    Membro Avatar de Poison Lord[CA]
    [JogoRapidoMOB]Rede da p5k premium...
    Fala galera, tenho uma p5k premium e ela tem 2 portas de LAN
    uma
    Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller
    e uma
    Realtek RTL8169/8110 Family Gigabit Ethernet NIC
    a questão é qual diferença de uma para outra e principalmente...qual é a melhor?
    Obrigado
    O mais forte do universo!
    na real? é a mesma merda!
    Realtek RTL8169/8110 Family Gigabit Ethernet NIC: The Realtek RTL8169 NIC Gigabit Ethernet controllers (RTL8169SB (128 QFP) & RTL8169SBL (128 LQFP)) combine a triple-speed IEEE 802.3 compliant Media Access Controller (MAC) with a triple-speed Ethernet transceiver, 32-bit PCI bus controller, and embedded memory. With state-of-the-art DSP technology and mixed-mode signal technology, they offer high-speed transmission over CAT 5 UTP cable or CAT 3 UTP (10Mbps only) cable. Functions such as Crossover Detection & Auto-Correction, polarity correction, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, and error correction are implemented to provide robust transmission and reception capability at high speeds.
    ompliant with PCI Express Specification, revision 1.0a
    1-lane 2.5Gbps PCI Express host interface
    Low Profile PCI Form Factor
    RJ-45 Port offer high speed transmission over CAT 5 UTP cable
    Auto-Negotiation with Next page capability
    Supports pair swap/polarity/skew correction
    Microsoft NDIS5 Checksum Offload (IP, TCP, UDP) and largesend offload support
    Supports Full Duplex flow control (IEEE 802.3x)
    Supports IEEE 802.1Q VLAN tagging
    8K Transmit FIFO and 64K Receive FIFO support
    Fully RoHS compliant
    Supports Windows Vista
    Supports Mac OS X v10.4
    Consegui juntar isso hehe veja se dá p tirar alguma conclusão.. eu acho que não.
    Pessoalmente prefiro realtek, apesar de nunca ter tido problema com as marvell,
    as realtek sempre me deram uma compatibilidade excelente em qq coisa que tentei
    espeta-las.
    Membro Avatar de Etnies
    Jul 2006
    As duas fazem a mesma coisa do mesmo jeito, use qual você "acertar" o cabo primeiro.
    pensei isso mesmo, tu usando a marvel mas o textinho ali em cima foi bacana da pra ver as espcificações ehehe valeu galera
    Até onde eu sei a Realtek é 100/1000 e a Marvel é 10/100
    será que procede?
