    Ajuda ACPI
    galera, consegui finalmente instalar meu notebook com o windows xp e todos os drivers!
    so que o processador esta rodando na velocidade max td hr...e eskenta pra vc
    em gerenciador de dispositivos, tem 3 icones nao identificados do acpi...
    me ajudem please
    onde achu esses drivers??
    meu micro e um gateway t-1625
    obrigado
    up please
    hellllllllllllllp
    Sep 2005
    Geralmente é falta do driver do chipset.
    Citação Citando Pedro Silveira Ver mensagem
    me ajudem please
    obrigado
    cara isso é o driver do processador ou do co-processador. eu nem vi sobre o modelo do seu note mas sei que isso resolve.
    alguem poderia me ajudar onde acho os drivers??
    eu nao consegui sozinhu
    ae vaum as specificações do micro:
    T-1625 Notebook Specifications
    Part Number: 1015086RGateway T-1625 Notebook
    Feature Description
    Processor AMD Turion™ 64 X2 Mobile Technology TL-60
    2.0 GHz | 512 KBx2 L2 cache
    HyperTransport™ technology up to 1600 MHz
    Chipset ATI RS690T
    Display panel 14.1-inch Ultrabright™ WXGA TFT display (1280 × 800)
    Memory 2048 MB 667 MHz DDR2 SDRAM (2 × 1024)
    Total slots: 2 DDR2 slots | Available slots: 0 DDR2 slots
    Video controller ATI Radeon® X1270 graphics
    Up to 256 MB of HyperMemory™
    Webcam 1.3 Megapixel
    Fingerprint reader No
    Audio High definition audio - 2 channel
    Hard drive 250 GB 5400 RPM SATA hard drive
    Optical drive 8X Multi-Format Dual Layer DVDRW with DVD-RAM and Labelflash™
    Write maximum: 8X DVD +/-R, 6X DVD-RW, 8X DVD+RW, 2X DVD-R DL, 2.4X DVD+R DL, 5X DVD-RAM, 24X CD-R and 16X CD-RW discs
    Read maximum: 8X DVD-R/RW/ROM, 4X DVD+/-R DL, 5X DVD-RAM, 24X CD-R/RW/ROM discs
    Modem Integrated V.92 56K modem
    Network 10/100 Ethernet LAN
    802.11g Wireless LAN
    Memory card reader 5-in-1
    * Memory Stick®
    * Memory Stick Pro®
    * Multimedia Card™
    * Secure Digital™
    * XD
    MiniSD and RS-MMC (when used with adapter that is supplied with card)
    Interfaces
    * Three - USB 2.0 ports
    * One - VGA port
    * One - HDMI version 1.2 connector
    * RJ-11 port
    * RJ-45 port
    * Headphone/SPDIF Audio Out jack
    * Microphone jack
    * One - Lock slot
    * Power input
    Pointing device Touchpad with vertical scroll zone
    Expansion slot Expresscard® Type 54
    Battery 6-cell Lithium-ion
    Dimensions 1 to 1.30-inches (H) × 12.95-inches (W) × 9.7-inches (D)
    25 to 33 mm (H) × 329 mm (W) × 246 mm (D)
    Weight 5.55 pounds
    2.52 kilograms
    Feature Description
    Chipset ATI RS690T
    * Memory Stick®
    * Memory Stick Pro®
    * Multimedia Card™
    * Secure Digital™
    * XD
    Interfaces
    * One - VGA port
    * RJ-11 port
    * RJ-45 port
    * Microphone jack
    * One - Lock slot
    * Power input
    Weight 5.55 pounds
    2.52 kilograms
    se não achar no site do fabricante tenta instalar o aida ou o everest
    já instalei o everest
    mas nao diz nada pra informar aonde puxar nem especificações do dispositivo.
    ajuda please
    ajuda please
    dispositivos PCI
    BOMsoMITO 2018!
