    Chipsets
    North Bridge AMD 770
    South Bridge AMD SB600
    Memory
    Number of Memory Slots 4×240pin
    Memory Standard DDR2 1066* / 800
    *DDR2 1066 is supported by CPU AM2+ only
    Maximum Memory Supported 8GB
    Dual Channel Supported Yes
    Expansion Slots
    PCI Express x16 2 x PCI-E X16 (1x16; 1x4 bandwidth)
    PCI Express x1 1
    PCI Slots 3
    Storage Devices
    PATA 1 x ATA100 2 Dev. Max
    SATA 3Gb/s 4
    SATA RAID 0/1/0+1
    Onboard Video
    Onboard Video Chipset None
    Onboard Audio
    Audio Channels 8 Channels
    Onboard LAN
    Max LAN Speed 10/100/1000Mbps
    Rear Panel Ports
    PS/2 2
    USB 4 x USB 2.0
    S/PDIF Out 1x Optical
    Audio Ports 6 Ports
    Onboard USB
    Onboard USB 6 x USB 2.0
    Physical Spec
    Form Factor ATX
    Dimensions 12.0" x 9.6"
    GIGABYTE GA-MA770-DS3 AM2+/AM2 AMD 770
    Model
    Brand GIGABYTE
    Model GA-MA770-DS3
    Supported CPU
    CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
    Chipsets
    Memory
    Maximum Memory Supported 16GB
    Expansion Slots
    PCI Express 2.0 x16 1
    PCI Express x1 4
    PCI Slots 2
    Storage Devices
    SATA 3Gb/s 4
    SATA RAID 0/1/0+1
    Onboard Audio
    Audio Chipset Realtek ALC888
    Onboard LAN
    LAN Chipset Realtek 8111B
    Rear Panel Ports
    PS/2 2
    COM 1
    USB 6 x USB 2.0
    IEEE 1394 2 x IEEE 1394a
    S/PDIF Out 1x Optical, 1x Coaxial
    Audio Ports 6 Ports
    Onboard USB
    Onboard USB 4 x USB 2.0
    Onboard 1394
    Onboard 1394 1x 1394a
    Physical Spec
    Form Factor ATX
    Dimensions 12.0" x 8.3"
    Windows Vista Certified for Windows Vista
    Dec 2004
    help ? =/
    Membro Avatar de AccellX®
    Tenta descobrir qual chip de audio a Abit usa..
    a giga tem o ALC888 que eh bom.. mais pode ser que a abit use o 888A um pouco melhor.
    No mais as placas são praticamente iguais.. me parece que a Giga é um pouco melhor.. mais em contra partida ela tem apenas um slot 1x...
    vai mais do seu gosto hehe
    Membro Avatar de diegotmc
    May 2007
    a gigabyte parece melhor acabada
    Dec 2004
    o que é aquele suporte de alimentação de 8 pinos na abit? perto do soket do processador?
