    Oct 2005
    NB HP DV6785SE ou NB SONY CR420E/R
    Será meu primeiro NB, esses modelos são bons? ambos na mesma faixa de preço....gostaria da opniao de vcs qual devo pegar, ou se nao devo pegar nenhum dos dois hehe. Obrigado
    NB HP DV6785SE C2D 1.67/3G/250/RW/CAM/15.4''
    Valor: 1,355.00 dolares
    Características
    - MODELO: PAVILION DV6785SE
    - FSB: 667MHZ
    - SITE DO FABRICANTE: HTTP://WWW.HP.COM
    - TECNOLOGIA: CENTRINO DUO
    - FABRICANTE: HP
    - RESOLUCAO: 1280 X 800
    - RECURSOS EMBUTIDOS: IMPRESSAO DIGITAL, CAMERA WEB 1.3MP
    - COR: BRANCO E CINZA
    - CACHE TOTAL: 2MB
    - MEMORIA INTERNA: 3GB DDR2 667MHZ (2+1) EXPAND 4GB
    - PESO: 2.79KG
    - DIMENSOES: 14.05" X 10.12" X 1"/1.69"
    - DISPLAY: 15.4" LCD WXGA BRIGHT WIEW WIDESCREEN
    - PROCESSADOR: MOBILE DUAL CORE INTEL CORE2 DUO 1.67GHZ
    - SISTEMA OPERACIONAL: WINDOWS VISTA HOME PREMIUM *INGLES
    - UNIDADE OTICA: GRAVADOR DVD+-RW DUAL LAYER *HD DVD
    - TECLADO: INGLES
    - HD: 250GB *5400RPM *8MB DE BUFFER *SATA
    - BATERIA: INTERNA LITHIUM-ION
    - MICROFONE: EMBUTIDO
    - CORES: 32 BITS
    - REDE RJ45 10/100: REALTEK RTL8101E
    - VGA: 1535MB NV GEFORCE 8400M G *COMPART *DEDICAD 256MB
    - USB 2.0: 03
    - MINI FIREWARE: 01
    - FAX: 56KBPS
    - SAIDA AUDIO/VIDEO: 02 FONE
    - PCMCIA: 01 EXPRESS CARD/54
    - ENTRADA DE AUDIO/VIDEO: 01 MICROFONE
    - LEITOR DE CARTAO: SD,MMC,STICK/PRO,XD
    - WLAN: WIRELESS INTEL PRO/4965AGN *BLUETOOTH
    - PORT REPLICATOR: 01
    - MONITOR EXTERNO: 01
    - SAIDA DE TV: 01 S-VIDEO
    - MANUAL: SIM
    - CABO DE FORCA: 01
    - FONTE EXTERNA: BIVOLT 100/240
    - CD/DVD RECOVERY: NAO POSSUI CREAR ANTES DE FORMATAR
    - FONE DE OUVIDO: 01
    - CONTROLE REMOTO: 01
    - HDMI: 01
    NB SONY CR420E/R C2D 2.1/3G/250/RW/CAM/14'
    Valor: 1,345.00 dolares
    Características
    - MODELO: VAIO VGN-CR240E/L
    - FSB: 800MHZ
    - SITE DO FABRICANTE: HTTP://WWW.SONY.COM
    - FABRICANTE: SONY
    - RECURSOS EMBUTIDOS: CAMERA WEB 1.3MP
    - COR: VERMELHO, PRATA
    - CACHE TOTAL: 3MB
    - PESO: 2.49KG
    - DIMENSOES: 13.2" X 9.8" X 0.83"/1.51"
    - DISPLAY: 14.1" LCD WXGA XBRITE-ECO WIDESCREEN
    - PROCESSADOR: MOBILE DUAL CORE INTEL CORE2 DUO 2.1GHZ
    - TECLADO: INGLES
    - CORES: 32 BITS
    - VGA: 358MB INTEL GMA X3100 *COMPARTILHA
    - USB 2.0: 03
    - MINI FIREWARE: 01
    - FAX: 56 KBPS
    - SAIDA AUDIO/VIDEO: 01 FONE
    - PCMCIA: 01 EXPRESS CARD/34
    - LEITOR DE CARTAO: SD,STICK/PRO
    - WLAN: WIRELESS INTEL 4965AGN WI-FI *BLUETOOTH
    - MANUAL: SIM
    - CABO DE FORCA: 01
    - CD/DVD RECOVERY: NAO POSSUI CRIAR ANTES DE FORMATAR
    Membro Avatar de ReflexiS
    vaio
    nao era esses HPs q tavam dando problema?? e dps dah uma dor de cabeça correr atras e arrumar?
    Oct 2005
    pois eh kra, esse eh meu medo.....como nao manjo muito, acredito q sony seja mais marca que Hp
    Membro Avatar de Jack
    Citação Citando ReflexiS Ver mensagem
    vaio
    Os hps que tão dando problema são os com proc AMD
    test automation
    Eu iria no HP, mesmo porque somente o lote com AMD's deu problema...
    Abcs..
    Jun 2007
    Citação Citando eduhunter Ver mensagem
    Abcs..
    E ainda são só alguns lotes dos AMDs..
    Mas eu iria de Vaio.. Parece ter proc melhor e é menor
    test automation
    Citação Citando eduardoll Ver mensagem
    Exatamente, apesar de que fiz minha escolha no HP pela vga... mas vai depender do uso do criador do tópico...
    Abcs..
    Membro Avatar de daniel_cps
    e as arveres some nozes
    eu vou nesse vaio... to esperando sobrar uma $$ p pegar um desse azul p mim.