    Uia ^^
    Tira uma screenshot do gerenciador de dispositivos, kd o cd q vem com o note ?
    o cd só tem drivers pra windows vista...
    porem, puxei o chipset da minha mobo hj nop site da amd com drivers pro xp e mesmo assim nao funcionou...
    vou mandar o link pro pessoal ver...pode ser que tenha feito cagada...
    http://wwwd.amd.com/AMD/SReleaseF.ns...t?OpenDocument
    AMD M690T/M690E/SB600 Chipset Windows® XP 32/64-Bit Drivers v8.40 - Windows® XP drivers for M690T/SB600 and M690E/SB600 chipsets. (M690T, M690E, SB600)
    continua sem informação
    As vezes o ruindows nao reconhece o processador na instalaçao ai ele fica sem acpi unica soluçao formatar e instalar dinovo.
    up galera1
    o problema continua sem solucao!
    up galera1
    já baixou o driver p/ o seu CPU?
    talvez ajude
    Membro Avatar de frodex
    Posta um screenshop do gerenciador de dispositivos
    no gerenciador de dispositivos
    FALA Q TAH UNKNOW 3 DISPOSITIVOS
    SENDO A MESMA IDENTIFICACAO NOS 3
    Microsoft ACPI-Compliant Embedded Controller
    gente
    forca ae!
    problema continua
    Dispositivos PCI:
    Bus 0, Dispositivo 24, função 1 AMD Hammer - Address Map
    Bus 0, Dispositivo 24, função 2 AMD Hammer - DRAM Controller
    Bus 0, Dispositivo 24, função 0 AMD Hammer - HyperTransport Technology Configuration
    Bus 0, Dispositivo 24, função 3 AMD Hammer - Miscellaneous Control
    Bus 1, Dispositivo 5, função 2 ATI RS690(M) Chipset - High Definition Audio Controller
    Bus 0, Dispositivo 0, função 0 ATI RS690(M) Chipset - Host Bridge
    Bus 0, Dispositivo 1, função 0 ATI RS690(M) Chipset - PCI Express IGP Port
    Bus 0, Dispositivo 5, função 0 ATI RS690(M) Chipset - PCI Express Port 1
    Bus 0, Dispositivo 7, função 0 ATI RS690(M) Chipset - PCI Express Port 3
    Bus 1, Dispositivo 5, função 0 ATI RS690M Chipset - Video Adapter
    Bus 0, Dispositivo 19, função 5 ATI SB600 - EHCI USB 2.0 Controller
    Bus 0, Dispositivo 20, função 2 ATI SB600 - High Definition Audio Controller
    Bus 0, Dispositivo 20, função 1 ATI SB600 - IDE Controller
    Bus 0, Dispositivo 19, função 0 ATI SB600 - OCHI USB Controller
    Bus 0, Dispositivo 19, função 1 ATI SB600 - OCHI USB Controller
    Bus 0, Dispositivo 19, função 2 ATI SB600 - OCHI USB Controller
    Bus 0, Dispositivo 19, função 3 ATI SB600 - OCHI USB Controller
    Bus 0, Dispositivo 19, função 4 ATI SB600 - OCHI USB Controller
    Bus 0, Dispositivo 20, função 3 ATI SB600 - PCI-LPC Bridge
    Bus 0, Dispositivo 20, função 4 ATI SB600 - PCI-PCI Bridge
    Bus 0, Dispositivo 18, função 0 ATI SB600 - SATA Controller
    Bus 0, Dispositivo 20, função 0 ATI SB600 - SMBus Controller
    Bus 8, Dispositivo 0, função 0 Realtek RTL8139/810x Fast Ethernet Adapter
    Última edição por Pedro Silveira : 11-03-2008 às 0:39
    som ta funcionando? pode ser o chipset tbm tem que ver. baixa o driver do chipset e o microsoft uaa high definition.
    quanto ao cpu se for amd tem no darkgiank (forum - procura no google) o driver do processador.
    galera, ja instalei dos drivers do procesador pelo site da amd.;...mas nao some nada
    instalei o southbridge pelo site da ati..e nada
    o som está normal tb...
    pqp...q q tah acontecendo!
    alguem me de uma luz!
    up ae!!!
    instalei o winx64 e continua mesma coisa...
    com o win vista roda td normal galera...
    mas preciso dos drivers pro xp mesmo...nao quero voltar pro vista
    Se o vista instala tudo, use o everest para gerar uma relacao de dispositivos/drivers instalados.
    Ai rode ele no XP e veja o que tinha no 64 que esta faltando no xp e pegue os drivers na net.
    instalei os pacotye de drivers especificos nosite da AMD...td certinhu amigos
    continua a porra do microsoft ACPI sem idenfiticação
    pow...vo quebra essa merda
    Amigos
    Problema Sem Solução!
    Peça Ajuda Please
